Jamesrob637
- Joined
- 12 Aug 2016
- Messages
- 6,083
Double doors at two-thirds and a slightly higher top speed
Nothing to lose and lots to be gained?!
There aren't enough of them. Nottingham to Norwich is scheduled to go over to 170 operation in due course (although as I have written before it would be good to see Norwich's spare 755s on this route instead now that they aren't needed for the services they were originally acquired for).Double doors at two-thirds and a slightly higher top speed
Yes https://www.railforums.co.uk/thread...idlands-franchise.180920/page-57#post-4165532Can 170’s use sprinter speed differentials?
The Harrogate loop is operated by Northern and their own 170’s so isn’t an option for EMR.I think the question that needs to be resolved is which route should be losing its 170s to allow them to be used on Liverpool to Nottingham.
The Harrogate loop is often suggested but that isn't going to make many available.
But hasn’t it been said that the 755s don’t have the diesel range to work Norwich to Notts?There aren't enough of them. Nottingham to Norwich is scheduled to go over to 170 operation in due course (although as I have written before it would be good to see Norwich's spare 755s on this route instead now that they aren't needed for the services they were originally acquired for).
Well quite - we could equally suggest that Liverpool to Norwich should be run with 172s from the West Midlands but I doubt they would want to give up their units either.
I like this idea, refit the interiors for longer distance work and run them as 2x3 car! However if we're going by the logic that anything can be used and solely used for this service, then I'd also suggest a four car Turbostar (168/171), converted to 170 but kept as four car. Both of those suggestions will take away the issue of having a non gangwayed unit (not that it's that important), and there would be fast boarding/alighting at the busier stations.Well quite - we could equally suggest that Liverpool to Norwich should be run with 172s from the West Midlands but I doubt they would want to give up their units either.
I really wish people would leave Northern’s 170’s alone. And no we don’t want EMR’s junk 158’s in return before anyone suggests it.
Bringing together both your points, services from Leeds to Selby and York via Harrogate could go over to 172s, displacing 170s to EMR for Liverpool & Norwich services.Well quite - we could equally suggest that Liverpool to Norwich should be run with 172s from the West Midlands but I doubt they would want to give up their units either.
The point I was making about 172s is that they aren't any more available for a move than 170s are no matter how much speculation is made.Bringing together both your points, services from Leeds to Selby and York via Harrogate could go over to 172s, displacing 170s to EMR for Liverpool & Norwich services.
It just might be expensive to move 2 batches and potentially need to refurbish the 170s for EMR so soon after their refurb for Northern.
