O L Leigh
...and if it is implemented along the lines of the Strathclyde model it won't result in a reduction in staffing and, therefore, would not yield the savings that the DfT want.
O L Leigh
O L Leigh
Because a ticket examiner is on a lot less money than a guard so a net saving overall, and a ticket examiner will also be far more productive and be able to collect more fares as they don't have to worry about pushing buttons
Dispatch of trains is a very important and safety critical job.
Yes - that's exactly why the driver has the final decision as to whether the train actually moves or not....
Actually that's a point. Why was the Strathclyde model introduced? What was the motivating factor to going to DOO with on-board ticket examiners on nearly every train? Or did it start out as DOO as seen in the South East but moved to the model that's currently implemented?
errrrr actually No! Thats why the Guard is in control of when it moves as it is our decision (just like in DOO land when the driver has crappy monitors and mirrors instead of eyes) to decide when it is safe. The only time I would ever expect 1 back from the driver is if I almost caused a Spad (which luckily I have Never done)
As far as I can remember due to high losses there was a review of costs on Scotrail around the mid 80 s involving BR ,SPT local government etc ,so cost savings across the board were agreed like re signalling , sprinterisation some local electrification and DOO of SPT local electric services which I believe have always carried a second member of staff historically due to smaller stations being unstaffed but I'm sure the unions applied pressure too
That does not disprove what ac6000cw actually said! The driver does have final decision as to whether the train moves or not
Correct, DOO was introduced in lieu of shutting lines
No the driver doesn't have the final say unless, as ANorthernGuard says, the guard tries to send the train through a red signal.
It is the guard's responsibility to check that station duties have been completed and it is safe for the train to move. Then, and only then, will they give two on the bell/buzzer to signal to the driver that the train is ready to start. What grounds does the driver have to overrule this when he/she has no part in completing station duties?
O L Leigh
O L Leigh
The driver surely does have the final; say? His decision as to whether or not the train moves obviously requires the input from the guard to say station duties are complete, but as well as signals at danger there's always the (remote) chance that there may have been something (or more likely, someone) end up on the line in front of the train out of sight of the guard. It's not as if the guard has a gun to the head of the driver forcing him to start.
So, to summarise for the benefit of the pedants, the Guard has the responsibility for confirming that station duties have been safely completed and that the train's ready to depart? Still sounds like "an important and safety-critical job" to me, even if the Driver does have to make the "final decision" once the Guard's done his stuff...
I guess monitors are OK if you have station staff carry out daily checks to ensure that camera's are aligned with no blind spots and monitor quality is A ok, this happens on LUL.
Does such a thing happen on the mainline?
No, that much I agree on. So - both have important responsibilities during the non-DOO dispatch process, yes?Twlight zone time alert, it is obvious that the driver has final say to depart. He may rely on the Guard to clear dispatch but he has final say. To think otherwise is mad
May well be but it is not correct at all to say 'errrrr actually No!' to 'Yes - that's exactly why the driver has the final decision as to whether the train actually moves or not....'
Twlight zone time alert, it is obvious that the driver has final say to depart. He may rely on the Guard to clear dispatch but he has final say. To think otherwise is mad![]()
I think DOO/OPO can only be considered safe if stations are actually staffed with people who are licensed to dispatch in case of equipment failiure and that the equipment is checked regularly with markers on the platform to make sure there are no blind spots.I doubt it. I had to report a DOO mirror for being too dirty. A week later I have to report the same mirror for being etched because whoever had come out to clean it had clearly used something inappropriate to clean it. A couple of weeks after that there was a brand new mirror.
See Degraded dispatch methodI think DOO/OPO can only be considered safe if stations are actually staffed with people who are licensed to dispatch in case of equipment failiure....
And what do I do if I decide that the guard has given me two on the buzzer three minutes or so early? Or should I be giving the guard a rocket if I decide he's being too tardy?
O L Leigh
You can give the guard what you want, it is the driver decision to go. The driver is accountable not the guard
Both are accountable, surely?
Modern DOO installations (e.g. SouthEastern High Speed) are based on bodyside CCTV cameras.
Apologies, misunderstood what 68000 was trying to say - I thought the suggestion was that the driver alone was accountable for the whole dispatch process, not just timekeeping. Either way, I agree with you that it's the Guard's problem!No. If there is a delay at a station it is down to the guard but if you lose time between two places then it is down to the driver.
But would the Guard of, say, a Voyager, be able to see if a passenger had slipped under the train?And what about stock that does not permit the driver to look back while driving due to the layout of the cab or has in-cab CCTV monitors that shut down the moment the train hits 5mph or the platform is curved or has an obstructed view?
