Severn tunnel drainage
linuxlad7
9 Nov 2017
Did my failing eyes deceive me or did Noel Dolphin report (on twitter) that they've usfully improved the drainage in the tunnel and are ready to roll???
(as usual with his threads, (I cant find it now! but I think its starts 'Ssssshhh))
DidcotDickie
12 Mar 2017
Oxfordshire
D365
29 Jun 2012
Reported elsewhere that Network Rail need a possession to remove the balises at either end before class 80x can traverse the tunnel on electric (presumably the balises instruct the 80x to lower pantographs and switch to diesel at the tunnel entrance).
No way for drivers to override those?
linuxlad7
9 Nov 2017
The Severn Tunnel is already live. See the GW Electrification thread: https://www.railforums.co.uk/threads/great-western-electrification-progress.83452/post-4547110
thats the one - ta. must get down to Pilning
DidcotDickie
12 Mar 2017
Oxfordshire
I doubt if they can in regular service. Also a report from a GWR driver/manager elsewhere implies that an 80x has already traversed the tunnel on electric (presumably on test) so it appears that there is a way round it in special circumstances.
linuxlad7
9 Nov 2017
What locos are in line to work this route though the tunnel, for freight especially
Why so, when Class 88s have been designed for just such work.
Class 88 is fine if it's (pretty literally) the last mile that isn't electrified. The range and maximum speed on diesel are very low, so it's probably not adequate if electrification is missing for five or ten miles.
D365
29 Jun 2012
Class 93s might have been suitable if an order had actually been placed, but that's getting off topic (and very speculative).
linuxlad7
9 Nov 2017
meanwhile how do I get Welsh steel up to Brum, or even up to Burnaston
John R
1 Jul 2013
meanwhile how do I get welsh steel up to Brum, or even up to Burnaston
There are two routes up to the Midlands via Hereford and Lydney that don't require use of the tunnel, even before considering the point that the majority of whichever route is taken is currently not electrified.
linuxlad7
9 Nov 2017
Burnaston has the minor problem of no rail terminal, although one has been talked about. Does any steel for Toyota go by rail to a terminal nearby?
Willington has/had a station... failing that the A38 goes by the door, or (mixed-mode), -the Trent and Mersey. Or (as we've discussed many times) repower the Lickey
