Train driver 'freewheels' broken down train 13 MILES to London Euston after a power cut
Tomnick
10 Jun 2005
It's air pressure.
How do you think they are raised when a unit has been shut down? :D
How do you create the air pressure if you have no power, though?
It’s a bit of an irrelevance though, admittedly, as the loss of air pressure will mean that the pan will have dropped of its own accord by that stage anyway!
37057
3 Jul 2009
There's an auxiliary compressor that is powered by 110v battery supply for initial power-up. As per my post above, that's no good if the driver has allowed the batteries to become flat.
Tomnick
10 Jun 2005
That’s my point, really! A fair point about preserving the batteries to allow normal working to be resumed when the power supply is restored, but would drivers normally consider this vs keeping systems on the train running for as long as possible (for the passengers’ benefit)? Are there any instructions to that effect?
Highlandspring
14 Oct 2017
One thing which ranks highly on my list of railway oddities I’ve witnessed was watching a class 385 being ‘jump started’ with a boost pack to get enough charge in the batteries to allow the aux compressor to run...
There’s a couple of types of Underground train which have an interesting design feature, namely that the 630v line contactors are worked by compressed air. Needless to say the compressors are protected by these very line contactors, so if they open for whatever reason (one of which is traction current going off) there’s no means of re-closing them once any remaining air leaks away or gets used up. To get round this there’s a small secure leak-proof reservoir, which maintains a supply of air sufficient to close the line contactors, however this requires the driver to close a cock which is located beneath seats (so great on a busy train!). Failure to do this results in a foot pump having to be used to power up the train.
37057
3 Jul 2009
I don't deal with the operation of these units in service or what procedures are implemented in "out of course" situations but running these units at any speed without 25kv / auxiliary converter output is risky territory as I mentioned previously. It wouldn't necessarily be dangerous but it would certainly add to the situation if you now had a unit failure (or several) in the middle of a power outage. In my opinion I guess it would depend on the route, with priority to at least get to a station for evacuation whether it's a booked stop or not, rather than attempt to complete the journey that's "x miles away".
37057
3 Jul 2009
I borrowed a Corkerhill 156 to blow up a 350 for pantograph air when it's aux compressor failed a few months ago!
driver9000
13 Jan 2008
Surely, if a 185 automatically shuts down one of its engines, then it will restart it automatically, too, irrespective of whether the train is in motion or not. No?
No. There is no engine auto-start function.
driver9000
13 Jan 2008
Battery load shedding (2 stages) when power is lost is an automatic system which requires no input from the Driver. The TMS shows that load shedding has started and if it comes to the stage where the unit is totally without power and stranded then the assisting 350 can supply 110v to the dead unit using the cross feed once coupled.
driver9000
13 Jan 2008
Most probably. I just can't work out how an engine would be affected starting up while the train as at speed against it being stationary. What's different other than the speed of the train?
The engine on a 185 will remain at idle if started on the move as the Driver will need to select neutral and then forward to engage the transmission relays on the restarted vehicle.
hexagon789
2 Sep 2016
And I presume you can't select neutral while on the move? (I believe you can't on a variety of classes.)
driver9000
13 Jan 2008
Nope. I haven't tried it but I'm sure the switch is locked to prevent that but at very least I would expect a brake application as happens with 14x and 15x.
hexagon789
2 Sep 2016
Well I guess that's that then, engaging an engine on the move can't be done.
Highlandspring
14 Oct 2017
I did suggest to the Hitachi fitter that they might have been sensible to install a last resort bicycle pump...
Highlandspring
14 Oct 2017
I’ve never come across it though I know the Woodhead EM1 and EM2 locos had hand pumps to raise the pans.
bengley
18 May 2008
If I'm on time I can shut off at Garforth and coast all the way to Leeds
Deepgreen
12 Jun 2013
Gomshall, Surrey
Brings to mind the line in "The Railway Children", where they ask Mr Perks why the train is going so slowly - "Well it's all up'ill to Scotland in't it?"
Deepgreen
12 Jun 2013
Gomshall, Surrey
With these nice 700's I drive 60%/60% no need to go more than that ever. Under fcc any braking over 80mph had to be a full service step 3 application. Now we have no steps just feeling what we need, they certainly stop on the dime in 100%. Not tried emergency yet so not sure how that feels.
Don't you have to try emergency braking in type training? I would have expected all likely performance elements to be covered.
ComUtoR
13 Dec 2013
Yes; if your a Trainee. If you are a Trainee and have done a cab conversion then you don't need to do it. Our Trainees can do 3 traction types and only need to do one emergency bake.
If you are a Driver doing a conversion or new traction course then it's not mandatory as the expectation is that you already know how to drive and your driving skill will adjust.
craigybagel
25 Oct 2012
You can do the entire trip from a standing start at Knucklas to Knighton without taking power. There are a couple of drivers who when it's time to leave Knucklas merely release the brake, and don't touch the throttle.
Supposedly back in the 50s/60s when many services in Ireland were worked by AEC built railcars, they had a design feature where the dead man's handle had to be pushed down with one hand all of the time or else the brakes would kick in. However, if you put the reverser into neutral, it would disable the deadman's and given Ireland's generally flat topography, you could coast for miles and save your muscles!
ComUtoR
13 Dec 2013
It was easier to hang a bag on it...
hexagon789
2 Sep 2016
I believe the first generation BR DMUs were like that, the throttle had to be held down or the vacuum would be destroyed. Not sure if the reverser could be set to neutral to negate that though.
big all
23 Sep 2018
redhill
Some units do have a manual pump of some kind for that purpose, don't they?
73s had a car footpump to pump the shoes down if you had flat batteries if over a juice rail
now the secrete was to isolate the shoe gear at the other end so you only pumped down the bogie at the electrical end this would take perhaps 5-10 mins
but not isolating the other bogie meant you had to charge 3 times as much pipework of course this would take 5 times longer as energy wanes and fully knacker the average driver:D
big all
23 Sep 2018
redhill
you had to have the gear sector in direction off travel [no neutral ]with deadmans handle or overide button on secondmans side by the window depressed to stop brakes applying and prevent the dogs shattering through lack off air pressure them skipping in and out through vibration
hexagon789
2 Sep 2016
I'm not quite sure I understand - neutral doesn't take the dogs fully out of connection to the transmission or something? Other than its a 4-speed mechanical transmission in which you can only coast in top gear I don't really fully understand the intricacies of it.
