Train crew (due to take over from Leeds) left behind at previous stop (York)
syorksdeano
7 Jan 2011
I'm currently on a delayed CrossCountry service due to shortage of train manager. Apparently they left him at York.
Fair play to the guy he's walked down and apologised to everyone but how could this have happened?
Mathew S
7 Aug 2017
Whoops! How far did it get before they realised and stopped? Presumably the next station?
cjmillsnun
13 Feb 2011
The driver walked down? He was brave.
1e10
13 Jun 2013
Less than excellent.
I dont know the answer to this, but I'm assuming it was a Voyager? So who does the doors? You'd hope it would difficult to leave a TM behind if they're closing the doors.
It'll be a Voyager. The TM gives two on the buzzer after closing the doors, so it's difficult to see how this could happen.
robbeech
11 Nov 2015
Perhaps they were due a change of TM at Leeds but he was boarding at York but was delayed on a connecting service.
tsr
15 Nov 2011
Between the parallel lines
Not the first time and won't be the last. We've had one or two threads on this recently.
Some trains can quite easily leave someone behind if the guard (conductor / TM etc.) has a non-interlocked local door from which they can dispatch the train. This can apply to BR era multiple units (such as 455/8s) and HSTs, for example. All the driver may need to do is think they have heard "2" on the buzzer, take power and the train may be able to leave with the local door open and the guard on the platform.
The guard may also be alerted to something amiss occurring on the platform, and think it is preventing the train from moving even though they've given "2" on the bell or buzzer, and yet find the driver is in fact able to move the train. (In this case they should have pushed the bell or buzzer once - "1" is to stop - before making arrangements to leave the train and deal with the issue.
If there are power doors controlled by the driver under instruction from the guard, the driver could close all the doors but the guard's local door could shut as well (for example, if the local door switch is not active at the panel) or, if it is a slam door, it could be pushed shut. The driver, again, may think they have heard "2" and depart with all doors safely closed and interlocked, but with the guard on the platform.
If the train has DOO functionality as well as guard control, the driver could dispatch by DOO method in error, and forget they should have guard dispatch. Admittedly this is most unlikely on XC!
There have, from time to time, also been train wiring and other faults which have caused these issues.
Any of the above can occur quite suddenly and subsequently cause long delays and much paperwork...
syorksdeano
7 Jan 2011
This is what I was thinking. Is the change of staff at Leeds and he missed the train or is it York and how did it leave without him?
Mathew S
7 Aug 2017
Thanks, that's what I thought. There was a similar case on a Northern (150?) a while ago, also near Leeds I think, and equally difficult to understand.
Mag_seven
1 Sep 2014
here to eternity
Maybe the TM in question was supposed to be travelling passenger on the train from York to Leeds to relieve the current TM at Leeds?
Minilad
26 Feb 2011
Anywhere B link goes
TM was on a PNB at York and was booked to assist on the train to Leeds then work the train forward from there. There was a late platform change at York by all accounts which made the TM miss the service. They had to travel to Leeds on a following TPE service and take over the service from there.
The train at no point had no TM on board and the TM that missed the train had no responsibility to do the dispatch at York
tsr
15 Nov 2011
Actually another possibility. It might be an easier way to explain someone else walking through the train.
EDIT: See the post above. So you are correct. So it wasn't the TM for the York-Leeds bit who was left behind. It was "a" TM who happened to later be diagrammed to work it!
6Gman
1 May 2012
We used to try to avoid doing that for precisely this reason.
Mathew S
7 Aug 2017
Thanks @Minilad, makes sense and easy to see how that could happen.
BestWestern
6 Feb 2011
The 150 is far easier to understand; I'd wager it was a 150/1 with a non-interlocked crew door.
221129
21 Mar 2011
Sunny Scotland
Quite. Can always rely on the forum to jump to conclusions though.
syorksdeano
7 Jan 2011
Minilads explanation makes sense and explains the TM saying it left without him. I was just struggling to work out how it happened. All we got told was we left without the TM
Mathew S
7 Aug 2017
Not at all.
From the point of view of a 'lay-person' such as the typical passenger, it's going to be difficult to grasp how train crew get left behind. For example, most aren't likely to understand things like buzzers, interlocking, and so on.
syorksdeano
7 Jan 2011
The thing is I'm just a passenger so I don't know the day to day running of the railway, and judging by the complexities don't want to
Eric
21 Oct 2010
West Yorkshire
I was on that 150 and the conductor had got off via the slam door to push the doors, so that they were fully closed.
As soon as the conductor had done so, the driver was accelerating out of the station with the conductor forced to jump back on at the back or faced being left behind.
As other posters have said - this appears to be a regular occurrence on certain stock like the 150s.
Mojo
7 Aug 2005
I’ve also known for traincrew to forget they are due a relief and then carry on leaving the relief behind, or similarly pick up the wrong train!
Robertj21a
22 Sep 2013
Presumably, if the late platform change was so late that even the TM missed the train then most of the passengers must have missed it too !
infobleep
27 Feb 2011
Perhaps the passengers ran for the train as it was a late change, thinking the train won't wait for them, as they don't wait, even in circumstances such as this.
In contrast perhaps the TM didn't run for the train as although it was a late change, he thought the train would wait for him, as they do wait, even in circumstances such as this.
Sean Emmett
9 Mar 2015
Was on a steam special at Marylebone. Lots of waving from staff on the platform and away we went.
But none of them was the guard, who had to get a taxi to pick the train up at Denham...
