ramon hefford
- Joined
- 17 Jan 2018
- Messages
- 9
do any passenger trains run via Hampstead Heath from Willesden low level?
That appears to be a requirement to run from Upper Holloway to Hampstead Heath, oddly enough, as there are no platforms on the lines that connect up, only a bay (P3) for trains from Uper Holloway and P1+2 for trains to Kentish Town West.There's also one in the opposite direction which also avoids Gospel Oak:
0759 Woodgrange Park - Willesden Junction 0851
http://www.realtimetrains.co.uk/train/L90923/2018/01/22/advanced
It’s just an extra to manage peak loadings with what by rights is the spare 172. Starting it at Woodgrange helps spread the loadings a bit more.That appears to be a requirement to run from Upper Holloway to Hampstead Heath, oddly enough, as there are no platforms on the lines that connect up, only a bay (P3) for trains from Uper Holloway and P1+2 for trains to Kentish Town West.
Why does it start at Woodgrange Park, though, tracing it back it appears to run in service (formed off a runs when required move, not sure how that works if it doesn't run) from Barking to South Tottenham, run ECS to Barking Upney Junction (on the c2c lines) and then again to Woodgrange Park before starting there.
Now the T&H is electrified can’t they just use a spare 378 to operate the pixie buster using SDO where required and avoiding the short bay at Gospel Oak and running directly through to Willesden Junction or turning at Upper Holloway ?
Congratulations! You have posted one of the most incomprehensible jargon-ridden messages in recent history. For the benefit of monoglot English-speakers could you translate?Now the T&H is electrified can’t they just use a spare 378 to operate the pixie buster using SDO where required and avoiding the short bay at Gospel Oak and running directly through to Willesden Junction or turning at Upper Holloway ?
Well done Mugam4! Thank you for your help.I gotchu @jeromeroberts:
Now the T&H (Tottenham & Hampstead line - Gospel Oak to South Tottenham/Barking) is electrified can’t they just use a spare 378 (378 Capitalstar - the trains used on the Euston-Watford and orbital lines) to operate the pixie buster (PIXC buster - a peak only train plying less than the full route to hoover up the 'Passengers In eXcess of Capacity') using SDO (Selective Door Opening, where the platforms on the line are too short for the aforementioned 378) where required and avoiding the short bay (a terminating platform at a through station, in this case platform 3 which is the only platform facing the T&H) at Gospel Oak and running directly through to Willesden Junction or turning at Upper Holloway ?
0900 Willesden Jn - Camden Road did today
On weekdays it's the 0558 Willesden Jn - Stratford.
Thanks Yorkie for info,do you know if the 0900 was one off or part of a full service?0900 Willesden Jn - Camden Road did today
