Signalling disruption between Doncaster and York - 14/05/24
HST43257
10 Apr 2020
York
I’m on a northbound LNER between London and York. Stuck way down the route because of signal issues between Doncaster and York. Any further info on what’s going on?
11 Feb 2022
Doncaster
Loss of signalling, Suspected theft of signalling cables
Edit: Complete block on all lines between York and Doncaster, NR staff hoping to clamp points and implement emergency special working
Signalling lost between Moat Hills and Shaftholme Jn
Another edit to pacify being corrected time and time again: One TOC is saying cable theft, others stating signal fault
24 Oct 2015
It’s not cable theft, it’s a fuse that’s blown, but module has melted as well.
Mike99
4 Mar 2011
G E M L
Out of interest which service are you on?
Intercity_225
13 Jan 2024
March
I see at Peterborough they are letting the Leeds services through, overtaking the York services. Could they keep the queue onto the slows so that the suburban Thameslinks and Leeds/Harrogate/Skipton/Bradford services can overtake?
HST43257
10 Apr 2020
York
Announcer says cable theft. Any further info on logs to suggest it is or could this be false?
In theory this works I think. We've been handily placed on the initial part of the down slow, while trains stopping are passing into 2 and 5
800001
24 Oct 2015
Everything still suggests signal fault, blown fuse in a location cabinet, which has also melted the holder so not a quick fix.
Still not seeing anything regards cable theft (but if it’s northern or TPE) depends what delay code they are using.
Intercity_225
13 Jan 2024
March
Interesting that the LNER advice on the NRE website says services via Leeds are unaffected, while at the top of the page it says services are affected to Bradford Foster Square. Mistake, perhaps?
HST43257
10 Apr 2020
York
We are now moving with intention to begin single line working north of Doncaster on the up line
Northampton
Only 1 signal section on the slow before the platform, although they are now letting 1S30 forward so 1S31 can pull into the station.
A Hull Trains service to Beverly has also diverted at Doncaster (skipping Selby) to avoid the single line working section.
800001
24 Oct 2015
Terminating the Leeds extensions at Leeds, releases crew to divert 2 services via Micklefield.
One addition Leeds to York and 1E25 via Micklefield.
Suspension of services at Kings Cross and Peterborough for northbound Anglo Scot’s services lifted, with emergency special working to be implemented very soon.
11 Feb 2022
Doncaster
I sent you a DM from Arrakis sent by Hull trains showing this.
Only messages from Northern are for ticket acceptance for rest of the day
800001
24 Oct 2015
So that message comes from TPE, so do not know where they have got cable theft from, as all Comms as I have said has been signal fault.
So, they are looking for possibilities of cable theft, but, still, everything points to a blown fuse.
However attempted cable theft is still not confirmed.
HST43257
10 Apr 2020
York
OTT showing trains going on the down line through the "danger zone". Is this special working or normal working?
And why on earth were 1S30 and my train (1S31) held at Peterborough when a short term resolution 40 mins up the line was moving into place?
800001
24 Oct 2015
Emergency Special Working now in place.
You will have been held as timescales may not of been known, can’t hold you at Grantham or Newark as Blocking platforms, so Peterborough better option rather than having you sat in middle of countryside in a loop or slow line.
Plus you wouldn’t have got any further by being moved further ahead, as you are waiting behind 1S28 and 1N29 to pass through the area.
HST43257
10 Apr 2020
York
Currently waiting outside Doncaster. Is it possible they're looking to sort the issue now? Announcer said engineers onsite and not much seems to be moving
800001
24 Oct 2015
Line block taken after passage of 1N29 to rectify issue.
Normal working given at 22:02.
