Transdev Blazefield
Class 165
24 Apr 2012
The most recent change to the registration was registered effective 25 February 2025 as far as I can see.
Ok, I don't use the bus too often, but I'm surprised the change happened that far back! I guess I'm not that observant
The timetable is a right hodge podge now, there's only a 4 hour period when it's at a 30 minute frequency, the rest of the day varying between 35 minutes to 55 minutes gaps (as well as hourly in late evening).
I would've thought that they'll have lost passengers on local journeys due to the lack of regular timings throughout the day.
YorkRailFan
6 Sep 2023
York
It looks like the change in frequency in the afternoon is because one of the buses on the A1 is used on a school run. Idle depot took on said school service from Keighley in February 2025 which coincides with the timetable changes to the A1/A2/A3.
Class 165
24 Apr 2012
Thanks for the info, it's interesting to know the reason behind it
YorkRailFan
6 Sep 2023
York
No problem. The morning school run is operated using an A2/A3 bus instead of an A1 bus.
With the end of the Summer DalesBus season approaching, several Transdev operated services will end for the summer season (820, 821, 825, 866, 875) with winter timetables commencing on services 864 & 873. There will also be changes to Saturday services, with the 75 reverting to Skipton-Malham (not extending to Settle) and instead operating three return journeys for the winter season and a change of route on the 59 via Jennyfield Drive in Harrogate from 24 October.
These DalesBus services will all finish for the 2026 season on 17th/18th October:
80, 820, 821, 822, 825, 830, 831, 832, 857, 858, 859, 866, 875 and 876.
Winter timetables will start on Saturday services 59 and 75 from 24th October, with DalesBus 59 running via Jennyfield Drive in Harrogate and service 75 running between Skipton and Malham only.
Winter timetables will start on these Sunday DalesBus routes from 25th October 2026:
Cravenlink 864: Bradford - Ilkley - Skipton - Malham
Cravenlink 873: Ilkley - Bolton Abbey - Skipton
26 Feb 2026
Lancashire
So would the 59 go through the estate itself, via the route of the 3 going towards Harrogate and reverse going out?
SCH117X
27 Nov 2015
When it has been previously diverted due to road works it has followed the 3 route outbound to the A59 and turning off the A59 earlier to follow largely the inbound 3 route i.e. then direct along Jennyfield Drive.
