Transdev Blazefield
mattb7tl
1 Jan 2022
Huddersfield
Transdev's entire network needs some simplicity. They should consider doing more than just the 1.
A gripe of mine is the D1 (between Huddersfield and Denby Dale) It makes an irritating detour to serve a random estate towards the end of the service despite the fact that very estate and every house on it is within 5, or at the very worst 7-8 minutes walk, away from the main road it detoured. Planners universally agree that people do very much walk 7-8 minutes for a bus, with the distance people are willing to walk increasing based on frequency and service quality.
markymark2000
11 May 2015
Great Britain
The generally agreed walking distance is 400 metres. Though I am yet to receive confirmation on whether this is 'crow flies' or 'actual' distances. However, in any case, that distance reduces quite drastically when hills are involved, as is the case with this estate that you are talking about. From the main road at the bottom, up to the top of the hill, Google Maps says you are climbing around 30 metres and it's at a decent gradient too.
mattb7tl
1 Jan 2022
Huddersfield
The estate is also almost entirely within 400 metres to the main road. I have heard the 7-8 minutes range used by a lot by planners. It is seems to be due to the fact that they cannot decide between a 5-10 minute walk so most now just meet in the middle which seems fair so this is now my measurement for walkability.
The issue with that gradient is the fact that we are in Yorkshire... If a bus service was detour and climb up each gradient to make it an easier walk we would never get anywhere but you also want buses to remain accessible so measuring by 400 meters, which seems to be a 7-8 minute walk, seems appropriate. Google maps also factors in the extra time it takes to climb a gradient. It also seems to be based on people far older than me since it is usually far too generous with time. So the elderly will likely be quite close to the estimated times.
markymark2000
11 May 2015
Great Britain
All planning guidance that I have seen, states 400m even guidance from Active Travel England states 400 metres. Guidance from Surrey County Council states "Homes should be within 400m walk of a bus stop or transport hub, as most people are prepared to walk five minutes (400m) to a bus stop". Leicestershire County Council goes further saying "Walking distances to bus stops in urban areas should be a maximum of 400m and preferably no more than 250m".
The joys of buses adapting to the terrain. It's a hilly area and so the bus goes up the hill to provide easier access to the bus. Same thing happens in Wales with similar terrain. The alternative is the bus doesn't go up the hill and that whole estate is then forced to either climb the hill if they want to use the bus, or the more likely answer is people will just rely more and more on private transport.
It takes into terrain slightly but not by enough in my opinion. It's also still based off an average walking speed. If you are elderly, the walking speed, especially up hill, will be be of no help at all.
Does the area need as frequent as a service it gets, probably not. However given the estate is near the end of the route in Denby Dale, I can't see it majorly affecting passengers who aren't making use of the loop, and it's probably worth sending all buses the same way just for simplicity (which in itself can encourage people onboard). The diversion takes between 2 and 3 minutes to complete and based on the overall journey times and so on, a 2-3 minute saving each way wouldn't cut the PVR as the round trip would still be over 2 hours and so what would be the benefit? The bus gets to sit around Huddersfield for longer.
M60lad
31 May 2011
Coastliner were having problems yesterday afternoon 2274 broke down in York on Stonebow while operating 840 13:10 to Whitby it got to York at 14:44 but didn't leave until 16:05 also not to sure why but 3642 spent about 3 hours in Tadcaster Bus Station from 14:54-18:07.
YorkRailFan
6 Sep 2023
York
Was on it earlier. Still says Harrogate on the inside rear of both floors, but externally, other than legals, it is blank.
Will it get Coastliner vinyls or something else?
Think you mean 2774 :D
SCH117X
27 Nov 2015
So 2774 at York has been repainted into the base red City Sightseeing livery, with Bustimes calling it a "Winter Livery." Any idea what that's about?
Paul Turner has confirmed on Facebook its a York City Sightseeing promotional livery.
Re the 400m walking distance there is a lot of housebuilding taking place to the north of the existing estate on the north side of Knaresborough Road in Harrogate but no bus service is being provdied despite being well over 400m; in the view of North Yorkshire County Council (now North Yorkshire Council) the frequent service along Knaresborough Road mitigates the added distance.
61653 HTAFC
18 Dec 2012
The D1 and its predecessor routes going back decades all had the detour around Gilthwaites Estate as part of the route, with the exception of a few early and late journeys in Centrebus days which skipped it. I'm not sure why successive operators have all felt the need to retain this diversion, because as you say it isn't a massive distance to the A636 Wakefield Road from anywhere on the estate. There are bigger areas of housing along the route (the outer edges of Skelmanthorpe, the large residential part of Shelley on the hillside) which have a much longer walk to the bus stop, than those on Gilthwaites would have if the bus just ran along the main road.
As others have said, it isn't a huge time penalty to continue serving Gilthwaites. You'd gain more time by re-splitting the routes which serve Denby Dale and Clayton West, but presumably the routes were merged together for a reason. Presumably the total ridership is higher (and costs lower) with a combined route than with two separate routes, despite the extended journey time for anyone going to Denby Dale.
AWWisher
27 Jun 2024
South Pennines
Walking times are better than distance in hilly country. This has been well researched over the years by the hill walking community (Naismith et al) and the current consensus seems to be:- 4 km/hr plus 1 minute for every 10 m metres of climbing. This is for the average hillwalker so you could double this for a pensioner with a heavy shopping bag.
So, for Gilthwaite Estate in Denby Dale (Team Pennine, D1) it works out to be 6+3=9 minutes for a fit person and 18 minutes for a pensioner.
Whereas, on a flat street in London it would be 6 or 12 minutes.
[As an aside: when a kid in Keighley (where many people live high up on the valley sides), just after the war, the thrifty Yorkshire folk would walk to town (downhill with empty bags) and catch the bus home (uphill with full bags). To generate more 'downhill' custom, the fares were a penny down and tuppence up (in 'old' money). Kids were a ha'penny either way].
Leedsbusman
9 May 2021
Layton
Who does it actually inconvenience given that the estate is pretty much near the terminus. The majority of customers won’t get anywhere near this.
61653 HTAFC
18 Dec 2012
I'm not arguing that it does inconvenience anyone- my point about extended journey times was in reference to the D1 doing a loop of Clayton West and Scissett on its way to and from Denby Dale (which the old 82 service under Centrebus didn't do, as Clayton West was served by the separate 80 and 81 routes). Just that it's a bit odd that the relatively small Gilthwaites estate gets a bus service when residents of the much larger developments at Shelley have to walk significantly further to access bus services on either the A629 or B6116. However the Gilthwaites diversion isn't that time consuming, and being so close to the terminus minimises the number of passengers who might be annoyed by it. By contrast a diversion via the estates at Shelley would mean extended journey times for far more people, and the roads there are deliberately designed to discourage through traffic and reduce speeds, so getting a full-size bus around there would be more difficult. Nevertheless, I'm surprised that none of the operators over the years have decided not to bother with the Gilthwaites detour anyway- particularly when penny-pinching Arriva were in charge (though using their Yorkshire Tiger subsidiary). I'd have thought the PTE/Combined Authority wouldn't be opposed to dropping the diversion either, as it means fewer stops for them to maintain.
61653 HTAFC
18 Dec 2012
No but one person has so now we have a long rambling thread discussing something rather inconsequential!
That's one downside of having master threads for operating groups- What's going on in Blackburn or Pickering has little relevance to someone in Denby Dale, and the buses being owned by the same group is neither here nor there (pun intended). However the alternative would be a dozen threads for each separate business unit within a company, with only three or four regular contributors... So it's not like the forum moderators can win!
We wouldn't have gone off on a ramble here if you hadn't rather haughtily pulled me up for making a post that largely agreed with the consensus that the diversion wasn't a problem that needed solving. Someone asked a question, and some people responded with knowledge such as the methodology for where gets served with regard to walking distances to stops, and I added some historical context as I'm familiar with the area in question.
Aggressively asking "who does it inconvenience?' when there had already been a polite discussion about whether or not it is an inconvenience, added nothing.
stevieinselby
6 Jan 2013
Selby
I would guess demographics are also at play. My impression of the estate around Shelley is that it is a lot more affluent than Gilthwaites, so people are a lot more likely to have access to a car rather than be relying on buses. That means you almost certainly wouldn't pick up enough passengers to justify the 8–10 minutes extra it would take to divert the D1, although adding 3 minutes onto the D2/D3 for a quick loop around Park Avenue and Cleveland Way (rather than trying to serve the whole estate) might be slightly more plausible.
61653 HTAFC
18 Dec 2012
This is probably true. It's slightly frustrating that the D2 & D3 are daytime only routes, as my mum lives on the Park Avenue estate and having the option of leaving the car at home when I visit would be nice... However one person occasionally using the bus isn't going to make an evening service viable. It isn't a new thing that there's no bus along that section of the A629 after 6pm anyway, you'd probably have to go back to the 1990s to find one (which possibly would have run right through to Sheffield).
YorkRailFan
6 Sep 2023
York
The last of the ex-Reliance MCV Evoras, 1901, has been repainted into York & Country Blue. I know 582 is now wearing branding as well as livery, have any of the other repainted buses received branding?
aswilliamsuk
10 Jul 2016
Agreed, it's a long time since there were evening buses down the A629.
When I first moved to the area in 1987, it was the 235 and 236 Huddersfield - Barnsley. The 236 served Highburton and then down Busker Lane at the Windmill Inn, before turning right to Denby Dale and Cawthorne, while the 235 went direct through Kirkburton, then down Highbridge Lane and left to Clayton West and through Kexborough. Both ran hourly and were shared between Waterloo and Barnsley depots of Yorkshire Traction (Waterloo had 2 of the 3 workings on the 236, and one of the 3 on the 235, Barnsley the opposite).
Shelley and Shepley were served by the X39 to Sheffield - which later became the 234 to Penistone and then Barnsley - and the irregular 285/286 services to Upper Denby which were tendered and went through a number of operators, and went via convoluted routes to say the least.
When Yorkshire Travel introduced to 240 to Clayton West - via Lepton and Highburton, using mostly new, leased Volvo B6s, Yorkshire Traction reacted quickly, introduced a copy of the route, and brought in Darts. Similar then happened with routes to Denby Dale through Skelmanthorpe and Shepley.
The routes were overbussed, but it did prove there was a market for a better service. It also, eventually, killed off the cross-border routes to Barnsley from Huddersfield and removed the double deckers from the routes too (getting the coach seated Metrobuses from the Barnsley allocation was always a rare treat!).
The mostly rural area SE of Huddersfield has always been a relatively affluent area, with a few pockets of deprivation, and it's perhaps no accident that the latter are served better than the big, car owning estates like Shelley Park, which as others have noted was never designed for buses or through traffic.
Shelley College - in my day Shelley High - is a big traffic generator, too, with a host of local school routes and a good number who use the now D1 and the X1 to get to/from school too.
SCH117X
27 Nov 2015
Mellor Strata 69 on fire at Halifax bus statoon yesterday
Photo of a pretty destroyed front end in this pretty vague article
Emergency services have been spotted attending to a fire at a West Yorkshire bus station.
A fire has broken out at Halifax Bus shelter this afternoon. According to witnesses it happened around 5pm today (June 25).
Fire crews are currently at the station as pummels of thick smoke fill the air. It is rumoured that a bus has has caught fire. It is not known if anyone is hurt or any other vehicles is involved.
It is believed that buses will be delayed until the fire is put out.
West Yorkshire Fire and Rescue Services has been approached for more information.
Bungle965
Buses & Coaches
2 Jul 2014
Calder Valley
Being discussed here:
YorkRailFan
6 Sep 2023
York
The first of the ex-Reliance B7RLEs, 1773, has been repainted into blue York & Country livery.
2423 has transferred from Idle to Rawcliffe.
MCRTransitYT
15 Nov 2024
Bolton
1504 now in service
Are all the flyer versas getting returned to their leasing company or are any being distributed between other transdev divisions?
JWalker127
12 Jul 2023
England
1504 now in service
All going back to the leasing company. 3 withdrawn so far: 239,274,277
MCRTransitYT
15 Nov 2024
Bolton
1515 entered service today with Harrogate - picture on friends of buses and coaches fb group
theblackwatch
15 Feb 2006
And for those who don't do Faceache, here's a pic I got around 30 mins ago on its last booked run of the day.
Shaw S Hunter
21 Apr 2016
Over The Hill
Nice to see a picture taken in the town centre somewhere other than in the immediate vicinity of the bus station. It'd be good if more photographers found viewpoints away from the usual spots in town centres generally.
