Yeah, northern rail. I’m needing to do front end turns where I can see one of the following:What do you mean by northern network? Northern Rail? ET is Electric Token working, OTS is one train working with train staff, OTNS is one train working no train staff. They are of course not the only types of single line working...
Depends on which side of the Pennines you want, clearly Windermere, Colne, Ormskirk, Cumbrian coast etcYeah, northern rail. I’m needing to do front end turns where I can see one of the following:
Electric token working
One train working with staff
One train working without staff
Sorry, Hope that clears things up!
Oxenholme-Windermere is one train working with staff.
I think the staff is in a locked box at OxenholmeHow does that one work, given that there is no signalbox at Oxenholme?!!
Interesting, thanks. It seems an odd set up, given that the single line starts before the branch platform at Oxenholme, into which trains can presumably signalled without the staff. Can a train use this platform while another is on the branch?
Ask your manager.Yeah, northern rail. I’m needing to do front end turns where I can see one of the following:
The station isn't part of the single line and a train can use platform 3 while there is one on the branch with the staff.
I think this is probably the best advice, ask your line manager or other colleagues.Ask your manager.
There's a passing movement scheduled each day when the train comes off the branch at 1628. I saw them about to pass each other the other Friday when I was travelling on a London bound Avanti that stopped thereThanks for the information.
Indeed. The mid-afternoon Northern train from Manchester Airport to Windermere is timetabled to take 40 minutes between Lancaster and Oxenholme Lake District, some of which is accounted for it being held outside Oxenholme station. At other times of the day, it will usually take less than half that time.There's a passing movement scheduled each day when the train comes off the branch at 1628. I saw them about to pass each other the other Friday when I was travelling on a London bound Avanti that stopped there
Rainford junction is a bit of an oddity, trains to headbolt lane are worked with a staff (which is actually a token).Also token work on the Rainford line
That’s a very strange request. Front end turns are about getting used to the life of a driver and experiencing different shifts to get a feel for what is to come.Yeah, northern rail. I’m needing to do front end turns where I can see one of the following:
- Electric token working
- One train working with staff
- One train working without staff
I agree that it is critically important to ask your driver manager. See first post by WoodyRail on Thursday. But the question in post one of this thread has resulted in lots of interesting information. So very glad woodyRail started the thread.Ask your manager.
Out of interest, what method do the single line sections of the Penistone Line between Barnsley and Huddersfield use please?Off the top of my head, the following are in use:
ETB:
OTS:
- Bransty to St Bees
- Midge Hall - Rufford
- St Bees to Sellafield
OTNS:
- Morecambe - Heysham Power Station
- Oxenholme - Windermere
NST
- Rufford - Ormskirk
- Rose Grove Junction - Colne
- Bare Lane - Morecambe
NST-R
- Rainford Junction - Headbolt Lane
- Nunthorpe to Battersby
- Battersby to Glaisdale
- Glaisdale - Whitby
Barrow to Park South uses a “penguin” style tokenless block instrument which uses the typical Western Region method of working.
As you mentioned, York to Harrogate has a more modern version of tokenless block with a block bell, being somewhat of a half way house to Scottish Region tokenless block.
TCB (colour lights) from Barnsley PSB. Stocksmoor - Huddersfield involves York ROC (and Huddersfield PSB before that) asking Barnsley for a slotOut of interest, what method do the single line sections of the Penistone Line between Barnsley and Huddersfield use please?
Can you explain that.. Do you mean that Stocksmoor to Huddersfield section is run from Barnsley? If so, that doesn't seem right - as historically when the Stocksmoor to Huddersfield section was singled, and Clayton West Jct box was closed, the Penistone box (Huddersfield Jct) and the Northernmost Barnsley Box (name I have forgotten) were both in action and mechanical - so I'd assumed that Stocksmoor to Huddersfield would have moved from Clayton West Jct to Huddersfield power box.TCB (colour lights) from Barnsley PSB. Stocksmoor - Huddersfield involves York ROC (and Huddersfield PSB before that) asking Barnsley for a slot
Stocksmoor to Huddersfield is under full TCB control of Huddersfield WS at York. This does not concern Barnsley.Can you explain that.. Do you mean that Stocksmoor to Huddersfield section is run from Barnsley? If so, that doesn't seem right - as historically when the Stocksmoor to Huddersfield section was singled, and Clayton West Jct box was closed, the Penistone box (Huddersfield Jct) and the Northernmost Barnsley Box (name I have forgotten) were both in action and mechanical - so I'd assumed that Stocksmoor to Huddersfield would have moved from Clayton West Jct to Huddersfield power box.
Stocksmoor to Huddersfield does not require a slot, it is not under Barnsley's control area. The slot is for Clayton West to Penistone.TCB (colour lights) from Barnsley PSB. Stocksmoor - Huddersfield involves York ROC (and Huddersfield PSB before that) asking Barnsley for a slot
To the uninitiated, why so many tokens in different columns?I can't post the images on here as they are copyrighted but here are some links to images of Whitehaven station in 2010.
This shows the token cupboard when the cupboard is closed.
This is the machine inside of it.
You don’t want to have a position where you have no tokens at one end of the section - the whole reason ETB was invented.To the uninitiated, why so many tokens in different columns?
