DelW
- Joined
- 15 Jan 2015
- Messages
- 6,051
Yes, possibly more suitable, IIRC the M25 is officially titled London Orbital Motorway."Orbital" is another commonly-used description I believe.
Quite! Loads of people walk from the station to their place of work in London.Indeed! Many people walk over a mile from their London station of choice to get to their place of work, because it is usually quicker (and obviously cheaper) then using the tube or bus.
I've regularly walked from Kings Cross to Islington (nice walk along the canal), Camden, Holborn, Marylebone areas.Kings Cross from a percentage perspective has to be low surely?
A fair chunk of people on the local lines have direct trains on Thameslink, and to Finsbury Park and Moorgate which are closer the main job hubs.
Intercity traffic is more likely to just go straight down into the tube and/or straight into St Pancras next door (do these count?) since Kings Cross isn't exactly the tourist hot spot.
It's less than a 15 minute walk if you know where you're going.Just curious but why would you walk to Euston Square from Kings Cross? Seems a bit of a mission when you could just go from Kings Cross Underground direct.
By the time you've got to the Underground platforms, waited a couple of minutes, minute or two running time, got out at the other end then walked to your final destination the time saving is marginal. And it's £3.10 each way on PAYG at peak times and £3.00 off peak.
I agree. Lots of people walk to and from London termini: take a look at Westminster, Hungerford, Waterloo and London Bridges during the rush hour. I commuted to Waterloo or Vauxhall for all my working life, except for two years, and always walked to my workplaces, except in heavy rain when I'd take the bus. I spent seven years at university in Bloomsbury, and usually walked from Waterloo if the weather was reasonable, and it was usually quicker than going by bus.Only someone called the Northern could say this!
All London terminals have large numbers of commuters who walk to and from their place of work, especially those in the City or near to Whitehall and Westminster. Even the terminal stations on the north side of central London have lots of destinations that are within walking distance.
10% - god no!Yeah learnt something today from KGX, generally thought it would've been like down the 10% levels for people going out of it but guess there is more.
A 15 minute walk is a mission?Just curious but why would you walk to Euston Square from Kings Cross? Seems a bit of a mission when you could just go from Kings Cross Underground direct.
No longer possible but a way to give yourself some peace and quiet from annoying visitors: take your leave from them outside Temple station, having armed them with a tube map, and say you’ll meet them at Aldwych!There is an odd mentality in London among tourists, though, of seeing it as a load of unconnected islands connected only by Tube - see people getting the Tube from Leicester Square to Covent Garden - those people might be surprised how easily walkable it is on the surface!
I don't think this is restricted to London mind. I think most cities with a metro map have tourists taking metro journeys when walking could be quicker or around the same amount of time.There is an odd mentality in London among tourists, though, of seeing it as a load of unconnected islands connected only by Tube - see people getting the Tube from Leicester Square to Covent Garden - those people might be surprised how easily walkable it is on the surface!
Where did I mention walking to Euston Square from Kings Cross?!!
I have however often walked between Euston and St Pancras International, this being the simplest and quickest way.
Sometimes I walk or cycle between stations instead of taking the Tube because I just want some "fresh" air or a bit of exercise or to grab a bite from that falafel stand outside the college of GPs. There's also a reasonable level of walking involved in going from KX NR platforms to the Underground platforms.
I walk between Euston and Paddington (and vice versa). A nice walk and definitely preferable to the tube.I have certainly walked from and to Euston many times, thanks to the location of Euston Square station....
Well... it ain't Cumbria that's for sure! It's interesting for the contrast (plus you can avoid the A501 for at least part of the way via side streets and Regents Park).Horses for courses, I guess. All that traffic along the A501 isn't my cup of tea, but there you go!![]()
I misread the post, was a long day yesterday.
The best way Esuton to Paddington is to go a block or two south of the Euston Rd. Lovely part of London and really quiet!
Walking to/from Ebbsfleet International is common when Ebbsfleet United are at home.I once walked out of Ebbsfleet International, I don't remember there being many others.
More people than usual also access the station by busMitcham Junction is an interesting one - there's not a lot around there. However, latest data says 408K entries and exits, but also lists interchanges as '0' so clearly doesn't take into account that most of the entries and exits are likely to be passengers changing from Tramlink to the rail network and vice versa.
