trentbarton discussion
cnjb8
26 Feb 2019
That deckers are more expensive to buy, to operate, more prone to vandalism, have longer dwell times at stops and that passenger growth should be accommodated by better service frequencies. That has been their reasoning.
Also they want passengers to be able to see the driver at all times, bit strange
Hyebone
29 Jan 2024
Chesterfield, Derbyshire.
According to an ex-Kinchbus driver pal of mine, it was all part of a customer survey, apparently passengers preferred to be able to see the driver.
Also you'll notice that the Ticketer machines Wellglade have, the card scanner unit and the ticket printer are on opposite sides to what is standard elsewhere with other operators. Apparently the driver handing the ticket to the customer instead of the customer taking it from the machine is better customer service?
Davidsb3
16 Apr 2019
Derby, UK
I was fascinated to note that Comet branded Volvo 748 had its latest MOT test at Arriva Midlands and that bus had clocked up over 1 million miles . No wonder it is "tired". But do you really want Enviro 200MMCs on it? But as you drive them, did they ever fix those roof panels near the front, that looked like they were going to fall off and hit someone?
Maybe it depends upon how many times someone opens the windows. Aircon doesn't work too well with windows open....
Most if not all the drivers do not want ADLs on the route as we dont think they would last very long with how bad some of the roads are on te route plus the awful amount of steering lock you get on them but at the end of the day we will drive what we get given. Those panels are secure even they dont look like it.
Trainman40083
29 Jan 2024
Derby
That roof panel always looked like it would come down and smack you in the face. Let's say I didn't stand under it. So, if the drivers all think that, it will be ADLs then. ;) After all, I don't see anything else. They might disappear in a pothole at Alfreton bus station.
Hyebone
29 Jan 2024
with how bad some of the roads are on the route
That's Chesterfield Borough Council for you!
There's part of the Pronto route between Hasland and Winsick that is absolutely awful. The pronto uses double decker Enviro400 MMCs and the rattles are deafening. I can imagine Comet ADLs would be something similar on some sections.
Have we even seen an 11.8M 6 Cylinder ADL on the comet at all?
bringiton
24 Feb 2024
derby
Derby bus station has shut
Trainman40083
29 Jan 2024
Derby
Not sure that there is such an ADL to use on the Comet service from Derby...A pink Mickleover may have done, shorter 269 has done. I thought ADL and rattles were always used in the same phrase. Comet service will be fine of they get the 20 plate Skylink Enviros in a couple of years
Davidsb3
16 Apr 2019
Derby, UK
This was due to an Arriva bus catching fire under the now closed car park. From what I have heard everyone is okay but still scary.
It nearly had 145 the other week, but i don't think so.
bringiton
24 Feb 2024
derby
This was due to an arriva bus catching fire under the now closed car park from what i have heard everyone is okay but still scary.
Yeah apparently no one on board. I'm fairly sure the bus station has now reopened.
Russel
30 Jun 2022
Lichfield
Someone better tell TFL!
Trainman40083
29 Jan 2024
Derby
I was a fire warden for 25 years. Every year there was training, including tackling all sorts of fires. Oil fires were quite scary. It was drummed in, get people safe, property can be replaced. We learned to keep an eye on likely causes. Presume ex car park didn't burn.
bringiton
24 Feb 2024
derby
From what I saw as I just drove past (and I didn't get a very good look) it looked alright, probably at most would be slightly burned
Trainman40083
29 Jan 2024
Derby
Yeah.
Good old council.
Is it known when Scania coach 99 is leaving derby? I know its next week but is there a certain day?
But the Council don't own the car park.
2 out of 3 branded Comet Volvos are off the road today with 269 and 846 covering. 3 different vehicle types covering a 3 vehicle route is cool to see.
Ah well, it looks like 748 made it back to Derby. I would imagine there will be no spare bus to cover some routes today. System gives the impression that a couple of the Mickleover buses have come off. So, to anyone looking forward to Enviros replacing Volvos, well, good luck.
Trainman40083
29 Jan 2024
Derby
In Nottingham we don't have that problem- routes are so much more reliable with ADLs compared to Volvos.
Maybe that is because the routes are more profitable, there are spare buses available between the peaks allowing time for planned /unplanned maintenance
Wow. Four buses on the Allestree today, with Enviro 200MMC number 269 helping out, whilst sister 265 is off. Personally, I thought it sounded odd, when it passed me twice, on my way back from lunch.
Russel
30 Jun 2022
Lichfield
Why is Mango still a thing when contactless tap on tap off schemes are well established with other operators?
bringiton
24 Feb 2024
derby
I prefer mango, it gives me visuals that it's working and not over charging when with a tap on tap off I would be worried its charging me two times
tram21
29 Dec 2022
You can easily add discounts so anyone can use it and know your getting the best fare. Also, outside of the £2 fare cap its around 10% cheaper I believe
Trainman40083
29 Jan 2024
Derby
The strange thing about the Mango app, is that all my friends that were using it, ditched it. The only one that still has it reverted to cash fares, both £2 and for zigzag. Clearly it wasn't for everyone, in the same way that self service tills aren't.
In the days of the Mango card, which I think ran for 10 years, not once did I get overcharged.
Can't help but wonder how many people walked away when they introduced the app. The clever thing about it, was they would have done it under cover of COVID, and maybe, took the money in their account when the company was getting significantly less revenue, when passenger numbers were on the floor. I would think more people paying £2 cash, may well have affected cash in the bank.
It was mentioned there would be both red and mango spares.
Yes indeed. I said that there was 6 contracts, so four were branded routes, so clearly there had to be both red and Mango spares.
Davidsb3
16 Apr 2019
Derby, UK
but the Council don't own the car park.
Cant even blame me I've been on annual eave this week ;) but im wondering what state im gonna walk in on sunday morning :p:lol:
