Tram track Explanation Single track auto divert to twin station /passing point
stuetor
8 Aug 2021
Hello guys Can anyone explain how a tram is auto diverted to one side or other of a passing point ? > Track controls > Is it so there is a single sprung blade on one side ?
Diagram with arrows much appreciated
If it is a single sprung rail/blade are there any safeguards to ensure it is in not blocked ? ( stiletto heel in gap etc ? )
Is there any ingenious idea to have a completely fixed track system to achieve no moving parts ? ( frogs etc ? )
Building a garden tramway O gauge Crodon Tramway base
stueter
ALEMASTER
18 Aug 2011
typically they are spring return points. There is usually a points indicator signal to confirm the points are fully across and making contact but the secondary safeguard is a visual check by the driver as they approach as such locations are low speed.
Waldgrun
13 Oct 2011
Gauntleted track is not ideal for vehicles to pass on! I recall reading a rule book London trams and they use an electrical contact system, it worked by having a section of overhead near the points, which if the tram was taking power set the road for one track, or if coasting the other!
507 001
3 Dec 2008
Huyton
For simplicity such an arrangement would likely use sprung points. Modern systems would indeed have a Points Position Indicator (Metrolink speak) to prove the points are in the correct position.
To be clear, that's the historic London Trams. On Tramlink, the points are actuated by a beacon on the bottom of the tram interacting with a loop between the rails.
Tramlink does have two sections of gauntlet (or interlaced) track. One is in Mitcham where the former double track railway formation is partly blocked by a big concrete block which I assume was put there to stop the cutting wall collapsing. Having interlacing instead of a short section of conventional single line avoids the need for moving parts, reducing maintenance and safety risk. The other is on Church Street, which avoids having to put a motorised switch in the middle of a highway.
Alfonso
22 Jul 2017
Amsterdam has very pleasing gauntleted track down narrow streets widening to passing places on bridges
etr221
10 Mar 2018
Tramlink points vary. Some - facing points needing to be often changed (e.g. that at Church Street) - are controlled (changed) by some sort of driver initiated beacon signal from the tram (one of the rules I think is that he has to check that the point can change safely). Trailing points, and those which in facing mode are always set one way, are normally sprung, and uncontrolled. Less frequently used facing points (e.g. at East Croydon, to enter the middle track) are worked by a point lever - one is carried in the cab, and driver will get out with it to set the points - or if it's being done a lot (for engineering work), someone will be posted as pointsman.
Sprung points are also widely used at loops on RETB controled sections of the Network Rail, and also at station loops on the Welsh Highland Railway - I gather shunting at Dinas has to be carefully planned to work with this.
If I recall correctly there are only 11 motorised points on Tramlink, but I think that includes the ones to access the middle track at East Croydon because that's used regularly.
_toommm_
8 Jul 2017
South West London
I’ve seen a few signs on the Supertram network where it says ‘points not trailable’ (mainly on the street running track). Are trailable points one that can be pushed over by the tram safely?
507 001
3 Dec 2008
Huyton
Yes. Non-trailable points in Metrolink land tend to be motorised or hydraulic points.
D365
29 Jun 2012
Where are those? Don't remember seeing those signs at Cathedral or Hillsborough.
