When you send an application at SR the status on your profile will show automatically "your application is under consideration" even if your actual application hasn't been seen yet.Hi. I’ve recently been logging into the application status page to see if there has been any movement on my application.
For a while now it’s said “under consideration” however it has since disappeared and just says “0 Applications in your profile”.
Does this mean that they have simply reviewed it and dismissed the application?
I know the application status site is not always the best for checking the actual status of an application so I just wanted to ask to see if anyone knew anything or were maybe in a similar situation.
Thanks.
If you progress, it will show "your application is under further consideration". This status "could" lead to progress to the following stage which normally is an assessment. Please note that these can stay even years on your profile before you get an invite, but remember, until are there it is good sign.
The problem is if your application disappears from your profile, this likely means you have been unsuccessful at application stage. Unfortunately the recruitment team don't have always the capacity to contact formally unsuccessful candidates due the high volume of applications but they only notify those successful to the next stage.
Please also note that these informations are based from my own experience, I can't really be 100% sure if this happens to all candidates in the way I tried to describe it but I hope this could help you to understand a bit more about the process.
