Trivia: Where tracks from traditional UK tramways still exist
Taunton
1 Aug 2013
We have had a recent discussion about new tramways following old on the same streets, but just how much of "traditional" tram tracks is still around and visible.
Start with a couple :-
- London, northern exit from Kingsway subway, including conduit slot.
- Salford, Hessel Street, down the west side of old Weaste depot.
- Manchester, Heaton Park, used as a heritage line, but the initial length may be even the original rails.
How much more left?
JD2168
11 Jul 2022
Sheffield
Firth Park roundabout in Sheffield, Tram tracks ran through the middle & are visible
Acathater
11 Dec 2025
NorthWest
Road surfacing may have removed it, but around three or four years ago in Liverpool there was still some tram rails crossing the roads around the Gladstone dock area, though I presume these were for "docklands" tramways rather than passenger carrying
Sun Chariot
16 Mar 2009
TrenHotel
31 Jul 2011
Tracks from the “tramatorium” in Charlton where London’s trams met their end are still in place:
One of the commenters says:
I researched the site for RB Greenwich in 2016 and can confirm these are the embedded tracks of a traverser that was installed to move the trams from the site entrance (off Woolwich Road) onto storage lines. The disposals took place between 2nd October 1950 and 29th January 1953 so were quite a local spectacle, one tram a week being stripped of its fittings and burnt.
izvor
11 Jun 2014
on the SER
How much more left?
Quite a lot I suspect! In many places it was cheaper just to tar over the tracks when the trams were abandoned, rather than laboriously dig them out. A century or so, and several layers of tarmac later, they will still be there, and periodically a full road reconstruction will reveal them again, to the delight of the local press.
I seem to recall reading that, in one or more Northern towns, the hidden tram tracks actually help prevent the roads from collapsing or subsiding into old mine workings.
Also many tram depots were converted into bus depots, some of which still remain with some track intact. @Sun Chariot mentioned Streatham Hill; another London one I can think of is Fulwell, which had them and may still have. The old depot site at Tonbridge Road, Maidstone still has them. Sure there must be others but I can't think of any more offhand.
BBF3
19 Oct 2018
Two bits of Torquay's tram system survive.
One at the site of the depot:
The harbour:img_1_1788935669391.jpg
Like this:
A bit of the track of the Burton and Ashby survives in the forecourt of the closed Ashby station. There are also track embedded in the cobbles between the approach to Temple Meads and the original Brunel building, which I think is tram rail but it may be for wagons.
Taunton
1 Aug 2013
It was indeed tram track; Bristol tram 8, a short route to The Centre, used it as a terminus spur.
Another is a very short piece of the old Edinburgh cable system, with centre cable slot, at the east end of Princes Street, which was a terminus of one of the cable lines. A road engineer, not understanding it was kept as a period piece, has recently painted roadmarking lines across it :(
vic-rijrode
31 Aug 2016
I live on a road which had double tram tracks used until the mid 1950s. Although nothing of the tracks is visible, there are suspicious cracks in the road surface which align almost perfectly with the position of the erstwhile rails. (I have photos of the trams trundling down the road).
I wonder if they are still there - slumbering, perchance to awaken and be used once again in a more enlightened era of public transport...
SargeNpton
19 Nov 2018
Inside the former Northampton Corporation tram sheds (which then became the Corporation's bus garage when the trams were withdrawn in 1934).
See attached pictures. That the rails run into the wall is due to a later partitioning of the building to create admin offices.
madannie77
12 May 2009
The Station Garden of Eden
There's a stretch of cobbled street complete with interlaced track preserved along Rugby Road in Portsmouth. See here: https://maps.app.goo.gl/GAW7bT2g3HWpNtPv9?g_st=aw
Another stretch in Portsmouth is on Broad Street:
There is a stretch of track opposite Chester Station on what was the approach road to Chester City Transport's depot until recently.
Taunton
1 Aug 2013
Quite likely. Some towns ripped up the tracks and rebuilt the substrata of the road, others just covered them with tarmac. The Tramways & Light Railways Act 1896 placed the responsibility for maintenance of the road surface around the tracks and for 18 inches either side on the tramway operator, not the relevant highways authority, which included dealing with this at abandonment, by which time of which almost all were run by the same local authority that did the roads, so they commonly took the cheap option then. Actually the steel rails form a useful reinforcement, with the road surface around them gently subsiding with traffic weight.
Some councils still divided the responsibility - I believe Glasgow maintained the separate arrangements for the tram system, which led to tram snowploughs and tram salt trailers for dealing with winter conditions (inevitably using old trams to do so) - and had substantial Permanent Way yards, which are essentially the civil engineer's department of the system.
The rails would be useless for current operations, corroded, wrong level, etc, and a considerable cost to rip out and replace. I think Manchester has encountered this multiple times as their system develops.
What I find fascinating about these surviving sections is how much history can be hidden in something as ordinary as a piece of track. It takes a bit of observation and logical thinking to distinguish genuinely original infrastructure from later restoration or reused rail. Heaton Park is a particularly good example—the original Manchester Corporation tram track was uncovered and incorporated into the heritage line.
When Greater Manchester did substantial road works in the 1970s on Eccles Road, before the current tramway, I think for the M602 Motorway, they unearthed the former substantial junction with Cross Lane, which had the only full tramway "Grand Union" junction ever in the UK, that is double tracks crossing at right angles, with double track connecting curves for all four quadrants. It had been under the tarmac since abandonment. The rails were all removed and given to the Crich tramway museum, who unfortunately do not seem to have relayed them. I remember them being all laid in a pile there from a youthful visit. It was a shame that the agreement didn't extend to the motorway contractor laying them.
JohnofWessex
3 Jan 2026
frome
The Tram Rail blown into the churchyard of St Mary Redcliffe in Bristol by the Blitz
AndrewE
9 Nov 2015
...the only full tramway "Grand Union" junction ever in the UK, that is double tracks crossing at right angles, with double track connecting curves for all four quadrants. It had been under the tarmac since abandonment. The rails were all removed and given to the Crich tramway museum, who unfortunately do not seem to have relayed them. I remember them being all laid in a pile there from a youthful visit. It was a shame that the agreement didn't extend to the motorway contractor laying them.
It is difficult to see where they might install it, given the area (width) of flat land needed for the side-arms to go to and Crich's quite constrained site...
Lloyds siding
3 Feb 2020
Merseyside
These were crossings from the local goods yards or links to the national rail network to the extensive dock railway system. There was still a signal gantry just inside the dock wall near Waterloo dock until about 10 years ago.
However, when Liverpool's tram network shut down in 1957, the tracks in roadways were merely tarmacked over in general, though a few were removed: 'In case they should be needed in the future'. This policy has been forgotten and tracks are now ripped out whenever resurfacing is done.
Acathater
11 Dec 2025
NorthWest
Presumably after 50 years the buried sleepers would be beyond further use?
Ziggy3legs
8 Jan 2026
Beeston
There's a small amount visible in Nottingham at the entrance into the Nottingham City Transport bus depot (formerly the Nottingham Corporation tram depot) on Upper Parliament Street opposite the National Ice Centre/Motorpoint Arena.
John Webb
5 Jun 2010
St Albans
duffield
31 Jul 2013
East Midlands
Bits of old tram tracks surface periodically in Nottingham:
Quote:
'100-year-old' tram tracks uncovered near Nottingham train station​
Tram tracks dating back about 100 years have been uncovered during work near to Nottingham's railway station.
The rails, which would have been part of the city's first network in the early 20th Century, are set to be removed later.
The story has a picture showing the dug up old tram tracks curving round outside the station entrance at the junction of Station Street and Carrington Street.
Zamalek
22 Jul 2021
Bristol
Gloucester Road Medical Centre in Bristol is built on the site of an old tram depot, and still has tramlines in the carpark.
Taunton
1 Aug 2013
This photo from 1959 shows tram tracks in Beresford Square, Woolwich, seven years after the last tram ran:
But were removed completely by the 1980s when the road was diverted - I'd moved from that area in 1977 so am not too certain exactly when.
They were still there in the mid-1980s when I first came to London, and in the absence of shops at Canary Wharf, we used to go via the ferry to Woolwich market on Saturdays, and I always used to deliberately stand on the tracks :)
John Webb
5 Jun 2010
St Albans
Interesting. After I left home my parents moved away to Lee in a 'down-size' so there was little reason to return to Woolwich. So I hardly ever went near it again until my mother moved into almshouses near to St Mary's Church until her death in 1999.
