Waterloo to be new Sleeper train hub?
Eagle
20 Feb 2011
Leamingrad / Blanfrancisco
If it can be kept with FGW then fab, I wasn't sure whether it'd have to be transferred to SWT.
It doesn't serve any routes on SWT's network so that would be a ridiculous thing to do.
I don't know what the WLL is :P
The West London Line, that runs between Willesden and Clapham Junction/Latchmere Junction.
ValleyLines142
25 Jul 2011
Gloucester
I know that but I wasn't sure whether Waterloo being a SWT hub it would need to be transferred, but maybe not.
Ah right. I still don't really see the point though.
ChristopherJ
Repeatedly returning banned member
8 Aug 2005
London, UK
West London Line. (Clapham Junction - Willesden Junction)
The Caledonians can be diverted round the WLL (which is fully electrified) which only adds about six miles to the total journey, so it's hardly a major diversion—would add 20-30 minutes tops.
How do you propose to solve the problem that the 25kv AC overhead catenary only extends as far as North Pole? It's 750V DC third rail for the remainder of the route to Latchmere Junction and in to Waterloo.
Eagle
20 Feb 2011
Because Waterloo has all that lovely spare capacity going to waste in the form of 20-car-long platforms 21–24 (and Euston might lose its long platforms sometime soon when it's rebuilt), meaning you could stick the sleepers there and free up space in Euston and Paddington.
How do you propose to solve the problem that the 25kv AC overhead catenary only extends as far as North Pole? It's 750V DC for the remainder of the route to Latchmere Junction and in to Waterloo.
Use 92s instead of 90s. FSR hire the 90s from DBS as it is, and DBS have lots of 92s.
ValleyLines142
25 Jul 2011
Gloucester
I haven't heard anything about Euston losing platforms during it's rebuild.
ChristopherJ
8 Aug 2005
London, UK
The transfer of the Cornish Riviera sleeper to Waterloo would probably cause more operational headaches than benefits, if the rolling stock remains allocated to Old Oak Common depot it would require two reversals just to reach Waterloo, at present the Cornish stock is a mere and simple direct sprint in to Paddington.
Old Oak Common Depot - (reverse) - Acton Main Line - (reverse) -Acton Wells Junction - Willesden South West Sidings - Willesden Junction Low Level - West London Line - Latchmere Junction - Waterloo.
ValleyLines142
25 Jul 2011
Gloucester
Wouldn't lose platforms, but the really long ones might not be as long any more. It's mentioned in post #1 :P
I only look at the most recent page :P
I don't see why, plus if that's the case then have people boarding at a carriage that meets platform space and then walk through if the carriage that one is travelling on doesn't fit.
ukrob
15 Jan 2009
Fouling the station throat and ignoring signals then?
ValleyLines142
25 Jul 2011
Gloucester
My post has been edited to be more accurate :P
Everything you've just said there could be equally true of Paddington or Waterloo.
I did notice. And indeed you are right, but it seems more logic still with what it is at the moment. The Sleepers could potentially get stuck in disruption by going on the WLL, e.g. signalling problem, overhead wire problems etc. Imagine a sleeper leaving London at 2130. It gets stuck in congestion somewhere on the WLL, for over an hour. Come 2300 and you still haven't left London! Whereas you'd be well on the way up north as it is now if it stayed at Euston/Paddington.
I don't know any of this, but there's obviously stations in the country that are too short and often have announcements saying something along the lines of 'Due to short platforms customers for A, B and C should travel in the front 4 coaches only' or whatever.
Eagle
20 Feb 2011
I did notice. And indeed you are right, but it seems more logic still with what it is at the moment. The Sleepers could potentially get stuck in disruption by going on the WLL, e.g. signalling problem, overhead wire problems etc. Imagine a sleeper leaving London at 2130. It gets stuck in congestion somewhere on the WLL, for up to an hour. Come 2230 and you still haven't left London!
They could potentially get stuck in all that kind of disruption on the way out of Euston too. I really don't see what your point is.
Anyway 22.30 is far too early for a sleeper to leave London, it would get to its destination at about 4am! :P
ValleyLines142
25 Jul 2011
Gloucester
Yes but it hasn't got to conquer problems that could occur on the WLL.
Well the Highland Sleeper currently leaves Euston at 2115 so I don't quite understand that. Plus I said 2130 anyway not 2230.
Eagle
20 Feb 2011
Those are all stations with two platforms and two lines, or something similar. Euston has 19 platforms which rapidly converge to just six lines. A traiin that's too long would foul loads of points. Also remember that the Caley sleepers split en route anyway, so you're just adding another complication to passengers.
MidnightFlyer
16 May 2010
Very few of those instances foul junctions...
Eagle
20 Feb 2011
There's a route from the WLL to the WCML without needing to reverse once, never mind twice.
No, we were talking about needing to reverse twice to get from Waterloo to Old Oak Common depot (once at Acton Mainline and once at Paddington). Which would only be a problem if the sleeper stock was still allocated there.
Jonny
10 Feb 2011
xplo42 said:
The transfer of the Cornish Riviera sleeper to Waterloo would probably cause more operational headaches than benefits, if the rolling stock remains allocated to Old Oak Common it would require two reversals just to reach Waterloo, at present the Cornish stock is a mere and simple direct sprint in to Paddington.
Old Oak Common - (reverse) - Acton Main Line - (reverse) -Acton Wells Junction - Willesden South West Sidings - Willesden Junction Low Level - West London Line - Latchmere Junction - Waterloo.
Exactly so. Plus Paddington is more convenient to the centre of London, around 5-10 minutes on the Tube to say Oxford Street etc. Waterloo may almost be double that.
Firstly, my understanding of London is that Waterloo is closer to a lot of things that Paddington is - in fact Paddington is quite a way out. Secondly, the stock need not be based at Old Oak Common (could even be Willesden?) - the OP also pointed out the Windsor Lines have access to Waterloo International so the Cornish Sleeper could reach the Eurostar platforms from the Windsor lines merely with a turn-off at Reading ;)
Eagle
20 Feb 2011
I was thinking that the Riviera would run via Acton Mainline and Kensington Olympia (like XC used to) myself...
Just in case all this discussion is a little hard to follow, here's a rough diagram (including the Riviera routes in grey).
marks87
23 Jun 2010
Dundee
The mention of a double-reversal was at the end of a post about the Caledonian Sleeper, so I believe the confusion to be not mine, but instead DanTrainMan185's.
YorkshireBear
23 Jul 2010
Economies of scale of a sleeper franchise? Maybe even with GW electrifcation you could run 92s, then have a diesel switchover at newbury/bristol.
Seems a good idea to me to be honest, as long as suitable solutions to traction are made ie, not having 25KV AC for first section of route.
ushawk
5 Nov 2010
Eastbourne
I think it would just be easier to run it direct from Waterloo to Reading via the Windsor lines rather than along the WLL - there cant be much difference with the journey times.
ValleyLines142
25 Jul 2011
Gloucester
No, I was in fact referring to Eagle's post. I got my info wrong however.
Erm... what?
Don't worry - just see below instead (although I have to admit I do find your 'erm...what?' slightly patronising if I may say so, although I'm not getting into a debate about that). Eagle's diagram has made things a lot easier to explain :)
... Or problems that could occur between Euston and Willesden / Wembley...
But at least they're already on their way out of London, if this happened on the WLL they'd still have to go past Euston and Willesden/Wembley and still effectively be in London.
That picture is EXACTLY what I need! Okay, the new terminus is Waterloo, it needs to go past Latchmere Junction, Kensington Olympia and Willesden Junction, an extra journey time of 20-30 minutes to what you said Eagle, compared to what it is now. The current sleeper goes straight past Queens Park and up. So anything could happen between Waterloo and Willesden Junction, meaning delays, but then out of Euston you're straight out of London. In other words, Waterloo in south London has to obviously pass through to get to north London and out, whereas the current service doesn't have to do this instead. Hope this is better to understand.
Eagle
20 Feb 2011
Granted, the route to Waterloo is slightly more complex, but "anything could happen" between Euston and Willesden too. It's only a couple of miles longer, and 20 or 30 minutes doesn't matter when you consider that Scotrail's sleepers have over an hour of padding in them anyway.
"Straight past Queen's Park and up" isn't really a fair description, as there's still 15 miles/25 minutes till you even get to Watford.
Your argument seems to hinge on the fact that the way out of Waterloo doesn't look very direct on a map, when that's a piddling concern given that it's a route hundreds of miles long.
Anyway, the route from the WCML to Waterloo is far less complex than the route from the ECML to Euston, which is used often when the sleeper is diverted.
