Traksy Website
takno
Verified Rep - Traksy
The data feed has been restored.
There's just been an e-mail on se-gen saying everything is back up and running normally.
Yes, I can see the Grafana panel reporting messages, but nothing is coming through on my connection, which is a bit frustrating. I'll keep working on it
Peter Mugridge
8 Apr 2010
Epsom
OTT is definitely working OK at the moment. Screenshot below.
Maybe it just takes a few moments for everything to come through after a restoration?
Freightmaster
Verified Rep
7 Jul 2009
There's definitely some kind of issue with my connections. I've reached out to them for updates, so I guess we'll see where we get to
It’s not just you - all map services *except* OTT (such as Railcam and Freightmaster) are not receiving any TD data.yet either…
MARK
takno
MARK
I've got Traksy restarted by using a backup public account. Maybe they were so angry at being called out earlier by Peter that they decided to take it out on everybody except him.
The old site is now working as normal, and the new site is cycling through the last week of train movements, which is at least interesting to look at, and will be up to date shortly.
trainmania100
8 Nov 2015
Newhaven
Bit of strangeness with this attached schedule. 8pm timing near the top is incorrect and then at the bottom back to 6pm with
Strangely Eastleigh is missing from the timing points, booked 1844, appears at the bottom
Hope this helps your debugging
Northampton
RTT is having problems with that schedule as well - the destination is blank
It's a VSTP schedule so has been directly input to TRUST, rather than being planned through a system that would help stop quite so many data errors being published.
takno
I'm mostly going to chalk that up to an error in the schedule. I'd love to know how it goes backwards I time though - I think if Traksy is displaying that then it has to be assuming that it arrives 2 days after departure with a couple of very long stops.
milooo
3 Dec 2024
Stevenage
Having a few issues that whenever I click on a train it flickers up for a second and the disappears..
  • screen-20250528-132504.mp4
    2.8 MB
takno
Ahh, that's annoying - I have a fix, just trying to get it released now
Fixed now
It seems to be advertising a new site without any way of getting to the original one.
takno
The adverts for the new site should be a small banner on the top of the original site. Something like this:
Are you not getting the "Pick a station" form underneath the advert?
Strange glitch I’m seeing, I cannot select the map for ‘Southampton Central’, (the ‘map’ button is dimmed), but stations either side work fine…
pokemonsuper9
20 Dec 2022
Greater Manchester
Mirfield has had some changes with TRU
Traksy screenshot showing Mirfield
Currently it's a 2 platform station, what was platform 2 is now numbered platform 1 (platform 3 is unchanged), the track at what was platform 1 has been lifted.
I've made a bit of a mess of it but I'm pretty sure this is correct.
Amended map of Mirfield station, now showing the middle line that has no platform
Here's a photo of a TPE leaving platform 3 for reference, taken 21st of June:
Class 185 - 185106 in Mirfield platform 3
MrJeeves
28 Aug 2015
Burgess Hill
I noticed this routing weirdness this morning on Traksy. I assume 1B22 isn't actually doing that...!
takno
No. The algorithm which draws the routes has a bit of a fondness for turning left. I've fixed a lot of places where it happens (including this one if you check again tomorrow), but it's safest to just assume that if it looks too silly then it's probably not what's happening
Trainguy34
29 Apr 2023
Kent
Just had a look and the crossover at Canterbury East is the wrong way round, it goes from Platform 2 onto the down line instead of the up line onto platform 1, as is currently shown.
takno
Thanks for pointing it out. This should now be fixed. I've also added a signal to the siding, which looks to be correct
