greaterangrier
When looking at this fare, there was a routing called TILBRY&GRAVESND - would anyone be able to advise on the available routes for this journey?
Thanks
Thanks
That usually means using the ferry between those points, although the ferry is not included in the fare.When looking at this fare, there was a routing called TILBRY&GRAVESND - would anyone be able to advise on the available routes for this journey?
Thanks
Great to know, thank you!That usually means using the ferry between those points, although the ferry is not included in the fare.
That is route Any Permitted, with a Maltese cross for travel via London.Sittingbourne to Tilbury Town via the ferry Off Peak Day return with railcard £27.25
There's still nothing in the condensed routeing which excludes the possibility of going via London, and so if that's all you're shown when buying, you'd be entitled to go via London if that's normally a permitted route, provided you also go via Gravesend and Tilbury.They'd have to let you travel via London in that case.
There was a time when these tickets were unintentionally valid via London; a few people got threatened with removal from the train, despite holding a valid itinerary.
I have no idea where anyone is getting £20.30 from. The TILBRY&GRAVESND routed tickets are only available for journeys which have a certain amount of rail travel at either end, so they don't exist for Gravesend to Tilbury. The last time I checked the cheapest TILBRY&GRAVESND ticket was Higham to Stanford-le-Hope at £12.20 for an SDR, which is half decent.If a route via London is not allowable then what are you paying £20.30 fro a Gravesend to Tilbury Town ticket when you walk from Gravesend Station to the ferry, pay the ferry fee and then use the FREE bus from Tilbury Riverside to Tilbury Town.
