Settlement Association
Ivo
8 Jan 2010
Bath (or Southend)
Using the serif form of the small case letter "A" ["a"], Haworth + one 180° rotation = Heworth.
(Assume this refers to Heworth on the T&W and not any others there may be; I was only aware of the one until I checked for this.)
Class172
Quizmaster
20 Mar 2011
West Country
No prizes for guessing what comes next; with a post like that Paul it was inevitable. ;)
Droitwich Spa also has a very long association with salt, however the salt is used in a somewhat different way that of the Cheshire towns.
Class172
Quizmaster
20 Mar 2011
West Country
Harrogate Spa and Bath Spa are, well, it's prettly obvious what the connection is… ;)
Xenophon PCDGS
17 Apr 2011
I am glad to see your return "to the fray" which will awake some dormant quizzes......though a little bit on the lazy side using the "Spa" association again.
Bolton (Le Mans Crescent) and Bath (Royal Crescent) both possess dramatic architectural buildings that are built on a curve.
Class172
Quizmaster
20 Mar 2011
West Country
Bolton is served by a triple-digit road with the same numbers (A666); the same applies to Nuneaton (A444).
Class172
Quizmaster
20 Mar 2011
West Country
Call me lazy for using the Spa connection too many times — I've lost count how many times you've used the Doomsday Book connection.
Canterbury (A2) and Hindhead (A3) are served by single-digit roads.
Eagle
20 Feb 2011
Leamingrad / Blanfrancisco
Particularly as you could use it to connect to the vast majority of settlements in England. :P
To stop you doing it again, I'm going to Scotland.
Hindhead has the UK's most expensive road mile for mile, the Hindhead tunnel. Before it opened in summer 2011, that record was held for about a week by the M74 in Polmadie.
Class172
Quizmaster
20 Mar 2011
West Country
Polmadie (M74) and Cumbernauld (M80) are both places now served by motorway extensions opened this year.
Class172
Quizmaster
20 Mar 2011
West Country
Northampton (A43, A45) is served by two roads in the A4x series; so is Evesham (A44, A46)
Welshman
11 Mar 2010
Whitby
The West Front and twin towers of St John's Cathedral, Paramatta, NSW, were modelled on the parish church of Reculver in 1817-19.
Earlier, in the 1770s, Captain James Cook had "discovered" New South Wales for the Europeans.
Although being born in Marton near Middlesbrough, James Cook is mainly associated with Whitby, as he moved there in 1746, and there is now the museum to his memory.
I, too, surprise myself at times. ;) ;)
Xenophon PCDGS
17 Apr 2011
The suffix ending of -by is a Viking terminology and is the most commonest Scandinavian suffix in The Danelaw, which originally signified a farmstead, but gradually in England began to be applied to villages and towns (and even cities). Whilst settlements are found in Eastern England coastal areas from Yorkshire down to Norfolk, the suffix also occurs in inland Yorkshire, parts of the Midlands and the Lancashire and Mersey areas.
Grimsby and Whitby are examples of this that are found in the coastal areas of the North Sea.
