Storm Eowyn Disruption - 24/1/25
skyhigh
14 Sep 2014
The issued the DO NOT TRAVEL for Saturday on Thursday morning.
So that would tie in nicely with 48 hours notice to save some money…
Except the 48 hour thing doesn't apply on Northern. So no, it doesn't tie in at all.
Bow Fell
12 Feb 2020
There are also multiple power failures causing loss of signalling on the Cumbrian Coast line today. Bootle/Sellafield/Parton, which would have caused major disruption and multiple trains trapped if there had been any.
Luckily, only the route prover is affected.
Multiple platforms lost at Preston yesterday meant the service was thinned out as per the agreed Network Rail contingency with platforms 1, 2 and 3c lost.
Starmill
18 May 2012
Bolton
I think a key problem is that Preston - Carlisle is not blocked by infrastructure faults but neither Northern nor Avanti West Coast want to operate even as far as Lancaster.
Usually Preston <> Lancaster is a high-speed, high-frequency, high-capacity link, with frequent connections at Preston and lots of through trains, and attracts some high numbers as a result. It's a fools game to suggest only the TPE services can cope.
Course, it'd have been alright with their old rolling stock as they used to be able to deploy a pair of 350s fairly easily. No such options now.
23 Jan 2013
Eccles Signal Box
Just to be clear, the line between Preston and Carlisle is open, the weather is fine, but Avanti can't be bothered to run north of Preston and is relying on TPE to transport passengers that way? Yet again?
How is this considered remotely acceptable? It's one thing to not run services when it may be dangerous, as yesterday, but that hardly applies today.
Possibly because Glasgow/Edinburgh - Preston is run by Scotland based crew who are still stuck north of the divide, while Preston - the South has a different crew who don't sign Carlisle - Preston?
Lots of Rangers fans from Thursday night's Old Trafford game still trying to get out of Manchester this morning. I was initially advising them to catch the first available service to Carlisle and see what options were available when they got there, but then it turns out there aren't very many. Does the X95 bus still exist?
D1537
11 Jul 2019
North Yorkshire
1S01 suffered damage to the unit, believed to be caused by OHL damage, picture I’ve seen, not mine to share, shows a registration arm Severely damaged.
1S01 is still later now, just north of Little Mills Crossovers, Alnmouth.
Customers have been evacuated onto another train.
Since the image has been shared far and wide now, I presume it is this one.
Tetchytyke
12 Sep 2013
Isle of Man
The “official reason” is the major weather event which occurred yesterday, and ensuing disruption which is continuing today. Stock displacement likely to be a key one, from what was stated upthread. It’s unlikely that there will be more detail than that in the public messaging.
Of course there won’t be any more detail than that, obfuscation is so deeply ingrained in their culture that they don’t ever think to do anything else. If they can’t run north of Barrow due to a signal failure then say so. If they can’t run south of Barrow because of Preston’s roof then say so.
Why obfuscate? It’s easy to latch on to an excuse to hide the fact you’d be struggling to run your service for other reasons. That’s why Northern are so fond of “short notice change to the timetable” as a reason for cancelling trains. I simply don’t trust Northern to be straight on anything anymore. They’ve long since shredded any goodwill they might have had.
The line is open at least as far as Oxenholme. The stock isn’t out of place- or at least a of it isn’t. So why not run?
driver9000
13 Jan 2008
Avanti crew based at Preston sign and work to Scotland alongside the Edinburgh/Glasgow crews. To the south Preston work alongside Euston, Piccadilly and Wolves crews (depending on which section they're working on).
Avanti abandoning north of Preston is common in times of disruption although it's far from ideal. For instance there are capacity issues at Carlisle for holding trains between trips especially as it appears platform 1 is closed today along with the Drivers having a clause in their conditions that prevents double tripping over routes. This would make crewing a shuttle service a bit more difficult than a TPE service where Drivers can and do work double trips. Avanti are also hampered by having to provide the rostered crews based at Preston for services to the south while trying to roster enough crews with who is left to cover Preston to Carlisle without the availability of Scottish crews.
D1537
11 Jul 2019
North Yorkshire
Also presumably bi-di working as 1S01 still there.
Yes, down trains are switching to the up at Little Mill and back across at Chathill. Five trains (1E07/16/17/19/20) waiting for 1S15 to go north is why they're all bunched together, they should all get through before 1S17 gets there. There will be a queue for platforms at stations further down the line, though.
AdamWW
6 Nov 2012
People were having a similar argument about TfW not running on the North Wales Coast after Storm Darragh in December. Somebody, the following day, was repeatedly stating that the weather was fine so TfW must be able to run a service. "They've not posted photographic evidence of anything blocking the line" was another argument. I'm pretty sure someone was also claiming that TfW were using the weather to hide staffing issues, which is pure nonsense as TfW staffing issues are almost non-existent in comparison to other TOCs. It turned out that there were actually multiple issues and instructions along the line and it took the proving train 2 days to get from Holyhead to Chester. Northern may be far from perfect, but that doesn't mean they're lying.
If a company is repeatedly dishonest with passengers, it's not surprising that they become suspicious.
43066
24 Nov 2019
But, with respect, your position seems a little contradictory. On the one hand you’re demanding further detail from Northern, but the above post suggests that you aren’t prepared to believe any explanation other than the one you’ve already decided must be the correct. So what would be the point of them trotting out Preston’s roof or signal failure?!
Isn’t it more useful to stick to the known facts, rather than just criticising for the sake of it? There was a major storm yesterday that has affected other TOCs in the same area. Not all of the routes they’re struggling to run today are the ones that fall over due to lack of crew, and the ones that are causing them a problem tomorrow they’ve been upfront about as far as I can see, just as they are every weekend.
I don’t see any reason to assume they’re cancelling trains today “to save money”, which we’ve already established wouldn’t work (despite your assertions to the contrary). Similarly, I don’t see how you can confidently conclude that stock isn’t out of place, as people upthread who work for Northern have suggested it will be. Indeed, it would be more surprising if it wasn’t!
I’m sure the explanation given will be perfectly adequate for most people given yesterday’s events.
Remember that most people are simply interested in knowing where and when they can travel, so that they can plan accordingly, rather than endless detail on why any particular part of the network can or can’t be served.
Winthorpe
18 May 2019
The latest on the Avanti website is no service north of Preston tomorrow, Sunday 26th, as well
Due to the impact of Storm Éowyn, there are no trains running north of Preston (to/from Cumbria, Glasgow or Edinburgh) on Saturday 25 and Sunday 26 January while Network Rail inspect and repair damage to the infrastructure. Do not attempt to travel on this route.
Starmill
18 May 2012
Bolton
One would hope by tomorrow at least a Northern service can cover Preston to Lancaster at minimum, and a replacement bus service between Lancaster and Carlisle at minimum.
D6130
12 Jan 2021
West Yorkshire/Tuscany
Barrow-in-Furness and Blackpool North (multiple) all have quite poor records for covering their work. Workington not quite as bad, Carlisle better than the rest.
To be fair, Carlisle-based Northern crews are covered by 'Eastern' conditions of service, with Sundays as part of the working week, so they have few difficulties in covering their work.
Smidster
23 Oct 2014
Interesting - not good news. I’m sure more detail will be made available soon by those in the know.
The Network Rail Scotland Twitter account has said plans to open late tomorrow afternoon with 3 sections of OLE damage near Carstairs
Already starting to explore options for when meant to be back from Glasgow to Yorkshire Monday night which may involve many hours wandering Leeds at 3am
InkyScrolls
20 Jul 2022
North of England
One could be forgiven for thinking that given Northern's appalling record.
No reason they couldn't be running to Lancaster today, TPE are.
Yes there is. Many trees down between Settle Jct. and Carnforth which are still being removed.
Carlisle is under Eastern Ts&Cs.
Lemmy99uk
5 May 2015
I remember 20 years ago, after the major flooding in Carlisle, my immediate manager demanding to know why the train crew weren’t turning up for work on the days afterwards.
I had to explain the extent of the damage to infrastructure and property suffered by so many. The worst affected were trying to dry out what was left of their belongings but many others were without power or water and were doing their best in such circumstances to look after their families.
As I sit and type this, I have a coal fire burning, I have 2 battery lights ready for use later, I have a camping stove set up in the kitchen for hot water and my router is running of a power pack that I managed to borrow today.
The power lines that supply my villages and the 2 adjacent ones are lying in a field with the a transformer on a post at a jaunty angle. As of this moment there are no engineers in attendance and no hint of when we will get reconnected.
My neighbours to the left (a couple with a young daughter), have left to stay with friends. Others in the village (including myself), have spent the day at rescue centres dotted around the county that are providing warmth and hot refreshments.
We are not an isolated case, there are thousands of people similarly affected and some of these will be the people meant to be operating, repairing and cleaning the trains.
Its not all as conspiratorial as some people think.
Tetchytyke
12 Sep 2013
Isle of Man
Northern have said the trains are cancelled “due to the forecast adverse weather”. That’s the reason listed on JourneyCheck. This was the reason they gave on Thursday when they made the decision.
There was no adverse weather forecast for today. There never has been.
The line is open at least as far as Lancaster/Oxenholme.
Maybe there is another reason. Maybe it is storm damage. If so, say so, people will appreciate the honesty.
But forgive me for not entirely trusting Northern on this one. They have form. Especially as the routes cancelled in the north west (so not the S&C/Little North Western) are the ones where there are chronic staffing issues.
ETA the timing is what really sets my spidey-senses tingling. They made this call on Thursday, using the forecast weather as the reason. There was no adverse weather forecast for today. So I think they are being obfuscatory at best, disingenuous at worst.
The S&C I get. It’s a remote windswept railway with a history of fatal accidents in bad weather. You can say the same about them Little North Western, Millom to Whitehaven too.The rest? Hmm.
AdamWW
6 Nov 2012
Quite.
Why should anyone give an organisation the benefit of the doubt if experience shows they are neither open nor honest?
43066
24 Nov 2019
I think that can reasonably be put down to yesterday’s adverse weather, and the wrong code being entered: “never attribute to malice that which can adequately be explained by stupidity” etc. :).
Tetchytyke
12 Sep 2013
Isle of Man
No, they were very clear on Thursday that there would be no service on the Barrow and Windermere to Manchester route. Which is why I’m so cynical about their reasoning as they didn’t say that for the other routes that were closed on Friday.
Bow Fell
12 Feb 2020
It’s worth pointing out that services between Barrow and Preston were reintroduced from after midday as well as services between Workington and Carlisle.
Although, Workington to Carlisle was disrupted by a track circuit failure at Flimby and an alleged track defect at Aspatria.
Up until 1800 because of the domestic power supply failure at various locations between Barrow and Workington its very unlikely trains would have ran regardless.
No conspiracy here!
skyhigh
14 Sep 2014
As JourneyCheck is as of this afternoon:
Due to severe weather:
How does it affect your service:
Train services running across the whole Northern network may be cancelled or delayed. Disruption is expected until the end of the day.
Our advice to our customers:
Due to severe weather caused by Storm Eowyn on Friday 24th January, we are expecting disruption across the whole Northern network.
We advise customers to avoid travelling where possible on Saturday 25th January, if you do choose to travel make sure you check before travelling as trains may be cancelled at very short notice with no available onward connections.
Effect on service:
Customers are unable to travel with Northern trains on the following routes and replacement road transport cannot be provided, PLEASE DO NOT TRAVEL on these routes until start of service on Sunday 26th January:
Windermere - Oxenholme - Manchester Airport
Workington - Barrow-in-Furness - Lancaster - Manchester Airport
Trains are running between Carlisle and Workington in both directions.
A limited train service is running between Barrow-in-Furness and Preston. The last train to run on this route is the 16:51 Barrow-in-Furness to Preston.
Lancaster - Morecambe - Heysham Port
Leeds - Carlisle via Settle
Leeds - Lancaster/Morecambe
A limited service is running with the last train departing Leeds at 17:26
Nothing about "forecast severe weather" today...
Tetchytyke
12 Sep 2013
Isle of Man
Northern’s line update:
Due to a member of train crew being unavailable between Windermere and Oxenholme Lake District fewer trains are able to run on all lines.
Train services running to and from these stations will be cancelled. Disruption is expected until the end of the day on 26/01/25.
Due to a member of traincrew being unavailable between Windermere and Oxenholme fewer trains are able to run.
Effect on service.
The last trains to run are:-
The 12.45 Oxenholme to Windermere.
The 13.08 Windermere to Manchester Airport.
Rail replacement.
To assist customers to complete their journey, road transport has been requested to run as follows:-
Oxenholme to Windermere calling at Oxenholme, Kendal and Windermere.
A 16 seater minibus at 13:45 15:45 17:45.
A full size coach at 14:20 17:20 Lancaster to Windermere calling at Oxenholme, Kendal and Windermere.
A 16 seater minibus at 14:20 17:20 Lancaster to Windermere calling at all stations to Windermere.
Windermere to Oxenholme calling at Windermere, Kendal and Oxenholme
A 16 seater minibus at 14:00 18:00.
A 16 seater minibus at 16:00 19:15 Windermere to Lancaster calling at Kendal, Oxenholme and Lancaster.
A full size coach at 16:00 19:15 Windermere to Lancaster calling at all stations to Lancaster
Journey times will be extended by 60 minutes whilst travelling by Rail Replacement transport.
Please see station information posters for the bus pick up points.
Alternative arrangements
Customers can use Transpennine Express services between Preston and Oxenholme.
Customers can use Avanti services between Preston and Oxenholme.
Other places to get more information:
For live information, please visit www.northernrailway.co.uk/stations and select the station you are travelling from, or message us @northernassist on X (formerly Twitter).
If you've been delayed by 15 minutes or more, hold on to your tickets and claim compensation by visiting www.northernrailway.co.uk/delayrepay
#NorthernUpdates
Last Updated:25/01/2025 11:36
They’ve updated it.
If you go into the individual cancellations it says “due to adverse weather” or “due to forecast adverse weather”. Except, randomly, the 1611 from Barrow which is cancelled “due to passengers causing a disturbance on this train.” I’m guessing someone pressed the wrong button?
I’ve just seen. That wasn’t (and still isn’t) on Northern’s website:
DO NOT TRAVEL
Friday 24 January and Saturday 25 January
  • Barrow/Windermere / Oxenholme – Manchester Airport
  • Carlisle – Barrow/Lancaster - Manchester Airport (Cumbrian Coast)
  • Heysham Port - Morecambe – Lancaster
  • Leeds – Settle – Carlisle
  • Leeds – Lancaster/Morecambe
They’re also terminating them early…
But fair play that they did eventually try and run something.
skyhigh
14 Sep 2014
Caused by passenger(s) urinating in the saloon.
That line update is for tomorrow.
Which is correct? Adverse weather brought trees down and damaged the line, hence the cancellations. Seems reasonable to me.
There is no big conspiracy here.
