This is set out in Condition 43 of the National Rail Conditions of Carriage.I'm going to an event in London tonight, and am booked on the 2330 LST-NRW. If it's not running, I shall be stranded in London. If that's the case, what obligations will Greater Anglia have towards me?
43. Help from Train Companies if you are stranded
If disruption caused by circumstances within the control of a Train Company or a Rail Service Company leaves you stranded before you have reached your destination printed on or stored on your ticket, and the Train Company whose trains you are entitled to use is unable to get you to that destination by other means, any Train Company which is in a position to help will, if it reasonably can, either arrange to get you to that destination, or provide overnight accommodation for you.
Given that their website very clearly advises you not to travel ....
Customer Relations Dept guidelines state the following:
Within the control of the industry (Compensation etc IS payable)
Signal Failure
Track Problems
Following another service (as long as the original cause of delay is not on the outside industry control list)
Connection not held
Engineering works (as long as not pre-planned and advertised)
Overrunning engineering
Overhead line problems (as long as not weather related)
Power failure (as long as not due to vandalism)
Fail to Call
Not within the control of the industry (Compensation etc NOT payable)
Cable Theft
Vandalism
Weather
Flooding
Trespass
Fatality
Animals on the line
Bridge Strike
Fire
Scene of Crime
Security alert
So it would seem that the TOC in this case might not have any liability to you, especially as the advice not to travel has been widely reported for a day or so.
Greater Anglia is on the 'delay repay' scheme, and that no longer differentiates between problems, i.e. whether they are in control of the industry or no
Greater Anglia is on the 'delay repay' scheme, and that no longer differentiates between problems, i.e. whether they are in control of the industry or not.
I do agree that 'advice not to travel' must have a bearing on compensation, but all those things you rule out in the second part of your post do now result in compensation on 'delay repay' TOCs.
Signal Failure
Track Problems
Connection not held
Fail to Call
Cable Theft
Vandalism
Weather
Flooding
Trespass
Fatality
Animals on the line
Bridge Strike
Fire
Scene of Crime
Security alert
So are you saying that if I had planned to catch the last service of the night, and it was cancelled because a signalling cable had been stolen, or someone had fallen in front of a train, they would have no responsibility to get me home or put me up in a hotel?
Wow, does the money from NR go directly to the directors?
You should ask Ann Gloag![]()
