Rulebook Before Nationalisation?
BrummieBobby
16 May 2022
A question on railway history, but was there a "Rule Book" before the railways were nationalised?
Obviously there has been a standard set of rules for operational staff (Drivers, signallers, shunter, guards, platform staff and others) to follow for many years, but what did this look like before nationalisation?
Did each company have their own Rule Book, did staff who crossed over company boundaries (Long distance drivers for example) have to learn different rules depending on their location?
Northampton
I believe each company had their own rulebook (theres an old LMS publicity video on YouTube showing a young man being given his copy when starting in the loco shed).
The Railway Clearing House may have encouraged some common practice.
Gloster
4 Sep 2020
Up the creek
Each company had their own rule book, but over the years a lot of rules had reached a point where they were effectively the same on each company. Staff working onto other companies’ lines would have to know the other companies’ rules, but (I believe) they would not have to know the whole book and would just be supplied with a shortened book which contained those rules that they had to know. In some cases, for very minor incursions, this would effectively be no more than local instructions.
Even in BR days staff from one region working on to another might have to pass an extra few rules. This was particularly so for other regions’ staff working on to the Southern Region with its third rail; I presume that the same applied to the North London third rail and ER or LMR overhead for staff from the SR or WR. However, such extra instructions would effectively be part of route learning.
John Webb
5 Jun 2010
St Albans
The situation in the early days of railways was very confused. According to several items in the "Oxford Companion to British Railway History" there was at first a muddle between the 'Bye-laws' aimed mainly at passengers and the rules to be followed by employees of railway companies.
It was the setting-up of the Railway Clearing House (RCH), mentioned above by zwk500, in 1842 that began a long and slow road to standardisation.
Their "Rules for working over foreign lines" was first published in 1867. Standard telegraphic codes were recommended in 1884 but not fully in use until around 1904. Standard signalling bellcodes were first introduced in 1884 after a serious accident at Canonbury involving 4 trains colliding in a tunnel due to different codes between the two companies involved.
It should be noted that even when companies started accepting other companies carriages over their lines, at junctions between two companies the locos were often changed over so drivers only needed to know their own company's rules.
It was only with the 1923 'Grouping' that rule book standardisation really took off, again assisted by the RCH.
There were of course a number of joint lines which would have some merged version of the owning companies' rules.
Such as the CLC, M&GN, S&D and the many joint lines covering significant areas like LNWR/GWR.
You also had arrangements like maintenance and signalling which would rotate between owners eg every 20 years, which is why Shrewsbury ended up as a GWR centre but with largely LNWR signalling.
Magdalia
1 Jan 2022
The Fens
Yes the Big 4 had their own rule books.
For most joint lines that wasn't how it worked, one of the joint owners' rule books was used.
I have an LNER sectional appendix that gives a list of joint lines and which rule books applied.
For example the Midland and Great Northern Joint used the LNER rule book.
Some lines were split. For example the Great Northern and London and North Western Joint ran to LNER rules north of Melton Mowbray and LMS rules south of Melton Mowbray.
Gloster
4 Sep 2020
Up the creek
The M&GNR became operationally part of the LNER in 1930, although it remained legally independent.
simonw
7 Dec 2009
Each company had their own. I have a GW R one,with various changes glued in it.
Rescars
25 May 2021
Quite a while ago Ian Allan published a facsimile edition of the 1904 edition GWR Rules and Regulations (with a price tag of 21/- !). It's interesting to note that some rules were around for a very long time. In essence, Rule 55 was much the same for the GWR in 1904 as it was for BR in 1950.
Going further back, "Stokers and Pokers" by Sir Francis Head contains the 1849 version of the LNWR rulebook. An interesting insight into what was deemed important and required for safe working in the pioneering days.
For what it's worth, the 1904 GWR book contains 280 rules, but there are only 240 in the 1950 BR Rule Book. Somehow it's difficult to believe that things got simpler over time. The Appendices no doubt tell a different story.
As an aside, the final paragraph of BR Rule 240 states that "Vehicles fitted with doors in the floor must not be used for the conveyance of explosives". Talk about going out with a bang.....!:D
