Wasn't there once a subway at Bolton?
SodTheDrummer
14 May 2015
Bolton
My dad seems to think so,but I assume if so, it was filled in when they knocked down Trinity Street station and built the current "architectural masterpiece" in the 80's. I can see what appear to be vents in the platform edges still, but I was only about 10-12 at the time, we'd moved from the area and due to the fact I struggle to recall what I did last week, it's all long gone... :(
MidnightFlyer
16 May 2010
I have been told and seen it confirmed many times that in the past that one existed: you can see remnants of it on the far wall if you look across from the end of the canopy on platform 4 towards platforms 1-3. I don't think any other trace remains in situ though. I too would also presume it went with the old building.
reg
15 Mar 2015
Bolton
If you look at the drawings submitted by Network Rail to BMBC planning(ref 96761/16) the subway is quite clearly marked.The application relates to alterations to the station canopy.
SodTheDrummer
14 May 2015
Bolton
I knew I'd seen something about it somewhere! Thanks for that Reg! :D
That would suggest that it's still there and just capped off though rather than filled in completely?
Trackman
28 Feb 2013
Lewisham
It's still there and I've seen inside it. It was a parcel/PO subway between platforms/warehouse/old station. the platform link is definitely not filled in, don't know where it's capped elsewhere though.
AndrewE
9 Nov 2015
And the country end of Liverpool Lime St, believe it or not. Cut into the bedrock even deeper than the tracks. Not very big though (too small for an old post office trolley If I remember it right.)
