Transpennine Route Upgrade and Electrification updates
YorkshireBear
23 Jul 2010
The TRU website shows no disruptive work at all after the September blockade, which we know is false. They could do with starting to broadcast future closures as October is not far away.
Was hoping to see confirmation of blockades for January 2026.
KN94
12 Mar 2025
Stalybridge
Church Fenton from 27th December (24th December) until Monday 26th January
From 27th until 29th December, nothing Leeds - York (via Micklefield or Castleford) or Leeds - Hull
From 29th until 4th January, nothing Leeds - York (via Micklefield or Castleford) but Leeds - Hull can run via Micklefield
From 4th January, Leeds - York via Castleford and Leeds - Hull via Micklefield
Nothing else TRU-wise in January until 31st January when Diggle is closed over the weekend again.
Before that, 4/5 October has Diggle and Micklefield closed (so double diversions for TPE)
11/12 October, 18/19 October, and 22/23 November has Micklefield closed
15/16 November and 30 November (Sunday only) has Diggle closed
w/c 6th October, 13th October, and 20th October has Morley closed
25/26 October and 1/2 November has York station closed for non-TRU work, although I'm sure TRU will get in there South of York. The line to Scarborough is open except from Sunday 2nd November.
8/9 November has York blocked from the South for non-TRU work, although again I'm sure TRU will get in there. North of York, including the line to Scarborough, is open.
And then on Tuesday 23rd and Wednesday 24th December, Mirfield is closed ('Eye of the Needle')
Yes, the TRU website needs to update (they're probably to busy focussing on the Huddersfield block!) but until it does, I hope the above helps.
superkev
1 Mar 2015
west yorkshire
Latest Sarah Bell video shows an absolutely massive crane at Hudds ready to do a test lift of the replacement John William street bridge replacement. Much work around the station too.
Also much activity on all the new bridges between Huddersfield and Heaton lodge.
K
30907
Meanwhile the Shipley Depot site is seeing some serious activity this afternoon....
KN94
12 Mar 2025
Stalybridge
Question- when is the planned long blockade on mirfield/ Heaton lodge section? Is it 2027?
There is a planned block at Thornhill LNW Jn from 22nd May 2027 until 27 June 2027
There is/was also a planned block around the Cooper Bridge / Bradley Jn area but I *believe* the plan is to combine the two (might result in a larger timescale footprint for the one block but reduces the number of overall disruptive days).
2027 is full of 'Eye of the Needle' weekends (either full weekends or Sunday only) in preparation for the major blockade and then as a follow up.
Traf73
30 Mar 2023
Lancashire
Video of the Span 108 bridges being loaded at the Heaton Lodge assembly compound, trundling down to the canal and being installed:
GRALISTAIR
11 Apr 2012
Preston Lancs
Wow, thanks for posting. The enormity of the civils on this project never fails to amaze me. Does that green color of the spans have an official name such as BR Green ?
superkev
1 Mar 2015
west yorkshire
Ten superb drone pictures of Baker viaduct posted by Robert Stenhouse on Flickr.
Most of the piling looks to be complete with much above ground construction around the canal and river crossings.
Work at the Ravensghorpe station end dosn't look as far advanced particularly with the flyover over the Wakefield lines.
Robert's great drone pictures along with Sarah bells super vids are the main source of TPU upgrade works. Great job thanks.
Sorry don't know how to give a link.
K
hwl
5 Feb 2012
At an educated guess RAL 6029 "Mint Green" (dubious name given the actual shade)
The lighter sage green shade green shade often used on bridges is RAL6021 "Pale Green".
D6130
12 Jan 2021
West Yorkshire/Tuscany
Noticed en route to York this afternoon that a wire run has been erected over the Up (Leeds-bound) line about mid-way between Church Fenton and Micklefield. Catenary wire and contact wire up....but no droppers as yet.
GRALISTAIR
11 Apr 2012
Preston Lancs
Thanks for that. Believe it or not, until December 2009 I was a colour chemist- matching shades etc.
billh
7 Jan 2015
Interesting. An earlier version , which looks an identical shade to me, was "Holly Green" made by Sherwin Williams and possibly others ,was used on many new and re-painted Networkrail bridges.
hwl
5 Feb 2012
It was from the older British standard industrial paint range:
BS4800 14C39 Holly green
Which is much greyer than RAL 6029 (~10% more black pigment, the blue : yellow colour ratio is similar though)
Traf73
30 Mar 2023
Lancashire
It normally is S-W Holly Green but they've applied Jotun Penguard on this one for whatever reason.
The daft thing about this span was the requirement to resupply the service bridge as well even though it won't be used for any services just because its a "protected view."
K
Here’s a this link to the relevant Flickr photostream. I’ve done this in reply three times now:
Tim_UK
9 Jan 2019
Can I check what you mean?
That there is a spare span in the Canal bridge that had to be replaced even though it will not be used?
unslet
5 Apr 2013
Whilst all the attention has been focussed on the Dewsbury to Huddersfield section, some track alteration has taken place at Cross Gates. The crossover, which had been stored between the running lines at Cross Gates station, has been installed about a quarter of a mile to the west of the station although it is not in use yet.
D6130
12 Jan 2021
I believe that facing crossover is designed to eventually give access to Neville Hill depot from the East.
Tractor37
23 May 2017
It’s to allow services from York and Selby to crossover and head back east when all the track work through Neville Hill is being altered. To access Neville Hill from the east at that point would involve approximately 3 miles of running wrong road blocking eastbound movements.
unslet
5 Apr 2013
Regarding Cross Gates. I think both of the 2 scenarios mentioned above make sense. Trains from the east can turn back during the day and return to Neville Hill at close of service.
Andyh82
19 May 2014
I always think the replacement bus arrangements at Huddersfield could be better
People just hang around randomly outside the station and then occasionally a bus pulls up and a member of staff shouts out where it is going.
There are no departure boards outside so unless you are using an app, passengers don’t know when the buses are due
There is are no shelters except for the normal bus shelters. None of those marquees, queuing systems, extra toilets or coffee carts that they did when there was that major closure down south a few years back that I remember reading about.
johntea
29 Dec 2010
York - Manchester via Wakefield just has a bus replacement between Wakefield and Dewsbury so not too bad thankfully for me using that route a lot
Once Huddersfield is back up and running looks like the end to end train service resumes just not calling at Deighton
Andyh82
19 May 2014
I see that Brighouse station has got a new lick of paint, all in Metro red, with a complete set of new signage in the new RA2 style
The car park is closed to allow buses to turn around, passengers are advised to park on the roadside or use other (chargeable) council car parks. Additional shelters have been built.
Have the platforms been extended? Can Brighouse take a 2x185 six car formation?
Class 170101
1 Mar 2014
Andyh82
19 May 2014
Looking at this schedule (and there are others) I would say yes.
That doesn’t mean anything as TPE have been using 6 cars on this route for years, Can it take 6 cars with all doors on the platform?
