TfGM Bus franchising
Goldfish62
14 Feb 2010
That'd need a lot of work to current infrastructure to accommodate.
Agreed. I'm firmly in favour of dual door operation for urban services, but it needs the right infrastructure, and saw tooth bus stations are no good!
pokemonsuper9
20 Dec 2022
Greater Manchester
Whose fault is that? Adapting normal bus stops presumably can be done relatively quickly. They would just have to use front door only at certain bus stations.
Basically every "normal" bus stop in Greater Manchester is just a sign stuck in the pavement, maybe with a shelter, so I don't think any changes would be required.
TheGrandWazoo
18 Feb 2013
It's not that easy. Millions are being spent on Stockport interchange for example. https://tfgm.com/stockport-interchange
When you look at Bolton and Wigan as the most notable examples, you can see how big a challenge it is.
At a time when they will have enough challenges to make the sums add up, it's simply not a necessity.
Leedsbusman
9 May 2021
Layton
Not only that but the pictures only show 4 rows of seats plus the back row - suggesting a capacity of 20 downstairs plus whatever tip ups are in the two wheelchair bays. Add a centre exit and that would make the downstairs capacity minimal.
pokemonsuper9
20 Dec 2022
Greater Manchester
The standing capacity (when no wheelchairs) seems to be quite high downstairs.
johncrossley
30 Mar 2021
If downstairs seating capacity is so important then then the operator shouldn't use double deckers. Full size single deckers or artics are the tool for that situation. I've travelled on two door double deckers my whole life and it is perfectly normal.
You would need a different arrangement for GM to allow wheelchair users to still use the front door, but that's no great issue. And anyone who opposes dual door just needs to go to London and see just how much it speeds things up, particularly on routes like Oxford Road (which itself really needs to be artics or even double artics with 3 or 4 doors).
mangad
20 Jun 2014
Stockport
London also has simple touch-in fare paying which also makes an impact on boarding times. There's no need to state destinations and wait for tickets. No need to wait for tickets machines to wake up and be ready for contactless because it's always ready. Paying by card in Manchester is definitely slower. Simplifying boarding processes would be a simpler thing to do.
mangad
20 Jun 2014
Stockport
There's no need to state destinations in Manchester either, it's just £2.
Yet everyone still states the destination. The driver still has to enter a destination, even if all they are doing is putting in the route terminus. The ticket machine has to get ready to accept your card. The ticket still has to be printed. The fare is now flat rate and simple, but no steps in the ticket buying process have also been simplified.
(I don't expect it will improve until every bus is franchised and they have introduced fare capping so don't need to sell travel cards on board.)
johncrossley
30 Mar 2021
Presumably passengers in Manchester will soon have a similarly speedy ticketing system? Otherwise that would call into question a lot of the argument behind franchising.
Yes, the £2 capped fare (not even flat as fares below £2 still exist) is a shambles regarding boarding times. The commercial operators are simply incapable of getting it. (This applies nationwide outside London, not just in Greater Manchester).
Leedsbusman
9 May 2021
Layton
By that logic as I’ve travelled on single door double deckers my whole life that’s perfectly normal too.
johncrossley
30 Mar 2021
That doesn't follow. The slowness of single door boarding is evident, yet London double deckers function reasonably well with a small number of seats downstairs, because most people go upstairs, leaving the seats downstairs for those who really need them.
johncrossley
30 Mar 2021
If "they" have wanted what you say above about "no single door only" bus stations got built, how do you explain the new bus station layouts that have been adopted and built in recent years?
We can only assume that TfGM did not even consider that they had the opportunity to introduce two door buses after franchising or were negligent. Either way it looks bad.
GusB
Elginshire
I think it's time to park the dual door debate; it has been done to death in previous threads and we're getting away from the main topic.
Leedsbusman
9 May 2021
Layton
Is it evident though in GM? It was SELNEC who adopted single door operation in the 70s and I don’t recall it significantly slowed things down. Nottingham and Lothian have switched to single door and hasn’t slowed their services as a result.
stait.john
17 May 2013
the trouble is, everywhere outside London uses ITSO smart cards which are a great deal slower than the Oyster card system.
TOTO (tap on-tap off) has proved to speed up boarding on First West of England as no ticket is issued. Ticketer machines can be very slow at picking up the card for card payments when a ticket is issued, it’s actually quicker to pay cash when issuing a ticket if correct fare is tendered.
John
