S Stock feels dated despite age
vuzzeho
11 Apr 2022
Their air cooling systems seem pretty poor this year compared to the Elizabeth line. Do they need maintenance?
To be honest, I think they're just not very good, same with the 378s. Unless the carriage was quite empty, I've always found it kinda rubbish.
Wolfie
17 Aug 2010
Certainly not the case on the District line train l got on at Whitechapel yesterday. Positively artic compared with the 378 l'd just left.
I don't imagine that either are helped by lots of opening doors and short distances between stations.
GFE
6 Jun 2024
HA4
It would seem that there are several Air con modules in each S stock car - so perhaps some units struggling but train still Ok for service?
Also perhaps dependent on the temperature sensors setting/calibration
pbin
25 Jul 2022
Maybe I’m misremembering but I think the air conditioning on the S-stock doesn’t extract the humidity, so it’s just air cooling, really…
Goldfish62
14 Feb 2010
You're quite correct. Extract from an FOI request from 2023:
Do the trains use air conditioning (using typical refrigeration and humidity/air extraction) and/or air cooling systems (without humidity extraction)? Yes, the trains use air conditioning (HVAC) units. Each HVAC module contains a refrigerant circuit using R407C and is hermetically sealed. The HVAC units have passive ventilation but not humidity extraction
FOI request detail - Transport for London https://share.google/qy600fQaOtkf41n7u
So in humid weather, like this summer has been so far, it's not going to work particularly effectively especially if the train is full of people.
UPDATE: Using the power of Google I've found that the majority of UK mainline rolling stock aircon also does not have a dedicated humidity extraction system.
Wolfie
17 Aug 2010
Less than useful given that UK heat is almost inevitably accompanied by stupidly high humidity.
Silent
31 Mar 2016
That’s probably why on a really bad hay fever year for me, I noticed my itchy throat and coughing wouldn’t go away on an s stock out class 378, but went away on class 700’s, 350 I think and went away in supermarkets.
Recessio
4 Aug 2019
I think that's the same for cars though?
pbin
25 Jul 2022
Also not certain on this, either, but I think the Aventras do have humidity control.
Mikey C
11 Feb 2013
Before they had opening windows retrofitted, the London Borismaster bus had an air cooling system which wasn't powerful enough to cool down the interior. It did reduce the humidity though, as emphasised when on a bus where it wasn't working, the upstairs was horribly damp and steamed up. So the system did reduce humidity, even if it wasn't full airconditioning?
I'm pretty sure cars have air conditioning, as reducing the humidity to stop windows steaming up is a key benefit of having such a system installed.
35B
19 Dec 2011
Correct. My car is much more pleasant because of the dehumidification performed by the air conditioner than if it were just cooled
AM9
13 May 2014
St Albans
Isn't that why on a really hot and humid day, there will be a pool of condensation beneath a parked vehicle? That could only have come from a drain of evaporator condensate.
100andthirty
Milton Keynes
It is the process of cooling the air that performs the dehumidifier function. A car's and a train's cooling system both do this. Full air conditioning has an extra step that the cooled air is heated, if necessary, to deliver air at the temperature set by the thermostat. Cars have lots of surplus heat for the reheating function. On trains, especially in the winter, cooling and heating both require energy from the electrical supply. Whether S stock cooling functions as well as heating in cold weather is a question I can't answer, but T697 will probably be along to confirm.
