Train derails on highway bridge in Washington state
MarkyT
20 May 2012
Torbay
Did he not propose to cut the budget for long-haul Amtrak a little while ago, though?
That's true, while in the same year Amtrack announced its best traffic year ever in November! This particular service and others in the state are underwritten by WSDOT (Washington State Department of Transportation) however, so wouldn't be affected directly by any federal budget cuts.
Dixie
19 Feb 2012
Live aerial footage of the scene is being shown here as I write:
Bend doesn't look suitable for 79 mph, but presumably they must have run some trains through it to check it
Dixie
19 Feb 2012
A photo from the scene
Dixie
19 Feb 2012
I does appear as if the front locomotive has left the track travelling in a straight line rather than negotiating the left hand curve. It looks like it has pulled the first few carriages down the embankment and as they've all come to an abrupt halt, the remaining coaches have fanned out as each one has been stopped by the one in front. So, it appears likely not to have been an issue with the coach set, but rather the loco.
Also, back from the bend, just where the bend starts, what appears to be a fishplate and short section of track has been highlighted in pink spray paint, maybe an indication of a fault, or the place at which the loco jumpred the rails. I note the bend has inside check rails on both sides.
Dixie
19 Feb 2012
The train was reportedly travelling at 81 mph as reported by a GPS railroad App. Darandio, where was it reported that the bend is restricted to 30 mph?
mrmartin
17 Dec 2012
It's definitely 30mph - you can see on this image here:
Apparently T = Talgo speed limit and P = passenger speed limit.
Apparently the 81mph is a load of rubbish off out of date GPS info from amtrak's website.
More stuff http://www.railroad.net/forums/viewtopic.php?f=46&t=166546&start=45
Something has went seriously wrong though, I'd be surprised if it was an overspeed considering they will have done a lot of testing and everyone should be paying full attention on the first run! The obstruction sounds more likely to me.
philabos
19 May 2010
Lancaster PA
I know nothing about what actually happened here.
The track is not owned by a railroad, rather just built for Washington State DOT.
No BNSF or UP ownership involved.
The curve restricted to 30mph coming off 79mph as others have stated.
Taunton
1 Aug 2013
It is normal in the US to provide check rails inside both rails across bridges, even on straights, to keep anything already derailed from going over.
The extent of the derailment and the distance travelled off track by the lead loco makes a 30 mph derailment seem unlikely, unless conceivably the rear loco continued pushing long after the front of the train came off.
AM9
13 May 2014
St Albans
They don't look like check rails, more likely just additional rails tied to the sleepers to stiffen the bridge via the track and spread the load. It's done in the UK sometimes.
westcoaster
4 Dec 2006
DTOS A or B
In the image shown, the guys in the orange hi viz jackets. Is that retaining wall damaged, and what is behind them looks like something with a ladder sticking up.
Chris M
4 Feb 2012
London E14
The rear loco continuing to push seems consistent with the end position - the annotated air photo on this BBC News article shows the leading end of the rear loco almost parallel with the trailing end of the last coach of the front portion of the train (which derailed to the right) - I think this is coach 5. what I presume to be coaches 6 and 7 are perpendicular to and level with coaches 3 and 4, coach 8 is on the road under the railway bridge having derailed to the left (roughly level with where coach 2 ended up), coaches 9, 10 and 11 are roughly level with coaches 3-5 and appear to be still connected to the rear loco. The rear loco is upright and in line with the track - possibly not even derailed.
philabos
19 May 2010
Lancaster PA
I thought the Amtrak woman on the live feed I was just watching implied it was BNSF track.
I did not see the feed. Somehow, would not be surprised.
Washington DOT now saying the tracks are owned by Sound Transit, another government agency.
News stations are now broadcasting initial radio message declaring emergency. They say the engineer, not sure how they know.
Chris M
4 Feb 2012
London E14
Since making that post I've seen a quote from an Amtrak official stating that the rear loco was "not under power", which does seem to imply more momentum than I would expect from 30mph.
talltim
17 Jan 2010
I’m pretty certain they don’t run the rear loco under power. I think the BNSF reference might come from the track being maintained by them under contract. Don’t quote me on that!
philabos
19 May 2010
Lancaster PA
What sort of warning would have been provided in cab prior to the drop from 79mph to 30?
Nothing unless the line is equipped with PTC. Do not know the definitive answer to that yet.
Should be trackside advance warning signs but nothing in the locomotive unless PTC was present.
AlexNL
19 Dec 2014
There is no PTC on that stretch of track, an Amtrak official confirmed.
Antman
3 May 2013
Confirmed on this mornings news that the train was doing 80mph on a bend with a 30mph limit.
ac6000cw
10 May 2014
Cambridge, UK
It looks like it to me. The odd thing is that there seems to be very little damage to the track in the vicinity.
Reported elsewhere as being an upturned/wrecked signal mast.
ac6000cw
10 May 2014
Cambridge, UK
Is PTC similar to AWS or TPWS?
From Wikipedia article :
A typical PTC system involves two basic components:
  • Speed display and control unit on the locomotive
  • A method to dynamically inform the speed control unit of changing track or signal conditions.[21]
Optionally, three additional components may exist:
  • An on-board navigation system and track profile database to enforce fixed speed limits
  • A bi-directional data link to inform signaling equipment of the train's presence
  • Centralized systems to directly issue movement authorities to trains
It's known as a guard rail, and as stated above its purpose is to catch the wheels of a train, derailed for any reason, to make it less likely to go over the edge. Those in the UK serve the same purpose, and I believe are mandatory on bridges unless there's a solid parapet that would provide an alternative means to restrain a derailed train.
A check rail is much closer to the running rail and when associated with a curve it is on the inner rail only. The back of a wheel contacting the check rail prevents the opposite wheel from climbing over the rail on a curve or going through the gap at a crossing.
More like ETCS/ERTMS.
Implementation of PTC in the US is very sketchy and so far is not standardised.
https://en.wikipedia.org/wiki/Positive_train_control
WatcherZero
25 Feb 2010
Bella Dinh-Zarr, spokeswoman with the US National Transportation Safety Board (NTSB), told a news conference Data recorder of the rear engine confirms 81mph in to the curve..
They also released recording of the radio call a conductor made after the crash to control saying the train was on the freeway and requesting EMS, was asked what happened replied they went off on the curve, asked if there were casualties he replied I don't think so, I will tell you when I find the rest of my carriages.
http://edition.cnn.com/2017/12/19/us/amtrak-derailment-washington/index.html
ac6000cw
10 May 2014
Cambridge, UK
My understanding is that the freight railroads settled on a common implementation some time ago (as they want interoperability of equipment across the country), but some of the passenger operators have gone for different implementations. But installation and commissioning of the systems is running well behind the dates Congress originally mandated.
