Trivia: Local bus services that use bypasses
P Binnersley
30 Dec 2018
In Birmingham the X3/4/5/15 (Nation Express) and 110 (Arriva) use the A38(M) "Aston Expressway" to bypass Aston.
Dai Corner
20 Jul 2015
Stagcoach x3 cardiff to Abergavenny by pass newport
Newport bus x30 newport to cardiff
Actually the X3 does stop in Newport, but in Malpas not the city centre.
Stagecoach X24 and Anslow's 24X use the A4042 and don't stop between Newport and the outskirts of Cwmbran.
Stagecoach X15 uses the A467 Rogerstone bypass.
DunsBus
12 Jan 2013
Duns
Borders Buses 253 and East Coast Buses X7 both use the A1 Tranent and Musselburgh bypasses.
Cambus731
19 Jul 2013
Chelmsford
First Essex C9 route between Chelmsford City centre and Beaulieu via North Springfield uses the Chelmer Valley Road which is an inner relief route constructed in the late 80s to by pass Broomfield Road, Broomfield itself and most of Springfield. This gives the residents of Beaulieu and North Springfield a fast route to the city centre
liamf656
2 Aug 2020
Derby
This thread is going to be very long very quickly, but I’ll stick to my own local routes
Trent Barton:
Ilkeston Flyer - bypasses Chaddesden on the A52
Nines - bypasses Little Eaton on the A38
Sixes 6.X - bypasses Little Eaton on the A38
Skylink Express - bypasses Barton and Thrumpton on the A453
Threes A/B - bypasses Newstead on the A611
X38 - runs non stop between Derby and Burton via the A38
Diamond Bus East Midlands
401 - uses the A50 in various parts
X12 - runs non stop between Burton and Lichfield via the A38
Vectare
90 - runs between Bingham and Newark with a few deviations, using the A46
High Peak
199 - runs between Manchester Airport and Stockport via the M56
Transpeak - bypasses a few villages on the A6
Stagecoach
X17 - runs between Barnsley and Meadowhall on the M1
Deerfold
26 Nov 2009
Trent Barton:
Skylink Nottingham uses part of Bye Pass Road, which seems to bypass Chilwell High Street. It also avoids Beeston Town Centre that its predecessors used by going along Queens Road.
Trainguy34
29 Apr 2023
Kent
Stagecoach South East 89s sometimes skip Bridge using the A2, mainly from 3pm - 5pm
liamf656
2 Aug 2020
Derby
61653 HTAFC
18 Dec 2012
There was in Yorkshire Rider days an X37 that used the bypass, came off to serve Elland town centre and then came back on to continue it's journey.
There was also an X36 which may have stayed on the bypass and missed Elland.
Back to today, Keighley Bus Company 862 runs via the Aire Valley Road between Keighley and Silsden while the 60 uses it between Keighley and Crossflatts and between Bingley and Cottingley.
The X36 did use Elland bypass from end to end. It lasted way longer than the X37.
Ossett is an oddity which has had two bypasses. The first has since been swallowed by expansion of the town, leading to a more substantial dual carriageway bypass being built. I'm not aware of any bus routes that use the current bypass but the Arriva 268 (among others) uses the old bypass rather than serving the town centre and bus station.
LOL The Irony
29 Jul 2017
Chinatown, New York
The 89 Knutsford - Northwich uses the A556 between Northwich Road and Pickmere Lane. It's predecessor, the 289, used significantly more of the bypass.
Deerfold
26 Nov 2009
liamf656
2 Aug 2020
Derby
Yes, you'd already said that in the message I replied to (and it's not an unknown route to me)..
I was adding another trentbarton route to those you'd listed.
D’oh! I thought you were telling me I was wrong in my first message :oops:
SCH117X
27 Nov 2015
A section of the A61 Ripon bypass is used by local services RS2 and RS3. Other services may use it in part as they are timetabled at the bus station and then a village where the logical route would be to use the bypass:
Dales & District 136 to Melmerby Business Park
North Yorkshire Council 147 & 150 to Thirsk
SCH117X
27 Nov 2015
Also Connexions X1B uses part of the A658 *Harrogate southern bypass" at Knaresborough between the B6164 and A59.
fisher2511
23 Aug 2014
Stagecoach 585 between Ayr and Largs uses both the Loans bypass and the Kilwinning bypass.
Statto
8 Feb 2011
At home or at the pub
A10 Heathrow - Uxbridge uses the M4 between Heathrow North & M4 Junction 4
X6 Bradford - Leeds uses the Stanningley By Pass
508 Halifax - Leeds uses the Stanningley By Pass
plugwash
29 May 2015
I've seen serveral buses in the Greater Manchester area that run as normal local stopping buses for parts of their route, but also have sections where they run non-stop along fast segregated roads/motorways.
Examples include the 199 skyline (runs as a regular bus from Buxton to Stockport, then hops on the motorway to the airport), the x41 red express which runs with very few stops from Manchester to a motorway junction east of Summerseat, I presume running along the motorways, then turns into a regular stopping bus and the x43 Witchway which seems to run as a regular stopping bus from Manchester to Prestwich, then run non-stop along motorways/segregated dual carriageways to Rawtenstall then it seems to become a regular stopping bus again from Rawtenstall to Burnley.
Welshman
11 Mar 2010
Arriva in North Wales routes a handful of buses of its Service 12 Rhyl-Llandudno via part of the A55 Expressway. They join at Pensarn and leave at Llandulas and vv. It's only a short section, and simply avoids the centre of Abergele and Tescos.
Given the number X12, the westbound is a positioning move to Colwyn Bay for a service back to Rhyl at 5.50am in the morning, and eastbound there are a couple of journeys around 6pm virtually empty stock back to the depot in Rhyl, as the whole service is provided by buses from Rhyl depot.
The evening return services could be quicker if they used more of the A55, but I once did an X12 from Llandudno to Rhyl depot in 45 minutes, where the driver was keen to finish work and had a rather cavalier attitude to timing points in between!
Also in North Wales, the T2 uses the Y Felinheli bypass between Bangor and Caernarfon, leaving the 5C to trundle the old route. That bus also uses part of the Dolgellau by pass to reach the stop in Eldon Square. Were it running 60 years ago, it would have been along the tracks through Dolgellau station - literally a rail-replacement service!
