Turbine powered trains
gsnedders
6 Sep 2015
[Apologies if this is the wrong forum, please move it if it is!]
As far as I'm aware, the only notable turbine powered train in recent years has been Bombardier's JetTrain, with very little happening after the period where both Britain (with the APT-E) and France (with the TGV 001) were seriously looking at turbine powered trains.
My understanding is that turbines, especially in combined cycle applications, are very efficient at constant speed, with two major downsides: they have horrendous fuel consumption at idle, and they're slow to respond to changes of power demand.
It seems like a perfect application for them would be combined with batteries to power traction motors: you run them as a generator motor to charge the batteries at a constant, efficient, speed, then turn them off until the batteries reach a certain level of charge. Given their low weight, even combined with batteries I'd expect them to weigh no more than a conventional diesel engine.
I'm sure I'm missing something here, given nobody has seriously considered doing this, as far as I'm aware. Anyone care to enlighten where I am miseducated? :)
theageofthetra
27 May 2012
Beckenham
I agree with you re running it at its most efficient rpm to charge batteries. The same applies to diesel engines- they can be incredibly efficient if running at their optimum rpm for long periods. Once whilst working on a river ship the captain wanted to increase speed by a knot or two to make a time slot on a lock. This required a call to the ships owner as the slightly higher speed meant that the engines were not operating at their optimum speed and the extra fuel costs would come to several thousand USD. If I recall the request was denied!
Emblematic
14 Aug 2013
Cost. Turbines in this power range cost $millions per unit. They make sense where either the high efficiency at full power pays back over time, so baseload power generation, CHP etc., or high power to weight \ size is critical, e.g. aircraft APUs. Low duty cycle or standby power generation, and airport ground power units (GPUs) are almost always reciprocating engines.
JetTrain had diesel engines for starting and low-speed use, employing the turbine for sustained high speeds. High locomotive and fuel costs were intended to be offset by savings in infrastructure (i.e. thousands of miles of OLE) for North American high speed services.
Batteries aren't cheap either, although getting cheaper all the time.
Peter Mugridge
8 Apr 2010
Epsom
SNCF ran a fleet of gas turbine powered trains from Paris St Lazare to various destinations in the north east of France via Evereaux between 1972 and 2004; as far as I know that was the only time this form of traction has been used long term on a fleet basis in commercial service.
They sold a few to Amtrak too, for the Hudson Valley routes out of Grand Central.
Union Pacific (I think) had a small fleet of gas turbine locomotives.
Phil.
10 Oct 2015
Penzance
Ah yes, the Turbo Trains. I remember getting one at Boulogne to Paris circa 1978. Horrendously noisy externally.
mark-h
14 Jan 2015
Gas Turbines have the advantage of being lightweight (for the power produced) which is an advantage for use in aircraft (especially as the power can be used more directly in an turbo-fan engine).
They are not as fuel efficient as piston engines unless the weight saving provides an offset.
Some marine examples of turbine issues:
The QM2 has both diesel and gas-turbine engines (the turbines being located towards the top of the ship due to their light weight and high air requirement) but the diesel engines are used most of the time with the turbines providing peak power.
Finnjet (built in 1977) was retrofitted with extra diesel-electric engines in 1981 to increase fuel efficiency at low speeds.
The high cost of fuel was one of the contributing factors towards the demise of the Stena HSS services.
gimmea50anyday
8 Jan 2013
Back Cab
In the UK the APT-E parked up in Shildon is gas turbine powered.
There was also GT3, which looked like a BR Standard Class 5 kettle with tender
Kentish Paul
25 Apr 2012
Ashford Kent
Yes they ran from the Hoverport station at Boulogne to Paris Nord. A trip from Dover to Paris all powered by gas turbines. This was 1988 and a memorable weekend followed. :p
randyrippley
21 Feb 2016
the reason turbines have never been used along with batteries in that way is that quite simply the battery technology hasn't been good enough. It may just be getting there now. Arguably for the power burst required at acceleration you'd be better off with a turbine/batttery/capacitor 3-way system as batteries aren't too keen on rapid discharges. Or a big flywheel, with all the safety issues that brings.....
Another possible problem is that after Leyland dropped production of gas turbines, I'm not sure if there's any suitable small-scale turbine suitable for distributed power applications commercially available. I guess you could bodge a helicopter turboshaft to work if you just wanted a pair of HST-style power cars.
randyrippley
21 Feb 2016
something thats just come back to me: the American turbo locomotives were only cost effective because (1) they ran long distances without stops (2) they burnt a cheap naphtha fraction byproduct that at the time couldn't be used for much else and was therefore a lot cheaper than diesel.
Changing oil processing technologies resulted in the naphtha fraction being used for other oil products and the price increasing, taking the turbine's advantage away. Given that the turbine is inherently less efficient than a diesel for most motive power work, the interest died.
apk55
7 Jul 2011
Altrincham
Modern Gas turbines can be more efficient than diesels on full load. However on part load the efficiency falls off very considerably and the idling fuel consumption is horrific compared to a diesel. Since many railway applications only require full power for short periods and most time is spent on part load or idling a diesel is much more efficient
RichmondCommu
23 Feb 2010
Richmond, London
They also ran from Gare du Nord for a short while in the late 1980's. I'm pretty sure that I caught one on a service to one of the Channel Ports but I certainly remember seeing them at Gare du Nord. From memory they had a different livery to the rest of the SNCF fleet.
Gas turbine hybrid?
It did occur to me that (possibly also for automotive applications) a small turbine that charges a battery that is actually used for traction could be a viable option, as it can, from startup to shutdown, run at maximum efficiency - something a turbine does very well, hence its success in aviation applications.
coppercapped
13 Sep 2015
Reading
I can see it now - a kerosene powered Dyson Airblade...;)
Emblematic
14 Aug 2013
Aviation is rather different, as power/weight is the dominant factor. A light, inefficient engine is better than a heavier, efficient engine as you have to provide lift, hence energy, for every kg you add. The extreme example is the APU, which isn't needed in flight at all but you can't really do without one. Once on the ground, it's replaced by a GPU cart as soon as possible, as it typically uses 30 times less fuel, as well as being much quieter.
Turbines alone aren't very efficient, but unlike IC engines they benefit from reprocessing recovered exhaust heat, so combined-cycle, CHP and recuperation can all be used as part of an efficient sŷstem.
There is research looking at microturbines for hybrid vehicles, for exactly the reason you mention that they can run, periodically at top efficienĉy, to range-extend a battery vehicle. It's more about using minimum space and weight, to allow more batteries and hence longer plug-in range, than efficiency of the turbine.
For rail, we don't really have the issues turbines solve. We don't need more power than we can generate with available diesels. We don't have a surfeit of cheap refinery residue (and even if we did, we wouldn't be allowed to fuel a turbine with it.) Weight and size isn't really a problem. And if we do want to use turbines, we can put them in buildings, use any fuel we like (gas, coal, biomass, nuclear) and connect them to the trains with wires.
gsnedders
6 Sep 2015
As I mentioned in the OP, I really am questioning about gas-turbine electrics with batteries (or some other energy storage means—though I doubt anything else is practical yet, given flywheels would have to be massive to allow you to run without the turbine for any length of time). I think it's quite clear cut from all the previous trains that have used turbines that running it without any sort of energy storage is simply infeasible given the performance and fuel consumption characteristics.
With regards to automotive applications: that was the original plan for the Jaguar C-X75, to run a pair of micro-turbines at maximum efficiency with batteries for storage. As far as I'm aware, the concept car and the development cars genuinely used micro-turbines, though the production version switched to an ICE before it was abandoned.
Undoubtedly cost is part of the issue—but it seems more viable for trains than it does for cars. The cost of turbines is a far smaller percentage of the cost of a train than even the projected cost of the C-X75 (c. 750k).
Hmm, I was assuming batteries were good enough nowadays given the Electrostar BEMU trial? There again, as the recent thread mentioned, there's not been that much said about the results.
There's plenty of turbines available, including the JetTrain's P&W ST40 and the Rolls Royce MT7—though really those are more suited dedicated power cars. There certainly are plenty of smaller turbines, though; I'm not entirely sure there are marine variants of them which would be the obvious basis for any rail engine, however.
