TRIVIA - Non-terminal stations where every passenger train stops
61653 HTAFC
18 Dec 2012
Though it does have 5 terminating services an hour, all other passenger services through Huddersfield stop (diverted South TPE services excepted). Under plans for 6tph, 2 of those terminating services will be withdrawn.
Dai Corner
20 Jul 2015
Newport (South Wales) just misses if we're using the stricter criteria as the 0658 from Pembroke Dock terminates at 1035 and returns as the 1040 to Fishguard Harbour.
There are also starters / terminators to/from Ebbw Vale during engineering works and Cariff Central on big match days. There may also be some non-stoppers on those days but I haven't checked.
Richard_B
13 Apr 2016
0518 Bristol Temple Meads to London Paddington via Westbury does indeed pass through Bath Spa without calling.
0705 Wolverhampton to London Euston passes through both Birmingham International and Coventry without calling.
And as Cherry Picker says, 0609 Kidderminster to London Marylebone passes through Banbury without calling.
There are a handful of Chiltern services which don't stop at Banbury.
Ah fair enough.
Think Derby is one that hasn't been mentioned.
L+Y
4 Jul 2011
Croston, Rufford, Burscough Junction, Parbold, Burscough Bridge
christhebull
13 Oct 2014
Haslemere must surely be one as this is where passengers change between fast and stopping services to Portsmouth, the only passenger trains I am aware of that pass without stopping are occasional XC diversions.
TrenHotel
31 Jul 2011
Lewisham.
(Some trains avoid Lewisham, but I can't think of any that pass through without stopping.)
Parallel
9 Dec 2013
Dorchester South/West, Bournemouth, Honiton, Exeter St. Davids/Central, Salisbury and possibly Wareham and Brockenhurst
iirc, Honiton, Dorchester and Maiden Newton have no terminating services.
Honiton has an early evening terminating service from Exeter St David's with SWT.
Shrewsbury, Welshpool, Newtown, Caersws, Machynlleth, Dyfi Junction, Borth, Aberdovey, Towyn, Barmouth, Harlech.............................
There is a service from Machynlleth (Departs 18:00) to Aberystwyth that misses Dovey Junction and Borth.
Bevan Price
22 Apr 2010
The above highlighted, Llandudno Junction and Chester both have bay platforms and trains that terminate there.
Bangor doesn't have a bay platform in use but does have trains terminating there.
I suppose it all depends on what we describe as a terminus. I think that many people might regard a terminus as somewhere where through running is impossible, e.g. London Euston, Charing Cross, Victoria, etc. , and that the presence of bay platforms is not sufficient for the whole station to be classed as a terminus if through running is also possible.
IKB
15 Nov 2013
Streatham Hill
Streatham
East Dulwich
North Dulwich
Birkbeck (one of the least used stations in London)
Leatherhead
RichmondCommu
23 Feb 2010
Richmond, London
Refer to post no. 8 :)
Derby has terminating services from Crewe.
Hmm I thought we were only asked to exclude termini and last time I traveled to Derby it wasn't a termini (although of course it does have a bay platform).
Also, for what its worth some trains from St Pancras also terminate at Derby.
bb21
Emeritus Moderator
4 Feb 2010
Streatham Hill
Streatham
East Dulwich
North Dulwich
Leatherhead
http://www.realtimetrains.co.uk/train/G73645/2016/12/01/advanced rules Streatham out.
http://www.realtimetrains.co.uk/train/W72903/2016/12/01/advanced rules out Leatherhead.
Lewisham.
Quite a few, for example, http://www.realtimetrains.co.uk/train/W47010/2016/12/01/advanced
Coleshill Parkway? And excluding engineering works Oakham and Melton Mowbray where every passenger service stops
Coleshill is missed by quite a few XC trains each day.
Melton Mowbray is disqualified due to the 1800 ex-STP. (Not sure who came up with this rule.)
hassaanhc
5 Jan 2014
Southall
Hounslow and Brentford have all services call there. The other stations on the Hounslow Loop miss out thanks to the 1723 and 1753 Reading to Waterloo on weekdays.
Some services in the morning do start from Hounslow, none are booked to terminate there since the weekdays 0737 Waterloo to Hounslow was extended back to Waterloo via Richmond.
DarloRich
Fenny Stratford
there will be loads on every branch line in the country - every intermediate station on the Marston Vale line or the Bishop Auckland branch for examples
anti-pacer
5 Jun 2013
I'm confused as some have and others haven't. Maybe some clarity is needed as to what we are including.
Kite159
27 Jan 2014
West of Andover
Disqualified due to the "no terminating trains" rule (which also rules Winchester out as there is a Southampton - Winchester service in the afternoon)
The Thameslink Bedfords are routed East Croydon>Norwood>Crystal Palace>Tulse Hill. RTT must be wrong as I'm not aware of any that go via Streatham Common and Streatham.
Most likely those trains are pathed via Streatham due to paths via Crystal Palace.
NSE
3 Mar 2010
No, some get routed via Streatham Common. I was on one the other week that did. It has happened a couple of times. Wether or not that's planned or just because of delays or engineering works I don't know.
kevjs
4 Sep 2013
As do some trains from Nottingham - The evening Merdian/HSTs from Nottingham to Derby are a bit overkill on the capacity front... (I assume they are ex-St Pancras effectively doing a stock move to Etches Park via Derby).
Does anything travel through Nottingham without stopping?
Nippy
13 Aug 2013
Disqualified due to the "no terminating trains" rule (which also rules Winchester out as there is a Southampton - Winchester service in the afternoon).
Your rule though? As far as I can see, the OP hasn't been back and confirmed that yet.
Castle Cary
3 Sep 2015
Yes - that confused me, too. So - I resubmit Frome!!! Westbury I exclude because from time to time there have been Southern services that were fast from Warminster to Trowbridge. I am not sure of the current situation.
Regular peak trains on the Bexleyheath line from CX pass Lewisham non stop. They used to be first stop Kidbrook, but I think that it is now Blackheath.
Kite159
27 Jan 2014
West of Andover
Westbury is excluded due to the Saturday 06:08 Bristol to Plymouth XC running nonstop from Bristol to Taunton via Bath & Westbury (passes around 06:39)
Clansman
4 Jan 2016
Stirling, Perth, Dundee
All of which are majority through stations, but each have bays and regular terminating services daily.
Edinburgh Haymarket is one as well
SpacePhoenix
18 Mar 2014
Dorchester South is one on the SWML, possibly Southampton Airport Parkway as well
