Jamesrob637
- Joined
- 12 Aug 2016
- Messages
- 6,082
The 06:27 Manchester to Cardiff is stuck at Stockport as I type this
Fault with the stock apparentlyThe 06:27 Manchester to Cardiff is stuck at Stockport as I type this
Yep can confirm it also has wheel flatsIt’s set off an axle load detector between Manchester & Stockport, and has suspected dragging brakes.
Now moved across to Platform 0 and expected to be recovered overnight Sunday into Monday.Yep can confirm it also has wheel flats
Saturday 1st NovemberDoes anyone know what the plan is for the weekend?
HD01 Had a slight brake issue earlier on so if that gets sorted out then should be okay, 67012 Has also been snapped off of HD04 and may stand in for 67016 on tonights rescue mission for HD032 Crewe starts & possible 1 off Cardiff
@sd0733
@37052 xb mr
@MP393
@BillStampy
@FrodshamJnct
Afternoon
1. What are the current formations of - which set with which loco please ?
2. Will 1W96 tonight be loco or DVT leading from Chester please ?
Thank you
Dave
67010 Set 1, 1V33, 1W61, 1V62@sd0733
@37052 xb mr
@MP393
@BillStampy
@FrodshamJnct
Afternoon
Thank you
Dave
67016 Is on 567010 Set 1, 1V33, 1W61, 1V62
67029 Set 2, 1W13, 1V39, 1W96
67015 Set 3, ATC Dvt on Wheel skate
Should move later to Electric depot
Think 67012 is with it.
No loco Set 4 ATC
No loco Set 5 ATC - B exam
67020 Set 6 Cardiff, out of service
All last week, since Monday
67008 Set 7 Holyhead failed
67005 expected to go over later
From Crewe to drag it back
@37052 xb mr67010 Set 1, 1V33, 1W61, 1V62
No loco Set 4 ATC
67008 dropped it's coolent.67010 Set 1, 1V33, 1W61, 1V62
No loco Set 4 ATC
I used this service from Newport to Nantwich and it was a very comfortable journey. Made a great change from the usual 197s.They do seem to have a Mk4 on 1W13 though, so there was indeed one Cardiff set out this morning.
Availability has certainly been dreadful for the past week or so, coming after a really good spell too. Tomorrow should see 3 and a half diagrams, likely 4 for the rest of this week and back to 5 next.Looks like only 2 out of 5 diagrams today. I think this is the worst its been in quite a while. Its resulted in a quite a few South Wales-Manchester running as 3 or even 2 cars today.
