"Trivia" Through stations with extremely few passenger trains which do not call
Shaw S Hunter
21 Apr 2016
Over The Hill
Waterloo East and London Bridge, with the latter only having one: 2L17 0826 Cannon Street - Dartford via Lewisham.
Back in the day most Hastings services, whether from Charing Cross or Cannon Street, didn't stop at London Bridge with next stop typically being Orpington or even Sevenoaks.
45Fox
17 May 2022
Leicester
A good example, although as you know nowadays everything in the WTT does stop there, but during engineering some do run through non stop, for example upcoming XC Diverts and the odd EMR (one of which I did from Derby to Bedford with no stops)
We've had Hull Trains diversions on occasional weekends over the last few years as well, all non-stoppers.
LNER had one of their Hitachi units through a week or so back too, gauging tests in connection with possible future diversions.
A S Leib
9 Sep 2018
Lancaster's skipped by two Glasgow – West Midlands – Euston services, the Caledonian Sleeper(s) and Lumo, with everything else calling.
Swindon (everything calls except 2 tpd from Paddington to Swansea / Carmarthen and Lumo Carmarthen services when / if they start, and the Night Riviera when diverted there).
Weston-super-Mare (one CrossCountry service in each direction) and Northampton (a late night Manchester to Euston) are cases of the only passenger services passing through being ones which I suspect are to keep route knowledge.
Banbury (skipped by five CrossCountry services on the Reading to York / Newcastle route).
Brockenhurst (two morning London-bound and four evening Weymouth South Western services don't call).
Colchester and Manningtree (08:00 Norwich to Liverpool Street and 17:00 return).
Iskra
11 Jun 2014
West Riding
Wakefield Westgate, I don't think it has any anymore. There was possibly one at one point not too long ago.
Skipton, Barrow, Whitehaven, Workington and Carnforth too I imagine.
A S Leib
9 Sep 2018
Exeter St Davids and Plymouth have pretty much everything, even almost every railtour calls here. The closest Exeter SD comes to being skipped is the 12:03 Paddington-Penzance being pickup only here on an otherwise non-stop leg.
Similarly, Taunton has everything except the 10:03 and 12:03 from Paddington.
Zomboid
2 Apr 2025
Oxford
Andover? Certainly a few years back there was an XC route knowledge special that was non-stop Basingstoke to Southampton that way but everything that called. Romsey would be similar.
The exile
31 Mar 2010
Somerset
Just to be clear, the qualification is that there has to be a minimum of 1 train that’s booked to pass through non-stop? Otherwise there must be loads.
pokemonsuper9
20 Dec 2022
Greater Manchester
At Hag Fold there are normally 2 trains per hour during the day that stop, with only a few not:
The ex-05:34 from Manchester, the 12:20 from Blackburn (which also skips Hindley), and the 20:16 from Leeds (which also skips Hindley)
The 12:20 from Blackburn is followed closely behind by a freight train which needs to use the single line section towards Headbolt Lane which it can't do until the train has reached Rainford on its journey back.
To reach Hag Fold from it it's only a short double back via Daisy Hill.
And Hindley (normally 4 trains per hour during the day) is only skipped by the two mentioned above.
Indeed, although I did pass through Waterloo East non stop when it was closed for a security alert once I think.
Yes, it's amazing to think, given what an important interchange its become.
GordonT
26 May 2018
Yes as you say, but may also include stations which see passenger trains passing through non-stop on an established diversionary route from their booked route and where everything else stops.
The exile
31 Mar 2010
Somerset
In which case - Bath Spa. Non-stop on diversions only.
Jim
11 Jun 2005
Wick
Gatwick Airport.
Only the Coast <> London Bridge Southern commuter services run non stop.
The exile
31 Mar 2010
Somerset
1K71 0510 Bristol Temple Meads to London Paddington skips Bath Spa. Runs nonstop Bristol to Bradford on Avon.
Whoops - missed that one. Even I am not usually up at that time!
Obviously there would be precious little point in stopping - the Pompey running just ahead of it serves the intermediates to Westbury and the next London will be in Reading ages before it. Stopping at Bath on the off chance that there’s someone there at 05.20 who needs a through service to one of the Kennett Valley stations would be a waste of brake-blocks. (Yes, I know….)
ETMbloke
15 Sep 2025
Somewhere in the south
Godalming, looks like only the first train down from Guildford doesn't call there.
Not bad when years ago when it was 4 trains per hour off peak on the Portsmouth Direct, only two stopped there.
GordonT
26 May 2018
Would Crewe be a candidate? At least at one time you had maybe one train a day from Euston which was first stop Warrington.
SECR 65
2 Apr 2026
East Sussex
I'm not very familiar with the station, but from the RailCam camera, it seems there are ~2tph non-stop with Avanti
swaldman
19 Jan 2013
Unless I misunderstand the question, I'm going to answer "Every station on a lot of commuter lines".
GordonT
26 May 2018
Yes perhaps I should have some kind of additional clause to exclude "peak-time fasts". I was brought up in Helensburgh at a time when there was an 0810 Limited Stop train for Glasgow commuters with 9am starts and also the "Bowler Hat Express" at 0829 for those whose arrival time at work had a bit more leeway.
These were additional to the normal half-hourly service and no longer exist as the half-hourly service contains the demand.
Mcr Warrior
8 Jan 2009
Several of those each & every day, Avanti trains between London Euston and Glasgow Central, first stop = Warrington Bank Quay.
