The Push and Pull - Branch Line Society - Thursday 3rd April 2025
MrJeeves
28 Aug 2015
Burgess Hill
An opportunity to ride one of the testing runs of the Class 230 on the Greenford branch.
Departing West Ealing P5 at 13:32, we will journey down the 2.5 mile branch line via Drayton Green to Greenford, arriving at 13.45. We then return to West Ealing, where the Class 230 will recharge on the FastCharge system, before a second run to Greenford and back, returning to West Ealing at 14.52.
If you're interestred, you need an orange hi-vis, and a BLS membership (£12) to join the event.
Egg Centric
6 Oct 2018
Land of the Prince Bishops
Thank you for that - I found the whole "orange viz" requirement so amusing that I've signed up - I also think I'll be doing my bit given it's a load test by weighing twice as much as a standard passenger.
For those who like me don't have an organe viz vest you can order at https://www.hivis.co.uk/hi-visibility-clothing/hi-vis-vests/railway-hi-vis-vests.html
RGM654
19 Jul 2022
Harrow
I wondered whether they might have hi-vis to lend, as for example LT Museum do for their Hidden London tours. But then I decided it would be all too much hassle. I will have a ride when (and if) regular passenger services withn this train start.
43096
23 Nov 2015
You can get an orange, unbranded, high viz outfit off the market!
Quite why one is needed for the punters on a railtour where they board at a platform and leave the train at a platform is anyone’s guess, though.
Egg Centric
6 Oct 2018
Nevertheless, mine has arrived today. So I'm all kitted up :lol:
(NB it must have reflective stripes too. Do "normal" ones from the market? Due to my size I have to either go to a tailor or buy online so wouldn't even have considered looking anywhere other than the latter tbh, which only cost a few quid - think the postage was more or less the same cost as the hi viz! )
Invincible
23 Apr 2022
Both an historic tour with near 40 year old stock (which will bring back memories for some) and test of high tech electric traction before the public use it, plus a talk afterwards and raising funds for charity, now full!
Egg Centric
6 Oct 2018
Anyone else coming along? It's coming up to the time and I'm starting to get buyers remorse due to the practicalities :lol:. But I will do my best to actually be there.
paul1609
28 Jan 2006
K
When the unit runs out of charge on the second trip you will be expected to descend to the track level and push the train back to Ealing. The test is to see whether the unit can charge its batteries through regen whilst being pushed by a train load of enthusiasts.
43096
23 Nov 2015
:lol: :lol: :lol:
That’s as convincing an explanation as I have seen!
Invincible
23 Apr 2022
Ha ha. the train in 2024 set a record, although a risk, a very low risk on running out of battery!
"Great Western Railway says Class 230 battery unit No 230001 has set a new distance record for the type of train, covering 86 miles on 14 February without recharging.
The distance is two miles further than a Stadler Class 777 BEMU travelled on test in 2022 on the Merseyrail network.
Two days later, the set travelled from Porterbrook’s Long Marston test facility to Reading depot – a distance of 70 miles – on battery power, using around 45% of its battery capacity. Engineers suggest this could give the unit a range of 120 miles."
paul1609
28 Jan 2006
K
Cant help but feel this is like the useless WTLP range for EVs (possibly even worse!). What is its range with the heating on and the doors opening and closing in passenger seervice?
Invincible
23 Apr 2022
I expect they have been testing this over the winter with test loads, the line is 3.5 miles so should be able to do several runs before a full 10 minute fast charge is needed.
160,303 views 27 Nov 2024 #byd #electricvehicles #electriccars
In this special episode of The Everything Electric Show, we take you on an 18-month journey behind the scenes of the development and deployment of the UK's first battery-electric train. Join Imogen as she follows the incredible progress of the Great Western Railway team, from designing the innovative shoe gear charging mechanism, to conducting fast-charging tests at Long Marston, and finally seeing the train in operation at West Ealing.
Whether you're a fan of sustainable transport, electric trains, or cutting-edge green technology or all of the above, this episode is a wonderful insight into the future of rail travel. Enjoy!
greatkingrat
20 Jan 2011
I guess the hi-viz requirement is to distinguish the railtour passengers from any normal passengers who happen to be around at the time?
Egg Centric
6 Oct 2018
They've also said in the info I have that there will be high viz available to borrow (although I've already bought mine). But as I said I can't make it and it'd be good if someone here can take it?
Egg Centric
6 Oct 2018
Word of warning: I've had ID checks take place in the past (not at every BLS event, but definitely some).
Sure - I was intending to pass it to another BLS member (rather than give it back to the "pool")*. Anyone else going on it should also be aware you're gonna be weighed, inded here are full specifics:
*Technically it also says it is not transferrable. Honestly idk how it works, my assumption is that BLS would be cool with it being passed to another member so long as we notify them in advance but if they're not then it obv ain't happening either - this entire offer is based on BLS acquiescing and if they don't then tough I guess!
