Trivia: longest services to call at no two consecutive stations
24 Sep 2017
What is the longest service to call at no two consecutive stations along its route? In other words, it must pass through a station non-stop between each of its calls. Length can be either by distance, or number of stops (the latter is perhaps more interesting).
For example, the fast Kings Cross to Edinburgh services count, they pass through a station between each stop. The ones that continue beyond Edinburgh don’t, as they call at Edinburgh and Haymarket. What about for each region around the country?
The exile
31 Mar 2010
Somerset
Were it not for Totnes and Newton Abbot then I suspect Plymouth - Edinburgh would be a good call. Or do they really ruin it by stopping at Teignmouth as well?
Mcr Warrior
8 Jan 2009
Was also thinking of Lumo's typical service provision, (calling pattern), i.e. London King's Cross, Stevenage (sometimes), Newcastle, Morpeth and Edinburgh.
So what's that? Nearly 400 miles?
Doubt there's anything further on the entire GB network.
Kite159
27 Jan 2014
West of Andover
WCML side, something like an Euston to Liverpool (especially since they no longer call at Stafford). Or one of the Euston - Manchester services which go via Stoke.
Midland Main Line - St Pancras to Sheffield on a fast service (Leicester, Derby, chesterfield only).
Although neither are nearly as long as the ECML examples (either Lumo or the fast King's Cross - Edinburgh services)
Segedunum
International Transport
22 Dec 2013
Up North
Sheffield and Chesterfield (it was Newcastle Readings that skipped Chesterfield), Leeds and Wakefield Westgate
Dronfield is between Sheffield and Chesterfield, and Outwood is between Leeds and Wakefield Westgate.
The exile
31 Mar 2010
Somerset
True - I’d forgotten them!
Cheating, but do Brussels Eurostars still pass through the platforms at Vorst Zuid?
xotGD
4 Feb 2017
The King's Cross - Edinburgh example is beaten by the Sleeper from Euston.
24 Sep 2017
There‘s also Exeter St David’s, Tiverton Parkway, Taunton. But something XC starting from Bristol is ok on the southern end, annoyingly leaving just Darlington, Durham.
A S Leib
9 Sep 2018
I thought the Heart of Wales line could work if you counted request stops as not stopping but Gowerton, Llanelli, Pantyffynnon, Ammanford and Llandybie are examples of consecutive non-request stops even if you did count request stops.
Northampton
They pass on unplatformed fast lines at both Ruisbroek and Vorst Zuid, according to http://www.sporenplan.nl/ so I guess it counts (as all non-stop trains on HS lines use unplatformed lines when bypassing stations). The Amsterdam services would also therefore feature, as they pass through Brussels Central and North between Brussels and Rotterdam and through Schiphol between Rotterdam and Amsterdam.
