Elecman
Indeed, but how many people are killed by 25kV electrocution a year? I don't think it is particularily common
A small number most ussually trespassers
Don't think there's a breakdown that shows how much rail-sourced diesel fumes contribute though.
This report is a brief summary of the current knowledge of the health effects of diesel exhaust emissions, the impact of the railway industrys activities on diesel pollution, and some of the initiatives the industry has taken to mitigate these effects.
I have an FOI request in for the table used to justify the 25kV is much safer argument from the ORR.
However they have extended the deadline beyond the normal 20 working days so they can ask NetworK Rail if they are fine with me having it.
I don't know if they will have a lot of statistically valid numerical data. It is down to the Electricity at Work Regulations requirement for conductors to be either insulated or located such that people can't come into contact with them.
This gold plating will just destroy electrification.
The Electricity at Work Regulations for conductors does not really apply here
3rd February. We shall see what happensExtended to when or is it open ended?
RSSB advised Rail Engineer that, during the development of GL/RT1210, the energy standards committee, which includes representation from Network Rail, agreed that this standard should reflect the updated BS EN 50122 by specifying the European practice of a 3.5 metre minimum clearance unless an appropriate risk assessment was undertaken.
RSSB also mentioned the extensive consultation exercise for the standard that had attracted over 400 comments and that they understood there to be an industry consensus for this proposal. A senior source in Network Rail, however, commented that removing Annex G was a late change that they had not agreed to and that no one in the company had been consulted. Their view is consistent with the impact assessment for GL/RT1201 not mentioning standing surface clearance and stating that it will retain the use of Annex G.
Furthermore, there was also no assessment of the economic consequences of this decision as required by the TSI implementation strategy. In particular, there does not seem to have been any consideration of a minimum clearance of slightly less than 3.5 metres which, as will be seen, would have significantly reduced the impact of this standards change.
Chris125 has posted in the Scottish electrification thread this link and quote to an article in The Rail Engineer:
EGIP - Electrification Clearance Woes
So we have a new standard that explicitly says it should not be applied to the GB railway without economic assessment gets applied to the GB railway without economic assessment. You couldn't make it up. :cry::cry::cry:ENE TSI in 2011 which “notes that GB railway is constrained by its small loading gauge which is difficult and expensive to alter” and that “there should be a working presumption that current GB practice should be preserved unless a conscious decision to adopt standard European practice is made by industry through its stakeholder groups, having understood the economic consequences of such a decision”.
Would the above correction be closer to what you meant to write?So we have a new standard that explicitly says it should not be applied to the GB railway without economic assessment gets applied to the GB railway without economic assessment. You couldn't make it up. :cry::cry::cry:
So, paraphrasing, ORR doesn't seem to be relaxing its stance at all.
That means onerous risk assessments at individual non-compliant points on all the routes currently being electrified, with possible restrictions of use at high-risk points.
There is a mention of an evaluation being done on the GW project about the insulation of pantograph horns, which might reduce the risks at stations.
With sections of at least 4 electrification schemes due to go live before the end of the year, we will soon find out what the impact of this policy is.
My assessment of the whole mess, Lions lead by Donkeys. When the engineers and workers of Network Rail and their contractors are given an emergency task e.g. Dawlish and Dover they do a super job. When there is input from the Pen Pushers of DAFT (including ministers), ORR and Network Rail top Brass the schemes become a bureaucratic nightmare. Why oh why is Britain unable to progress rail electrification like HS1 or the rest of Europe.:roll::roll:
I'm sure the rest of Europe has its own nightmare projects. Compare HS1 to HSL-Zuid in the Netherlands, for example.
I don't suppose the OP could get around to correcting the thread title - pain in my eyes..
HS1 was a new railway and built to the standards applicable at that time, I know, I was part of the Engineering team. That's very, very different to electrifying an existing railway where the infrastructure is around 100 years old!
It's also a "beacon of hope" for the possibility of HS2 not breaking the bank in the way its detractors insist will happen.
In case you missed it, the act has received royal assent - its just a matter of weeks until the earthmovers start rolling.I am sceptical "HS2" will happen at all.
A Tweet by Captain Deltic in reply to John Dalton implies the nightmare will get worse.:roll:
https://twitter.com/Captain_Deltic/status/835495927485980672
