Rhine Valley
HS-TRA
6 Feb 2020
Preston
I am travelling to Germany from the UK
for 3 weeks at the end of July into August.
I was going to do some line-siding on the right side of the Rhine Valley but recently found out from a local that from July 10th the whole of that side is closed for upgrade work, track signalling etc.
That being the case I was wondering if anybody knows which routes all the freight traffic using that side would be diverted by.
Any help would be gratefully received
Thanks
The obvious route, if paths can be found, is the left bank, otherwise via Giessen-Siegen is the nearest alternative. Our German members will know more.
Richard Scott
International Transport
Railtours & Preservation
13 Dec 2018
Thanks
When it happened before just went down the other side. We were staying in a hotel next to the line and it was one freight after another.
HS-TRA
6 Feb 2020
Preston
Thanks for the information guys but..
On looking further into this apparently from June until December the whole of Koblenz station is closed with all arrivals and departures being buses.
How would this affect the possible use of left bank operations.
Any further help gratefully received.
Richard Scott
13 Dec 2018
Is it? Just looked at a trip using DB website and says up to Remagen ok but closed from there?
U-Bahnfreund
6 Feb 2015
Germany
The left bank via Koblenz will be open and one of the main reroutings. There are some replacement buses on the left bank as well though, since some small-stop RB trains will be cancelled in favour of rerouted traffic.
One other main route for diversion is via Gießen, this can be inferred from the fact there are small stops without service there as well.
Normally some trains would be heading from Siegen to the north via Finnentrop - Hagen, but on that route crumbling bridges mean that heavy trains are prohibited from using it (the IC double-decker trains there have been permanently cancelled for the same reason). So probably few trains there, instead they'd go from Siegen to Cologne.
You can see the bus concept here: https://rechter-rhein.deutschebahn.com/verkehrskonzept.html
HS-TRA
6 Feb 2020
Preston
Thank you very much for the information guys.
It's very much appreciated.
Thank you.
Richard Scott
13 Dec 2018
