VTEC "225" (91 + Mk IV) set in reverse order?
7Pinza
15 Jun 2013
Retford
Noticed a VTEC set heading south yesterday with the 91 at southern end, and again heading north on Sunday afternoon (think it was 1S22 KX - Edinburgh).
Not sure of the number, just saw it flash by at a level crossing.
skyhigh
14 Sep 2014
Yes, I saw it at King's Cross on Saturday afternoon when I was waiting for my train. Unfortunately I don't make a habit of noting numbers so I couldn't tell you which set it was.
I'm sure it'll be turned soon, either at Edinburgh (round the 'Edinburgh suburban line' on an empty coaching stock movement [ECS]) or at Newcastle (you can head southbound by initially heading either west or east, using either bridge).
(I'm not sure if you are asking for the number or not? If you are, the place for that is: TOPS Request Thread)
signallerscot
20 Sep 2016
You'd be hard pushed to turn it on the sub; it isn't electrified. Turning is via the High Level bridge at Newcastle only.
7Pinza
15 Jun 2013
Retford
Just curious how it had turned, can't recall seeing one this way round in recent years. I know there's a few places it could happen.
Kite159
27 Jan 2014
West of Andover
If it is the same one I'm thinking of, it worked the 1705 Leeds to London Kings Cross yesterday afternoon.
ash39
8 Feb 2012
Apparently a few are running like this at the moment, hence so many sightings!
Most likely it went out of Newcastle via a different bridge to the one it arrived on.
800001
24 Oct 2015
Points problems this morning on the King Edward Bridge at Newcastle, therefore 4 or 5 services departed via High Level Bridge.
Sets to be turned again tonight on their return workings.
GW43125
8 Dec 2014
happens all the time - most obvious turning point: Newcastle
When there are Newcastle-Edinburgh shuttles due to Engineering they often turn the sets round-as some of us know coming in with first at the London end into Waverley platform 1, 2 or 7 is a bloody long walk!
route:oxford
1 Nov 2008
Maybe the train should always reverse direction at Newcastle so First Class is at the correct end at both Edinburgh and London?
Mag_seven
1 Sep 2014
here to eternity
The firsts are normally at the London end aren't they?
GW43125
8 Dec 2014
Exactly so why is it an issue with the poster concerned?
I was saying in the sense that when they are self-contained NCL-EDB shuttles they turn them so first is at the Edinburgh end as the London ends of Waverley platforms 1,2 and 7 are quite a walk to civilisation.
Kite159
27 Jan 2014
West of Andover
And then laugh when the service goes into either platform 19 or 20 so FC passengers have a long walk :lol:
Darandio
24 Feb 2007
Due to the layout, you can only reverse the set when going southbound.
Heading south, you can take the country end out over the high level bridge. Heading north, no matter which route you take around, you'll always face the same way.
Isn't it the other way round?
No. You come in from the north DVT first, change to 91 and go out over the high level, around the back and then head south.
I figured out what you meant - when you said north/south you meant the direction of movement on leaving Newcastle. Because you can arrive into Newcastle via the High Level Bridge as well - XC has at least one daily northbound service that does this.
GW43125
8 Dec 2014
It's not impossible- at times there seems no rhyme or reason to the platforming at Waverley :lol::lol:
GW43125
8 Dec 2014
Not sure how I didn't even consider that! :lol:
Ah well.
Put it down to tiredness. :P
If you really wanted to, I don't see why you couldn't turn an HST via the sub lines. For example: arrive at Waverley, reverse, round the sub, come out the north facing connection and continue north.
Coat collected.
Can and do. When the lines between Haymarket and Waverley are closed. Though most commonly they serve Haymarket as well so it only runs in reverse formation between Waverley and Haymarket.
Like Birmingham New Street, Newcastle Central station is on a west-east axis.
However you can only go north, towards Berwick, by heading east out of the station.
You can go anywhere else (ie. towards Durham & London, Hexham & Carlisle or Sunderland & Hartlepool) heading west (King Edward VII Bridge) or east (high level bridge)
http://www.openstreetmap.org/#map=16/54.9662/-1.6121
GW43125
8 Dec 2014
You learn something new every day. Which platform is it at Haymarket that's reversible now?
