Warrington BQ to Chester routeing
rownd
28 Jul 2012
Midlands
Would a Warrington to Chester Cheap Day Return, route Any Permitted, be valid via Crewe?
TCBC says yes (map CG), but it's very overdistance and I don't really want to excess! Via Crewe is a backup on split tickets from Blackpool in the event of the six minute connection for the direct service failing to work.
Cheers
clagmonster
8 Jun 2005
As you say, you are not using the shortest route and it presumably isn't a direct train, so we use the National Routeing Guide: http://www.atoc.org/about-atoc/rail-settlement-plan/routeing-guide
Warrington Bank Quay is a member of the Warrington Group.
http://www.atoc.org/clientfiles/File/routeing_point_identifier.pdf page 63
Chester is a routeing point.
http://www.atoc.org/clientfiles/File/routeing_point_identifier.pdf page 14
Routeing permissions for Warrington Group to Chester are: CG, CL and ML.
http://www.atoc.org/clientfiles/File/permitted_route_identifier (version RGL WGN amended 140213).pdf page
CG shows:
Warrington Group-Crewe-Chester
http://www.atoc.org/clientfiles/File/Maps.pdf page 14
So yes, permitted route as per the same method as trains can be cheaper. If it makes you feel more comfortable, take print outs of the relevent links I have provided, and maybe even Condition 13 of the National Rail Conditions of Carriage.
kieron
22 Mar 2012
Connah's Quay
Thanks for confirming that. I'll save a copy of the maps just in case!
It may be easier to explain if you take an itinerary showing that route with you. You probably won't get asked, as ticket sites will give this route if you just ask for "Warrington to Chester" most times of the day, but train staff are more likely to be familiar with "the web site told me I could" arguments than with routeing guide ones.
It's certainly allowed on connections via Warrington, and I've used it on just the occasions you mention (missing the 6-minute Pendo connection from Preston) without problems.
