Hi,
I just started in the railways 2 months ago. I am working in the system department running test over the equipment on the trackside in the victoria line.
I need to implement a program that runs while we are running the test and show what the train is actually finding on the track. So I thought a good idea was to use OpenBVE and simulate the route.
I have already designed the route with 4 stations, it's good enough (visually). But now, what I need is to run it but with inputs from the system, for example the position of the train.
Do you know if it's possible to run a route in openbve without a train? and tell the program to go though the route just using and external input as it could be the position of the virtual train?
Could it be possible also to run a non fixed route? I mean, the route has points and they could be normal or reverse, taking one route or another. Could we pass on the positions of the points to the program and run the virtual train from the starting station to the end of the route set.
Thank you very much. I would be very grateful if somebody could help me out.
