(Trivia) Examples of splits and joins
D6975
26 Nov 2009
Bristol
I am not aware of any. In the new timetable the 1L60 19:20 Waterloo to Exeter leaves WAT with three units, one is datached at Salisbury and a second at Yeovil Jn, but it only goes to a single destination.
Back in 2010 the third unit detached at Salisbury used to go to Bristol, I travelled on it once all the way from Waterloo (the fare was ridiculously cheap at the time compared to PAD-BRI)
Big Jumby 74
12 Feb 2022
That's correct, the 1220 was 6 to Ex/3 to Bristol Temple Meads (BRI) for a time.
Loathe to wander OT, but just to say as the service pattern was tweaked here and there over the years.
A number of unit diagram changes took place, and with the passage of time I can't recall the sequence of events.
The diagram that was designed to get the allocated exam unit back to depot at a specific time each night did itself change in detail on occasions, even being part of a shunt move involving three units in Clapham Yard between the peaks - a part of the plan that wasn't done lightly, due to the risk of disrupting said diagram - but the nature of the timetable/diagram working at the time, left no other cost effective option.
Sorry for veering OT.
wimbledonpete
25 Nov 2011
M-F the 08.35 from Ramsgate to Charing Cross via Folkestone gets to Ashford at 08.51 and waits for another portion from Faversham via Ramsgate and Canterbury to arrive at 08.56 before coupling up and leaving at 09.00.
The 09.41 from Ashford to St Pancras is formed of the rear six coaches of a 12 coach ECS from STP that arrives at 0926 - the front six detach and scuttle off to the sidings allowing another six coaches from the Canterbury line to couple up to the (now front) six at around 09.35.
pokemonsuper9
20 Dec 2022
Greater Manchester
AndyNLondon
20 Jan 2014
Regular services between London Victoria and Bognor/Portsmouth split/join at Horsham e.g.
A possible oddity with these London to Bognor Regis/Portsmouth services is that after they split at Horsham, both portions then call at Barnham. I've had a fun "are we in the right bit of this train" moment on one of those: 12 carriages from Victoria, front 4 to Portsmouth and rear 8 to Bognor, and we were going to Arundel which has short platforms. So we needed to be in the front half of the rear (Bognor) portion, i.e. in the middle third of the train when boarding at Victoria.
D6130
12 Jan 2021
West Yorkshire/Tuscany
Why do those trains now divide at Horsham instead of at Barnham, where they always used to traditionally?
Magdalia
1 Jan 2022
The Fens
The Portsmouth portions are non-stop between Horsham and Barnham, only the Bognor portions call at the Arun Valley stations.
RailWonderer
25 Jul 2018
All around the network
The Liverpool Norwich still splits and joins in service. The rear half detaches at Nottingham and the front half continues to Norwich but only at certain hours of the day.
The exile
31 Mar 2010
Somerset
There are a few GWR local services and Cardiff-Portsmouth services which add or detach portions at Bristol Temple Meads. Confusingly they also reverse there so which is front and back portion is not obvious.
Sticking with Temple Meads, the ecs for XC’s 08.00 Manchester and 08.12 Paignton departures arrives coupled and is split “at platform”. As a result, both departures are shown as Platform 4, though 90% of the Manchester train is on 3. Cue someone (nearly) boarding the wrong train (nearly) every morning.
GW43125
8 Dec 2014
EMR are exceptionally good at Calling a Sheffield and Nottingham (which depart 3 minutes apart) on the same platform at the same time with no real indication that the Sheffield train is outside...
Busman
4 Mar 2017
A question about splitting services ...
I'll use an example of one I use well on a daily basis, the Caterham to Tattenham Corner service at Purley.
What I am interested in is this, if either the Caterham / Tattenham Corner unit has an operational failure on the respective branch lines towards London does the single unit of the other branch continue to London or does it get cancelled as well?
Credit to Southern because the very fact I'm asking this question is that it hasn't happened once over the last 8 years I've been using it. And that includes a number of Saturday's too.
mm333
28 Aug 2008
53.8331°N 1.7734°W
I noticed today that Leeds has its only 2 destination service. The 1611 southbound XC splits at Gloucester with one portion going to Plymouth and one going to Cardiff.
XC often split at Bristol Temple Meads with one half going south-east and one half going no further.
NSE
3 Mar 2010
Every effort will be made to get a level of service run. So if it’s 4 cars vice 8, that’ll still run. Unless, using Purley as an example, it’s the front unit that arrives off the Caterham branch that promptly fails and then blocks the healthy Tattenham one from moving, then you’re sort of knackered regardless.
Busman
4 Mar 2017
The irony of the above question earlier today weirdly semi-backed up what happens.
The 23:40 from London Bridge was only 5 carriages (usually 10 - 5 to Tattenham Corner and 5 to Caterham, split at Purley), however, the usual 10 was only 5 as stated above but the automated PA system stated front 5 to Caterham / rear 5 to Tattenham Corner.
Turns out the single 5 units is only running as far as Purley irrespective of where this unit would have originally ended.
So, bizarrely, after the original question asking something that hasn't happened to me for 8 years finally happens on the day I ask the question.
Very bizarre.
Very bizarre.
Very bizarre.
Although I should add, the above is the opposite of the original question I was asking.
Thanks to member NSE for the original explanation.
m0ffy
24 May 2022
Leicestershire
Do LNR services still split at Northampton, sending one train towards Birmingham New Street and another up the Trent Valley to Crewe?
61653 HTAFC
18 Dec 2012
It's going back over ten years now so my memory is a little foggy, but I'm pretty sure I used a Southern service which split three ways in around 2012/13. Can't recall exactly where the splits happened but I was travelling to Hove (then Brighton on the shuttle) and needed to be in the correct portion of the 12-car unit from Victoria. Think the portion I needed was for Littlehampton, but can't recall where the other portions went- one may have been Eastbourne.
On the question of services that join and then split again en-route, I think that there has in the past been services on the Cambrian that joined at Shrewsbury (portions from Chester and Birmingham) then split again at Machynlleth (for Aberystwyth and Pwllheli). I think this was in Arriva days.
NSE
3 Mar 2010
To my knowledge (which is pretty good with Southern operations), the only three way splitters were Victoria to Redhill, which then split into Reigate/Tonbridge/Horsham. The only other one that is sort of a three way split, was the Victoria to Littlehampton and Ore, which split at Haywards Heath, but then during the evening peak (and possibly just late at night) dropped off four coaches at Eastbourne. So if you were going to Hove, you may have to have been in the front or rear four. Bit more tricky when you wanted Ore and you had to be in 5,6,7 & 8 as 1-4 were dropped at Eastbourne and 9-12 carried on to Littlehampton.
I wouldn’t be surprised to know something similar existed where 12 coaches went to Haywards Heath, four came off for a run to the East Coastway, four went fast to Brighton and four carried on via Hove. An example, but something like that could have easily existed near the end of service only a Friday or something.
61653 HTAFC
18 Dec 2012
Thanks- as I said, my memory is somewhat hazy. It was an evening peak service, so it was probably Littlehampton/Eastbourne/Ore- so not a true 3-way split, just one of the portions dropped off at Eastbourne. The split being at Haywards Heath definitely rings a bell.
Deepgreen
12 Jun 2013
Gomshall, Surrey
When I used to commute via Redhill, I often caught a train that split into three there - with Tonbridge, Gatwick and Reigate portions. It no longer runs.
WAB
27 Jun 2015
Anglia
Comes from Swansea and... Swansea!
Each portion arrives on different platforms at Cardiff Central, so I have my doubts that this train actually joins…
pokemonsuper9
20 Dec 2022
Greater Manchester
