South Wales 'Metro' updates
Envoy
29 Aug 2014
Thought you would like to see the state of the Taff’s Well Metro depot as of today.
positron
18 Oct 2022
Cardiff
Great news on the overheads progressing. A poster on here posted up a brilliant map showing all the lines that are wired including the sections with intermittent wiring. I don't suppose anyone has it and could post it again?
Thankyou in advance!
https://www.openrailwaymap.org/ don't suppose you mean this?
Or the electrification PDF?
I have a photo of that too! An almost completed island platform and a third track (out of sight)
Third track? I thought initially they were only doing the two tracks (original one and one new one).
I have been thinking for a while the current track placement seems too far across compared to the new island platform.
  • electrification 2022.pdf
TT-ONR-NRN
30 Dec 2016
Cambridge
It seems there is a sort of siding there, which is what I mean by third track
positron
18 Oct 2022
Cardiff
Interesting if it's the case that the platform edge isn't next to that new track (which as I said it's not seemed to be so far) it may be that they're putting in the proposed 3rd platform (at least the track) as part of the initial works.
The eventual plan is for 3 platforms to have two through platforms to extend along to Newport Road.
22 Jun 2013
The plans show a very wide island platform, there is quite a bit left to build yet, it looks like it will reach the new track and will be made from the pre-cast concrete pieces stacked alongside. I don't think there's any plan for a 3rd track at this stage.
RJ
25 Jun 2005
Back office
I go to work on this line and to my disgust, the rail replacement services are not only very far from the station and not well advertised (and way less frequent than the train), but they’re only running on weekdays! Why on earth is there no service on weekends?
Anyway, as you can see from these photos, Butetown station’s platforms are taking shape.
It’s one of my buses that’s covering the rail replacement service for the duration. Speaking to local drivers, in the past the replacement service wasn’t heavily patronised after about 10am so ticket acceptance on local buses should suffice.
As for stop locations, buses cannot really stop outside Queen Street station as it would disrupt traffic flow. The officially designated stops have been in Churchill Way for at least as long as I’ve been around which has been from January and that’s where the bus control staff always are.
AdamWW
6 Nov 2012
I'm pretty sure that they used to manage, before the road past Queen Street became a permanent road works. There is after all a layby close to the station (which I think is now accessible again).
AdamWW
6 Nov 2012
Not big enough for a bus though.
There used to be one that was on the same side as the station. Maybe it's disappeared now.
Honestly if you need to travel to the Bay, stay on the train to Central and take the No 6.
Most of the day passengers are indeed expected to get the number 6. As previously stated the replacement only runs until around 9 am and late at night.
It might help some people if TfW pointed out that Central station is handier than Queen Street for the number 6.
Envoy
29 Aug 2014
I think the Cardiff Bus 6 now goes from the south side of the Library and not St.Mary Street,
CardiffKid
13 Feb 2011
Cardiff
Still there, but it's not big enough for a bus, especially a rail replacement bus, it's about half the width of a bus, fine for a service bus dropping someone off, but not for stopping and collecting passengers.
It does, it goes from the library to the back/south of the station then on to the Bay. Transfers from train to bus are the same now as they were when I moved to Cardiff over a decade ago.
Signal_Box
25 Dec 2021
If you go down to Cardiff central tonight (now) your in for a big..small surprise…
TramTrain testing Taff Wells to Central and back via the City line.
I have to say they look comical in person, a tiny little 3 vehicle contraption not even as long as a 150. Don’t learn on the side or you might tip it over !
mrmartin
17 Dec 2012
any update on the construction of Crwys Road station? i believe it was meant to start by the end of the year?
Bob Price
8 Aug 2019
Post bases and masts taken from the bridge just south of Heath Junction this lunchtime
Last Hurrah
17 Jan 2023
Canton
Out of curiosity, how close to Cardiff University Cubic Brain Research facility (next to Cathays station), can overhead wiring go before it affects their sensitive computers ?
Did the ‘sensitivity exclusion ring surrounding the Cubic Research facility impact the nearby Rhymney Line where both lines merge before Queen St station ?
TT-ONR-NRN
30 Dec 2016
Cambridge
Gutted to have missed this. Please do share if it happens again! :)
positron
18 Oct 2022
Cardiff
That could explain why the Rhymney line wiring doesn't start for a while (starts close to heath junction). But the distance from cubric to that line would be large enough that I'd question if Cardiff uni should even be allowed that level of control (I think it's pretty silly they have any) over such a large area of public infrastructure.
I hope the real reason is probably some bridges such as Crwys Road being too low.
Also if they were that sensitive wouldn't heath hospital being close to the Rhymney line also cause issues?
MikePJ
10 Dec 2015
Here’s Butetown station, with platform fencing and access ramps now taking shape.
60159
26 Nov 2018
Pardon my ignorance, I didn’t realise that such a detailed rail map existed.
Its brilliant.
Thanks.
AdamWW
6 Nov 2012
I've had to walk past it daily to get to work as they usually don't bother putting a replacement bus on.
That's because arranging ticket acceptance with Cardiff Bus is a perfectly good substitute for trains. Apparently.
