Transpennine Route Upgrade and Electrification updates
But it would still mean a much slower stopping service, and a fantastically complex timetable with little room for failure and recovery.
I mean, that's pretty much what the current timetable involves. Eastbound the Huddersfield-Leeds stopper sits at Dewsbury waiting for the Scarborough service to overtake it, westbound it uses the slow lines between Mirfield East Jn-Heaton Lodge Jn and sits at Heaton Lodge Jn, again waiting for the Scarborough to pass.
The margin for 'pass to depart' is actually less than 3 minutes in each case - it's 1½' at Dewsbury and 2' at Heaton Lodge Jn - but it still results in a timetable highly liable to delay.
Spartacus
25 Aug 2009
I think there's about 1km of possible loop at Batley, which while not ideal could be mitigated by having the next express behind it call at Dewsbury, I can't remember the details. I remember doing some basic modelling years ago which suggested Batley would be a decent spot for a loop if needed, in fact probably the only possible spot between there and Leeds to put one.
quantinghome
1 Jun 2013
Not sure that would mitigate it. Wouldn't you want the next express behind it to overtake as quickly as possible? Or do you mean the next-but-one express i.e. the one the stopper comes out in front of after being overtaken?
I suspect it's the latter rather than the former.
I think in the proposal by @Bald Rick a page or two back (edit: actually much further at #4936), the fact that the stopper can use slow lines between Huddersfield and Westtown means it doesn't have to wait at Batley. There may be some flighting of fast trains, but at 8TPH does it really matter if some of the gaps between them are a bit longer?
quantinghome
1 Jun 2013
As @Bald Rick pointed out, each stopper would take up 4 fast paths, so you'd have a 15 minute gap. Not a show stopper obviously, but not ideal.
My main concern though is that short of building additional tracks there's no way we can increase local services, unless you flight them as well. But that's really defeating the object of a regular metro service.
12 minute gap, as the stopper is one of the 4 paths it uses.
The objective of TRU is to provide quicker services Manchester -Leeds -York, and not to increase local services.
quantinghome
1 Jun 2013
I meant a 15 minute gap between the fast services before and after the stopper.
True. But at some point someone is going to have to decide whether West Yorkshire should have a proper metro-frequency rail service for local stations. The possibility of such a thing doesn't even appear to have occurred to those developing the IRP.
Ah, I see, yes that’s right (albeit it’s 14 minutes, on my back of fag packet assumptions). If the service following the stopper has a Dewsbury call, then the gap becomes 12 minutes departing Leeds.
There’s a difference between TRU objectives and IRP objectives. Nevertheless, one presumes such a thing was considered, but it was decided against.
Glenn1969
22 Jan 2019
Halifax, Yorks
So what you're saying is NPR services will effectively replace current services not operate alongside them? Not sure how that will go down with local stakeholders. My assumption is pre Covid levels of ridership will have returned by 2024. The pre Covid timetable on the core route didn't provide enough capacity which led to severe overcrowding which I think means there is substantial suppressed demand. There is also no scope for more tnan 1tph stopping Leeds- Huddersfield because of the capacity issues that won't be addressed given that Leeds- Westtown will still be a 2 track railway.
I think we've established there will be 2TPH of stoppers. The fasts could leave Leeds and Huddersfield at alternating 15 and 5min intervals, with the second one ones calling at Dewsbury in such a way as to even out the intervals a bit as mentioned. That would replicate the existing 4TPH fasts and add 4TPH of NPR extra-fasts - and in theory it would allow 4TPH of stoppers too, though some other constraint may prevent that.
61653 HTAFC
18 Dec 2012
The plan is for two stoppers per hour, but only one of them will go to Huddersfield- the other will branch off at Heaton Lodge for Brighouse and the Calder Valley (and may omit some stations, as it does today).
Back before the line through Brighouse reopened to regular passenger services, there was intermittently a second Leeds to Huddersfield stopper in some hours, which omitted Ravensthorpe.
No, I’m not saying that.
This is a TRU thread.
LittleAH
24 Oct 2018
The problem with the CV services is the role of ETCS and having a diesel under wires which is a massive performance risk assuming similar rolling stock is still used.
Potentially, with ETCS 3 stoppers per hour could run, but until more news around ETCS and post TRU timetables comes out, it's up in the air.
IanXC
Emeritus Moderator
18 Dec 2009
The Calder Valley service could, given the new track layout, and the diesel under the wires question, relatively easily be diverted via Wakefield Kirkgate to Leeds.
That would mean that the stoppers on the Dewsbury corridor would both be electric Leeds - Huddersfield services.
Roast Veg
28 Oct 2016
Would you have to put any extra calls in at Mirfield so that passengers from Dewsbury can continue to access the CV?
61653 HTAFC
18 Dec 2012
Providing that there's capacity on the Woodlesford route (and that a solution to the Leeds platform 17 conundrum is found), this would possibly be the best way to run the Leeds-Brighouse-CV services after the upgrade. You would lose the direct Dewsbury/Batley link to the upper Calder Valley, but that's probably less of a loss than having capacity via Morley swallowed up by a relatively slow diesel service. It also gives Wakefield a Manchester link back, though AIUI there is also the plan to extend the Manchester to Huddersfield stopper to Kirkgate.
If the Huddersfield to Leeds stoppers were running every 30mins, there would likely be a reasonable connection at Mirfield without adding extra Mirfield calls to the fasts/semi-fasts.
Roast Veg
28 Oct 2016
That depends on the timetabling, surely. If the CV service runs immediately ahead of the Huddersfield stopper heading West (or v.v.) then it could be a very long connection time.
61653 HTAFC
18 Dec 2012
25-27 minutes at Mirfield in that case... just enough time for a swift pint in the Navvy! ;)
(Edit: non-drinkers will have the option of changing at Ravensthorpe instead... though in that case being already drunk would probably help!)
IanXC
Emeritus Moderator
18 Dec 2009
The Calder Valley and via Dewsbury services would be on entirely different routes, theres no reason to think either would 'follow' the other.
Roast Veg
28 Oct 2016
I'm aware, I mean "immediately ahead of" in physical space rather that paths along the same sections.
61653 HTAFC
18 Dec 2012
They'd both (the Hudds stopper, and our hypothetical Calder Valley via Wakefield service) use the same slow lines between Ravensthorpe and Heaton Lodge.
IanXC
Emeritus Moderator
18 Dec 2009
Which is only a short section, and which could easily accommodate 8tph
Halish Railway
26 Apr 2017
West Yorkshire / Birmingham
Surely having the Leeds to Wigan via Dewsbury service non-stop between Leeds & Dewsbury in addition to a 2tph all stations EMU wouldn’t eat into capacity much. I would have imagined that post-electrification & linespeed increases a 15x load would only by 1-2 minutes slower than an EMU load between the two stations.
61653 HTAFC
18 Dec 2012
I agree capacity on that section shouldn't be a problem. If this hypothetical re-routing of the via Brighouse service was to happen, the pinch-points would be at either end rather than somewhere in the middle such as Mirfield.
The issue at Mirfield would really be which connections are prioritised. If we assume a 2tph Huddersfield to Leeds electric stopper, plus an hourly Huddersfield to Casvegas/York and an hourly Calder via Wakefield, then the optimum would be for those four trains per hour to run at 15-minute intervals on the shared section. This would mean either a 15min or 45min wait at Mirfield/Ravensthorpe for the journey described by @Roast Veg .
Harvey10
20 Jun 2014
Sorry if this is in the wrong thread just wondering does anyone have any update regarding TPE extending the stopping service to Wakefield Kirkgate please?
matacaster
19 Jan 2013
Huddersfield
Ravensthorpe has a wide variety of zero-rated takeaways. It is also best avoided during the day and certainly at night
61653 HTAFC
18 Dec 2012
My understanding is that it was initially proposed as a way of making 6-car workings possible- with running to Wakefield Kirkgate in order to avoid blocking up the whole of platform 4 at Huddersfield. IIRC the plan was to run there ECS, not in service- but I believe that's changed.
However the plans seem to change with the weather at the moment, so who knows what will end up happening. The Wakefield plan certainly seems to be less of a performance risk than the 2018 merged stoppers.
