Southern 313s and 508s
29 May 2008
Featherstone, West Yorkshire
I know for sure that the 508s/507s have the same profile. I'm guessing the 314s and 315s do to, as they are the same bodywork.
Don't the 313s have a slightly lower roofline than the rest of the PEP EMUs?
They all have the same body profile, because they're all the PEP EMUs, and they all look basically the same. But that's not what I was asking.
O L Leigh
20 Jan 2006
In the cab with the paper
yes its is lower as they were built to be able to run in certain tube tunnels. Like on the Watford DC line. And the morrgate branch. I know for sure that the 508s/507s have the same profile. I'm guessing the 314s and 315s do to, as they are the same bodywork.
Not true.
I've said this before. While all the various EMU classes derived from the PEP prototypes have a lower roofline than other stock, this is not due to the requirement of running in tunnels. For one thing, the VCB on the roof sticks up quite some way above the roofline and this has never caused a problem. They just have a low roofline because that was what the PEP prototypes had.
And no, Cl313's don't have a lower roofline than any of the others.
O L Leigh
jon0844
1 Feb 2009
The 313s look and feel very spacious and airy, and I've certainly never had to duck down on one!!
Part of me wants nice new shiny rolling stock, but the fact is the 313s are great trains (and their derivatives) - at least with a little TLC and better seating, something Silverlink never seemed to care for. Mind you, considering the people that used the NLL, I am not surprised.
How are the 378s doing? Are they being well looked after by the passengers?
17 Aug 2009
I think I have mistaken a Class 315 for a Class 315!
jopsuk
13 May 2008
Not true.
O L Leigh
I did always wonder- I'd heard people claim that the stock for the moorgate line was such because of roofline, but doesn't the pantograph stick up even further? it was the lack of well that made me suspicious.
Has any other stock though been down to Moorgate? Do you know if a 319 or 377 would fit?
Fincra5
6 Jun 2009
The odd thing about PEP emus is that there isnt a part of the roof for the pantograph to go down into, so it just sits on the roof.
jopsuk
13 May 2008
Isn't that line 3rd rail though?
It is- in the tunnel. The pantograph folds flat, but as noted, it sits on top of the roof rather than in a well- I'd guess that it is actually mounted at approximately the same height above the rails as most pantographs. The trains run onto the East Coast main line before Finsbury park and head up that and the Hertford loop, which is all overhead power. Thus why they're 313s- they use AC power.
(As a quick reminder:
3xx: AC and dual voltage
4xx: Southern Region 3rd rail DC
5xx: Merseyside 3rd rail DC)
jopsuk
13 May 2008
An anomaly to keep the class numbering consistent within the family? They are designed with AC/Dual Voltage conversion capability, but then so are 444/450s...
jayc
15 Sep 2009
East Sussex
Always wondered why SWT's new generation of trains were numbered in the 4xx range and Southern/Southeastern's in the 3xx family.
Maybe it was because some Southern (and Southeastern?) sets were delivered as dual voltage.
Fincra5
6 Jun 2009
I dunno could be possible. As far as i am aware no SWT desiro is fitted with a pantograph to make it daul voltage. Where as, as you pointed out, a number of southern/southeastern were delivered with Dual voltage.
8 Dec 2006
Costa Del Sheppey
SET's 375/6s are dual voltage, as well as some 375/9s. IIRC all the other subclasses have recesses in the roof of the TSO for a pantograph for future use.
3xx is Dual Voltage (or capable of in the future) whereas 4xx is DC only (Desiros, Networkers etc)
What about 376s?
They have a recess in one of the roofs of a carriage for a pantograph, like most of Southeastern's newer trains (with the obvious exception of the 395s).
MCR247
7 Nov 2008
I didn't mean ONLY SETs fleet have recesses, I merely used them as a example.
But I asked why 376s were numbered in the AC & DV class, but you answered because they can be converted so I said but so do 444s/450s so that cant be the reason
Fincra5
6 Jun 2009
Ajax 103 depending on what type of 508 they can take 25KV of power AC, hence the ones that were/are with London Overground.
Really not. The 508s run on london overground, yes BUT only on DC routes such as Clapham Junction-Willesden Junction and the Watford DC line. 313s are capable of AC & DC operation.
thefab444
27 Oct 2006
The New Forest
Clapham - Willesden is a mixture of AC/DC. 508s could run Clapham Junction - Sheperd's Bush, but there'd be no way of getting them back to Willesden depot!
