ScotRail HST Introduction - Updates & Discussion
InOban
12 Mar 2017
They have the same times at most of the timing points, so only one could be activated AFAIK.
Neither seems to have even been activated, let alone actually run.
And yet they're sending another pair of power cars south on Tuesday.
Northhighland
19 Aug 2016
Doesn’t look like the revised programme will be met. Don’t suppose it is that essential with the reduced passenger numbers. Can’t see numbers going back up anytime soon. We have stopped travel to central belt and with electronic systems won’t ever go back to level it was at.
InOban
12 Mar 2017
power cars cancelled. It seems a long time since a delivery. Maybe they're waiting in case the RAIB discover some structural issue arising from the refurbishment,
Stathern Jc
30 Nov 2019
Inverness
That sounds a bit of a pessimistic thought. Is it likely that the refurbs have any vulnerability not previously present in the fleet?
Hopefully it's more likely to be that there's no pressing need to chase deliveries at the moment, and conveniently having a corresponding delay to the invoice.
DB
Guest
18 Nov 2009
Hardly - RAIB will probably take quite some time for their final report, and what are they going to find? The only way the refurbishment could possibly have had any impact on the structure is the vestibule area, and from photos of the train it's quite clear that the only vestibule with significant end damage is the one with slam doors remaining -the others are intact in all but the coach at the bottom, where the whole thing was crushed.
I really don't understand some people on here - do you really think that structural strength won't have been fully considered when designing the modifications?
DannyMich2018
19 Dec 2018
There is I believe weekdays 14 diagrammed out of 19 available sets so no rush to send any more sets up as they won't be needed. Plus the Stonehaven accident likely reduced the amount needed too so even less diagrammed at the min I assume.
scotraildriver
15 Jun 2009
Until the line reopens at Stonehaven and Cadder Yard is complete there is no need and more importantly no space for any more HSTs. The plan is to put any more deliveries in store at Slateford as Haymarket has no space and there is no work for them. Not ideal though given the heavy vandalism that occurred there before so no rush now.
PG
Isn't there somewhere else ScotRail could store them which is less prone to vandalism? Might need to be route conducted and/or route cleared to get there but surely possible if they really wanted to...
BRX
20 Oct 2008
The siding at Corrour?
Might be cheaper to pay for someone to watch over them.
scotraildriver
15 Jun 2009
That's what Cadder depot is being built for. I can't think of anywhere else. All Scotrails depots are full. Dundee Yard was just as bad.
alangla
11 Apr 2018
Longannet? Assuming the track is still there & there’s still security guards around the power station site. I assume Bo’ness is still shut after the landslip.
Journeyman
16 Apr 2014
Yeah, the Bo'ness landslip won't be fixed for months yet.
Journeyman
16 Apr 2014
I wish someone would just put the HST project out of its misery and buy some bimodes. New trains cost peanuts right now.
The problem with going the bimode route right now is that not enough of the network is wired. For example, from GLQ to INV or ABD you're talking 34 out of 180 and 154 miles respectively. So really it would make more sense to go with straight diesel rather than lugging the extra weight around.
The HSTs serve as a stop-gap until the promised major electrification over the next few years comes to be (which is kind of fitting since they were only supposed to be a stop-gap until GWML and ECML electrification 40 years ago).
mcmad
11 Mar 2015
There are 2 landslides at Bo'ness. 1 on the main E&G line that will be fixed in the next week or so and 1 on the preserved railway for which works haven't started. The comments above about Bo'ness were in relation to stabling spare HST sets on the preserved railway I think.
If only TS had agreed to proceed with the stabling point at Perth New Yard then it'd be open by now.
DB
Guest
18 Nov 2009
You seem to be missing the point that there will be a long delivery time, over half of the HST sets are now delivered, and there's little point in having electric capability when so small a proportion of the lines they will work are wired.
hexagon789
2 Sep 2016
Even if you ordered an existing design, they wouldn't be in service for quite some time and I think ScotRail would probably want a slightly more specialised design to suit their requirements, probably something with greater diesel performance more like EMR's new order.
The rest of the HSTs would be delivered before these new trains would be and given the expenditure on those it would be a waste not to use them and instead spend even more money on a new fleet.
hwl
5 Feb 2012
With much electrification on the agenda, the aim with the HSTs appears to be replacing them with new electric only stock and not bothering with Bi-mode etc.
Roger B
16 Jun 2018
Gatley
Full electrification to INV and ABD must be several years from completion, perhaps more than ten (sorry don't recall whether dates have been published)? I'd be surprised if the HSTs could soldier on for that long, of if DR would want them to, when for their final few years a significant proportion of running would be under the wires. So I'd have thought bi-modes would be the way to go, at least for the interim.
