simon_train
Is the below cheaper split season ticket a valid option even if I travel on a train that does not stop at New Cross Gate when going into London Terminals. As per NRCoT 14.2 below it would seem its valid, but I would like to check?
Instead of Plumpton -> Z1-6 Travelcard
Two Tickets:
Plumpton -> New Cross Gate
New Cross Gate -> Z1-2 TravelCard
As per NRCOT 14.2 :
14.1. Unless shown below, you may use a combination of two or more Tickets to make a journey provided that the train services you use call at the station(s) where you change from one Ticket to another.
14.2. If you are using a Season Ticket, daily Zonal Ticket, or another area based Ticket such as a concessionary pass, ranger or rover in conjunction with another Ticket and the last station at which one Ticket is valid and the first station that the other Ticket is valid are the same, then the train does not need to call at that station for your combination to be valid
Two Tickets:
As per NRCOT 14.2 :
