TheKnightWho
But I would think you would still need to know the routes to some extent (lesser, admittedly). I certainly wouldn't fancy not knowing what was round the next corner! And again the cost of introducing it, retraining everybody etc etc. Why bother?
I don't think anyone's suggesting we'd switch it over right now, even if we could. It'd be far too expensive, and politically very "courageous".
However, it's the likely end result of a smooth transition, which is already being begun with ERTMS. It's the constant transmission and in-cab signalling that are the expensive bits to install, and ERTMS is what will create that in the first place. Although the actual computational software required for an all-ATO network would have to be much more sophisticated, I'm not convinced the trains themselves would actually need a huge amount of work done to them. All that fancy computation would be at the signal controller.
Are you going to Automate the passengers as well?
They are the cause of most small delays with their one door syndrome!
How will automation deal with that?
Because ATO isn't trying to solve that, but is addressing other problems.
Obviously things will never be perfect, but ATO doesn't claim to solve every issue on the railway.
And frankly, if we carried on employing all drivers as guards then an extra pair of hands in the main body of the train would help get people on and off faster!
