Goldfish62
- Joined
- 14 Feb 2010
- Messages
- 13,155
I've been told that that is what's going to happen (that's unconfirmed and not an official source).Indeed, given that 3 out of the 6 C2C 387s are now directly leased by GWR, and I’d have thought it quite likely that the remaining 3 would also head to the west too.
In any case the proposed cascades speculated on don't assume any service cuts with consequently less stock required.
I thought perhaps they might be kept on standby for short term use with SWR. If the 701s aren't in service by August and the last 707s go SWR is well and truly stuffed, especially as passenger numbers are evidently increasing.The 455s drop down dead on 14th May 14th. They will not be used after that and will go direct to scrap.
The cost to run a 455 is much more expensive than to run a unit with AC traction equipment. If the demand suddenly returns then there will be a lot of unhappy punters on busy trains and that’s a fact. There will also be driver competency factors to consider and so on and so forth. My understanding is that it’s not a long drawn out process like it has been with the Class 315s but rather a Big Bang in May where they all go. Considering the amount of money spent on C4 overhauls it really is amazing.
