johnnyp_360
Inspired by express sprinters 90mph running, what Class 170 Turbostar trains run at their top speed of 100mph? Or is their 100mph top speed just a future proofing thing?
Thanks
John
Thanks
John
The Brighton Mainline is cleared for 100mph and I'd hazard a guess the 377's reach it between London Bridge and East Croydon, so maybe the 171's do there? That'd be my guess, but, I know the 455 operated Tattenham fasts run down the fasts so maybe they have to stick to 75 mph.
Oh, and the 171's are allocated to Selhurst, so when the Brighton to Ashford units run back up the BML to South London, they must hit it then.
Oh, and another thought, when the ONE/NX ones used to come down to Liverpool Street. They must have hit it there.
(I know you said 170 before someone gets pedantic, but its the same unit really in this respect)
But as they had quite a bit of work coupled to 159s they would have often been limited to 90mph because of that.There was a time when South West Trains had it's 170s out on Waterloo - Salisbury - Exeter services, so there would have been plenty of 100mph line east of Basingstoke to work with.
Thanks
John
A couple of other examples where the Turbostars would have been maxed out frequently and consistently - on the ECML with Hull Trains, and on the MML under Midland Mainline.
Do any of the CrossCountry routes worked by 170s see any 100mph running?
Isn't there a stretch of 100mph track between Dundee and Aberdeen?
What's the line Between Norwich and Ely cleared for?
All Ipswich to Cambridge/Peterborough hit 100mph between Ipswich & Stowmarket. Following the over-running engineering works & mess up at Haughley the other morning a 5-car 170 combo worked a special from Ipswich to Liverpool St & then the 07.55 return to Norwich.
Ooh, any idea what units worked it?
Would be nice if the 2 car unit was 170270 then at least the liveries would match :P
Adam![]()
As others have said line speed between New Cross Gate and Norwood Jct is 60 on the slow and 70 on the fast. In the down direction it is a struggle to reach line speed on almost all stock because of the rising gradient up to Forest Hill, especially 455/456 where reaching 60 is rare, even taking full power. 171s can be a bit gutless too.
The 378s don't seem to be affected as much on this section ?
Nothing will get 60 between stations on the slow as they are too close together (can't renember getting 60 with a 377 on stoppers when I used to sign the road). Not between new x and forest hill anyway-may touch 60 between forest hill and Sydenham.
Where do you sign mate ?![]()
