Swiss Railways
Sad Sprinter
5 Jun 2017
Way on down South London town
Had a trip on the Swiss railways recently and found them very interesting from an enthusiasts perspective. Some of the train formations are completely wild; I've seen trains with a DBSO type carriage at the front, hauling a rake of coaches, with a locomotive in the middle and a continuing trail of coaches. But most strangely, a loco pulling a few coaches and a dead double deck EMU as part of the rake with more coaches behind and a loco on the rear! This was Lausanne station this spring. Does anyone know what the train formations are so varied?
eastwestdivide
17 Aug 2009
S Yorks, usually
Because they can? If you’ve got that flexibility, then make use of it!
Over on the RhB system in the SE of Switzerland they get even wilder. Two examples I’ve travelled on:
Driving coach, normal coaches, loco, freight wagons;
Extra-powerful EMU hauling normal coaches with freight wagons on the back.
SeanG
4 May 2013
It is quite quite common to find loco + coaches + control car + more coaches on the end - with a mixture of single and double decker stock
DanielB
27 Feb 2020
Amersfoort, NL
Those trains with locos or driving trailers in the middle are often lengthened trains for the peak hours. Actually a very effective way of having enough capacity whilst avoiding hassle with shunting.
For example: once had such a combination with driving trailer, coaches, driving trailer, more coaches and locomotive at the end from Zürich to Basel in the peak. After arrival in Basel, the first set of driving trailer and coaches was uncoupled and shunted away to the yard. The standard push-pull set remaining along the platform could immediately be used for another train. Whilst inserting the additional coaches between locomotive and the other carriages would have required a lot more shunting to get the locomotive back on the train.
Re 4/4
30 Jun 2018
Bristol
Most trains in Switzerland are push-pull, but if you need extra capacity at peak hours, you stick what SBB calls a module on one end - a couple of extra coaches with a cab on the end. We don't really do gangway doors at the front of cabs anymore, so you can't get from the module to the rest of the train, but as a way of making the vessel temporarily a bit larger, it works.
RhB are special in that they happily mix passenger and goods wagons whenever there's a need to - some scheduled passenger trains regularly take an extra goods wagon or two for the local shops.
duesselmartin
18 Jan 2014
Duisburg, Germany
RhB freight does seem like a blast from the past. The good old days with local freight.
The losses are paid for the canton. A wise descision to keep trucks off mountain roads.
Re 4/4
30 Jun 2018
Bristol
Mountain roads can easily shut for a week in winter due to avalanche danger - of course that can shut railways too, but if you have the road one side of the valley and the tracks the other, you have some resilience.
bahnause
30 Dec 2016
bülach (switzerland)
The Bernina line usually has freight Monday to Friday. During the tourist periods mainly in the morning and evening, during the day the trains are at capacity with passenger carriages.
Gordon
11 Feb 2011
I enjoyed watching this set at Chambesy (near Geneve) in June 2022. Ironically I should have been back in London at work this day, but my flight was cancelled the previous evening and rescheduled to 14.30 the next day!
Three class 460 locos, all under power. The second two are top and tail on the double deck set and the front loco and single deck coaches is the added 'module'
They know how to grow the market and gain high market share for public transport, and they sure know how to run railways.
Railways are actually treated genuinely as a public service and, wherever practicable, supply is altered to meet demand.
Thanks to a member of this forum who works for Swiss railways, I am able to get discounted tickets for travel over there (when I'm not using an Interrail pass with a long period of validity) and my conclusion is there is absolutely no comparison when it comes to Swiss railways vs UK railways.
We would never ever be able to achieve anything like what they have over there; there is just no prospect of it.
bahnause
30 Dec 2016
A top and tail set is usually a sign for a faulty DVT. Adding a loco in frontt of the DVT is the short term solution.
hexagon789
2 Sep 2016
Our trains are cleaner internally in my experience.
Of the six trains (all SBB) I travelled on in Switzerland - 5 had filthy windows, 4 had rubbish on seats/window perch table/aisles/bins overflowing, 3 had vile toilets and 2 had no water.
Either I'm very lucky, but beyond the odd coffee cup or crisp packet I've not had those, admittedly mild, issues.
Dutch trains definitely had worse toilets.
Also, Swiss timekeeping not very good - 5 trains were 2 mins late, 1 was 4 down.
Hardly a paradigm of the oft-touted Swiss efficiency and cleanliness...
And yes, I still love Switzerland and want to go back soon - please don't think this is an anti-Swiss rant by any means ;)
Just their railways are not that 100% perfect, 100% of the time example people suggest.
I also find fares for short distances are also relatively expensive compared to say an Off Peak Day Return for the equivalent distance here. (I'm talking about journeys of about an hour, for maybe 45-50 miles.)
duesselmartin
18 Jan 2014
Duisburg, Germany
Slight delays can happen due to the large amount of single track working in Switzerland.
Personally I found Swiss trains cleaner than anything GWR has.
johncrossley
30 Mar 2021
:D I presume you were being sarcastic there!
Are you taking off 50% for the Half Fare card discount?
hexagon789
2 Sep 2016
No actually, I was being serious! ;)
I'm not really quibbling over a minute or two here or there, it isn't important in that it didn't affect connections or plans; it was the fact that every train was late even if only just, that was my point.
This is not consistent with my experience; I have travelled on many trains in Switzerland in the past 5 years; well into a three figure number and this isn't the norm
A few minutes here and there isn't particularly uncommon but where they excel is maintaining connections; they absolutely put us to shame in that respect.
Not 100 per cent perfect but the best country I've visited, for sure.
It's true that single-mode walk-up short distance off peak travel in the UK can be cheap, especially at super off peak times (though this is under threat from those who advocate 'simplification' which is another story) but other than that, Switzerland wins.
As a general rule, fares are very affordable for people based in Switzerland.
You will percieve them as expensive as you are considering the cost against a UK wage, rather than a Swiss salary, and of course being a non-local you don't have a discount card.
For urban areas, fares are zonal, with no penalty for using different modes (unlike the UK) and indeed 'splitting' is very much a thing when going from one urban area to another (e.g. you can get zonal tickets at each end and a point-to-point to bridge the 'gap').
If you compared the price from a Metrolink station to a Supertram station, including trams at either end and a train between Manchester and Sheffield, with equivalent prices for a similar journey in Switzerland, then adjust it for wages, the UK would be horrendously expensive.
It's a myth that Swiss trains are consistently exactly on time, but they don't need to be! What really matters is that passenger journeys are rarely later than a few minutes here and there.
It is very different to the UK approach of desperately trying to get trains out of stations early (in Switzerland you can board at the advertised departure time; boarding is vastly more civilised than the UK approach), even to the detriment of connecting passengers, only to get held up at junctions.
It's a completely different outlook, and overall it's vastly better than the UK.
Probably more useful is the percentage of connections made. 98.7% of connections were made in 2022.
On this measure the GB rail network must be dire by comparison.
Switzerland also does proper integrated transport at most locations; in the UK this is very much the exception, rather than the norm.
johncrossley
30 Mar 2021
The trouble with this comparison is that British fares are entirely market priced. At least that isn't the case with walk up fares in Switzerland, so we can quote a fare in confidence that it will be representative of the fare across the country. Brig to Martigny is about 75 km. The single fare with Half Fare card is 13.50 CHF (£12.15). That is valid anytime, peak or off-peak. Take Basingstoke to Waterloo as an example that is about the same distance. This costs £19.65 Off Peak Return with a Network Railcard (route Woking). So there's not much in it, especially if you consider the superior spending power of the average Swiss compared to the average Brit (even one living in Hampshire).
Obviously when looking at singles the comparison is much worse for the UK, as the Anytime Single with a Network Railcard is only a little less than the return and the morning peak fare at £28.30 (as Network Railcards are not valid) is outrageously expensive, more than double the Swiss equivalent with a Half Fare card which is valid at any time.
One must also consider that the Swiss have the GA annual season ticket, valid on all public transport in a year for roughly the cost of a Gold Card between Woking and London, so many Swiss never need to think about the cost of fares.
Route115?
26 Jun 2021
Ruislip
If you want to know the formation of your train it is available at:
You can find your train number at:
or
(Unfortunately the Swiss station guide no longer seems to exist but you can still get details from the DB site.)
43 302
25 Oct 2019
Not always, there are certain routes where two engines are required if the train is over a certain length. Also can be to transport an engine and save a light engine move. I've certainly had many tnt Re 460 trains.
Austriantrain
13 Aug 2018
The new Zurich underground Löwenstraße station requires top-and-tail when IC2000 are operated at full length, IIRC. Though nowadays the IC-Twindexx trains run on those services.
bahnause
30 Dec 2016
Rule of thumb: Top and tail with Re460 directly in front of DVT -> faulty DVT.
Maximum is 760 tons for a single Re460.
Jamesrob637
12 Aug 2016
View attachment 144615View attachment 144616View attachment 144617View attachment 144618
Dromédaire they call that, after the type of camel.
Rescars
25 May 2021
Another feature of Swiss working is the running, on mountain railways, of services in multiple separate portions. This looks very strange to those of us brought up on the principles of the block system.
30907
I think that applies only on wholly rack railways, where speed is severely limited.
bleeder4
19 Jan 2019
Worcester
It's the train dispatch that's always fascinated me. The minute hand on the Swiss railway clocks doesn't move slowly throughout the duration of a minute, like ours does. The minute hand jumps forward one minute all in one go at the end of the minute. And that is when the trains due to depart at that time are dispatched, right on the full minute. So if you go to a busy station like Zurich HB you will see trains departing in waves. For example, trains due to depart at 1137 will all depart simultaneously exactly as the minute hand jumps forward to mark the completion of the minute. Then you might have a few minutes of no activity, then a few minutes later you'll get another wave of trains that all depart at exactly the same time. It's a sight to behold.
Krokodil
23 Jan 2023
Wales
I wish that we did compile this statistic and considered connections when measuring delays. There's no point in a train departing right time with no one on it because they're all just arriving on the long distance train. A seven minute delay has turned into half an hour for the passenger (and hence Delay Repay) but everything made PPM so the beancounters are happy.
You do see that in the UK, the Snowdon Mountain Railway can run multiple trains as a line-of-sight tramroad. Used to be a regular occurrence but less so now that there are only six passenger carriages instead of eight.
I've got a picture of the Pilatus Bahn somewhere with a total of five railcars in section.
Rescars
25 May 2021
Once upon a time it was possible to buy a wrist watch which did the same thing with its minute and second hands. Great gift idea, but sadly not in quite the same price bracket as most stocking fillers!
Jamesrob637
12 Aug 2016
I have a Mondaine watch however the second hand functions just like normal.
43096
23 Nov 2015
You still can - it’s on the SBB website.
There’s also an app (at least for iOS) that is considerably cheaper. It also has a couple of nice features: you can have two additional time zones on it and it goes into night/backlit mode when it goes dark outside. If I remember I’ll post a screenshot.
