Uni Interview Problems
ChrisTheRef
15 Apr 2009
South Liverpool
I have two interviews coming up. Plymouth on Monday 1st Feb and Reading on Wendesday 3rd Feb.
Obviously it makes little sense to come back to Liverpool for Tuesday.
Can I go Liverpool > London > Plymouth > Reading > London > Liverpool on one ticket over the several days?
Many thanks in advance!
John @ home
1 Mar 2008
No. London is not a Permitted Route with a Liverpool Stations - Plymouth ticket. You would need more than one ticket.
OwlMan
25 Jun 2008
But it is valid on maps MW+WE
Which enables travel from Plymouth - Newbury - Reading - Birmingham - Liverpool
peter
tony_mac
25 Feb 2009
A Liverpool to Plymouth ticket is probably not permitted via London. (I haven't checked the maps, but there is no 'LONDON' in the list).
Runcorn to Plymouth does have a routeing of London. (this is not priced by Virgin, so you can't officially use a peak-time Virgin train with your Railcard, but I've no idea how you are supposed to know this!)
Do you have other plans when you are there? A Freedom of the South West may be of some use if you are doing other travelling.
A Liverpool to Swindon return would get you into the area, although it's significantly cheaper for 'not London', you could travel via Reading with this.
(Also, you can book the Holiday inn Express in Swindon at £55 for both nights - it's very close to the Station, and the 'Steam' attraction is nearby and worth visiting). Then you are in easy reach of Bath, Bristol, Penzance etc. with your Rover ticket.
There is a very useful ticket for this, and an excess that will allow you to do what you want. You have a PM.
ChrisTheRef
15 Apr 2009
South Liverpool
OK, solved the problem, but caused another.
My Plymouth interview has now been moved to 25/01 (this coming Monday)
The best I can do is £80!!
I'd also like to via London if possible, but will accept Bristol if it's much cheaper!
mathmo
28 Nov 2008
Splitting at Bristol would appear to take it down to £71.20, though I haven't checked much else.
A60K
26 Jun 2008
Kilburn
I expect that if the OP could drive then he would. As he's posted about making the journey by train, that seems like a rather unhelpful reply!
